Question about Ovens
I HAVE A FRIGIDAIRE MODEL FGES3065KFA STOVE FIRST A MONTH AGO WHERE THE CLOCK IS PART OF WHAT LOOKS LIKE THE 7 STAYS LITE ALL THE TIME . NOW THE SELF CLEANING WONT WORK F90 CODE SHOWS UP AND THE DOOR WON'T OPEN. AND ALSO THE LEFT LARGE FRONT BURNER WON'T WORK IF THE OTHER BURNERS ARE ON BUT IT WILL WORK IF ITS THE ONLY ONE ON
  • 10 Answers
SOURCE: burners on gas stove work but oven and broiler not working
Most ovens, unless they have an electric igniter (does it go tick tick tick when plugged in and turned on? If so, it has an electic ignition.) have a pilot light. In order to keep gas from flowing out, and to prevent a possible explosion when the pilot light has gotten put out, they have an electric thermocouple on them that shuts off the gas when it gets cold. Plug the cord back in, and relight your pilot light by holding the lighter (I recommend a fireplace match or bbq lighter, not a cigarette lighter to prevent singed knuckle hairs!) over the thermocouple for a couple of minutes.
Posted on Nov 19, 2007
  • 1314 Answers
SOURCE: self cleaning mechanism is locked with door open will not shut off
hold in on door light switch hit cancel
Posted on Oct 30, 2008
  • 17 Answers
SOURCE: large burner won't shut off
This stove uses a special switch that turns one way for the large burner and the other way for the smaller burner. I was not aware that this had a seperate simmer burner on it, however. I think you using the wrong term there.
This is not computer controlled--the only computer on it should be the oven switch. I would assume that you need to replace the switch for the dual-size burner. If you take your model number in to Sears, or log onto Sears dot com, you should be able to get to the PARTS DIRECT web site on the computer, and if they ever sold that model you should be able to pull up a parts breakdown with expanded drawing and part numbers and prices. You should be able to buy the part from them. The part should be virtually the same as ANY recent model Frigidaire or Kenmore stove with the same style burner. This should be a very easy repair for you to make yourself, assuming that you know a little about working with electricity--remember, this stove USES 220 VOLTS!
Check out all of the wiring coming into the switch and going from the switch to the burner to be sure that there is not a short!
If you have one of the older smooth surface stoves, where the burners are part of the ceramic top, all bets are off, but anything you bought new in the last half-dozen years, should have a separate burner underneath a glass top, and the repair should be simple. Even with the older stove, it is still likely the switch, and should be no problem.
Posted on Feb 09, 2009
jumptrout51
  • 3361 Answers
SOURCE: Frigidaire Oven - lights are on but no heat from oven or burners
You must check your incoming power for 220 volts. You have lost one leg of your power. Either a bad breaker or bad wall outlet or bad range cord.
Posted on Jun 26, 2009
protek480
  • 1723 Answers
SOURCE: Left front burner will not shut off
Get the Model number of the data plate on the oven so I can help
Posted on Jul 20, 2009
Frigidaire gas oven Oven control panel went blank. There is electricity to stove and oven.
sounds like the clock assy. is bad part 316557206 heat usually is the cause of this part to fail,people use the self clean the oven gets up to 1000 degrees and damages the clock assy. or a large pot was on top of the stove and the heat damaged it but whatever the cause was you need to change out the clock assy. if the touch pad is black you can reuse it if it's white for some reason it doesn't peel off without damaging the overlay get a putty knife and a hair dryer,heat up the overlay and peel it off with the putty knife,go here to see the parts
https://www.searspartsdirect.com/model-number/FGFLMC55ECA/1428/0124002.html
it looks like this only comes with the black overlay because it doesn't show any other colors so you can order the overlay or peel it off and save some bucks,go to the sight,put your model number in,go to backguard and look at parts 20 and 20a this is what you need,first i would check all the wires going to the clock assy. to make sure there isn't a broken wire.good luck
Dec 24, 2017 | Frigidaire FGB24L2A Gas Single Oven
Setting the clock it is a frigidaire elite stove
Hello Susan, thank you for your post!
I understand that you need help setting the clock on your Frigidaire range. Could you provide me with your model number please? You should be able to locate the serial tag (which lists the model number) on the frame behind the bottom drawer. With this information I can better assist you. -Matt
Mar 13, 2015 | Frigidaire Ovens
I have a frigidaire electric stove,model # 316433603 there is power to the stove the only working is the clock
General answer for all electric stoves: Electric stoves are usually 220V in the USA. The clock is 120V. My first "guess" is that you have 120v to your clock and maybe light if the stove has one. You should have a separate 220v power cable ( see photo attached) that will power the range itself. The cord may be missing ( simple to unbolt), the cord my be unplugged, or the 220 circuit may be turned off at the fuse box or circuit breaker.
Mar 02, 2015 | Stoves Ovens
I have a frigidaire stove and the timer sets itself at any time of day or night...
You may find the necessary information related to your problem among these manuals Oven service manual download repair manuals installation schematic... Just choose your oven manufacturer and model.
Mar 24, 2014 | Ovens
Stove timer frigidaire part #318011502
I want a timer no # 318011502 A Clock / Timer for Frigidaire model poile CFES388RE I want to know availability and price with delivery and taxes to address suivente comuniquer by iMail only I do not speak english
lucirfrancois@hotmail.com
Francois Simard
272 Archambeault
street
Alma Quebec
Canada G8B 7P7
46129e38-7280-4209-af5a-8221ee1faecf.jpg0b834c2d-f507-4cf5-ada7-21a37af0b5f7.jpg29d0c2b4-6e82-4ed4-858a-52b016f35b16.png
Jul 29, 2012 | Frigidaire Ovens
Need to set clock on oven
Instructions
    • 1
      Check the oven to ensure that it is off and that the timer isn't running. The buttons used to set the clock are the same buttons that adjust the oven, and you may end up making unintended adjustments to the oven.
    • 2
      Press the "Clock" button to enter the clock setting mode. The LCD will show the current time set on the oven.
    • 3
      Use the "Set Temp/Time +" or "Set Temp/Time -" buttons to adjust the clock to the current time. Depending on your model of stove you may need to use the "Hour," "Min" or the "Temp/Hour" up and down arrow buttons to set the time.
    • 4
      Save the new clock setting by pressing the "Start" button. Depending on your stove model, you may need to press the "Clock" button a second time if the "Start" button does not work.
Read more: How to Set the Clock on a Whirl Pool Stove ' eHow.com http://www.ehow.com/how_5692616_set-clock-whirl-pool-stove.html#ixzz1H3Wfexf6
Mar 19, 2011 | Ovens
I need six knobs for a 1950 Frigidaire model RM-45
I have the same model stove for sale. here is my number 678-644-2161 samantha
Jul 23, 2009 | Ovens
Control panel on oven not working (clock/heat time, etc..) (model fgf326a)
HI, this control(clock/timer), will need to be replaced at this time. this code represent a control fault within the chip set(logic). this control has failed.
Jun 01, 2009 | Frigidaire FGB24S5A Gas Single Oven
Dirt and grease between glass in oven door
i have taken the glass from the inside of the oven,and just cant get grease off, tried everything ,bleach,even lemon juice,
any ideas jimmy
Aug 01, 2008 | Ovens
Ovens Logo
71 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
