Question about Canon PIXMA iP1800 InkJet Photo Printer
Canon ip1800 troubleshooting
My new ip1800 canon donot start printing
it emet seven yelow lights
and demend to adjust the cartridg
i have done it and clean it for many times
some ones tell me to flash it and so to start new program
so how to flash my ip1800
and what are the propable problems meeted
note Mr that i have just buy this printer
with my thanks ..................
  • Anonymous May 25, 2008
    I have the same problem
    My iP1800 after power flash 7 times red light 1 time yellow? What problem is this?
    Thank's
Driver
Posted on Jun 01, 2008
  • 3 Answers
Try to hold the power botton then unpluge it while still holding the power botton,then plug it after 5 seconds.then turn it on again
Posted on Aug 02, 2008
My printer is leaving a blank line through text
Please use original cartridges to solve the problem.
May 25, 2010 | Canon PIXMA iP1800 InkJet Photo Printer
Canon iP1800
Make sure you removed the protective film on the cartridges.I've seen this alot on new installs.Next clean the print catridge contacts with a clean moist (very little) cloth ,then dry cloth.It may work, Good Luck.
Sep 08, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
New ink cartridge. Canon ip1800 series print is pale
check the settings to insure your aren't printing in "Draft" mode
Jul 23, 2009 | Canon PIXMA iP1800 InkJet Printer
In canon pixma ip1700 Alarm light orange flashes 15 times
Fifteen Flashes: The FINE Cartridge cannot be recognized.
Possible causes are as follows:
- The FINE Cartridge may not be installed properly.
- The FINE Cartridge may not be compatible with this printer.
Install the appropriate FINE Cartridge. If lines are misaligned or the resulting output is not satisfactory, carry out the Print Head Alignment.
Apr 06, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Canon ip1800 printer won't print.
My Canon PIXMA iP1880 cannot print...and shows a message "ink absorber is full" can u help me this problem..
Mar 11, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Canon printer pixma ip1800 not recognizing new cartridges installed
If the cartridge is new, probably the connector between head and cartridge is dirt. clean it using dry tissue and never touch by hand the metal plate
Mar 10, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Canon iP1800 printer,flashing orange light under the green 'on'
First off, How many times does it flash organge before it goes to green?
two: out of paper
three: paper jam
four: Ink has run out
Five: FINE cartridge cannot be found
Seven: FINE Cart. not installed in correct position
Eight: Ink absorber almost full
Count how many times it flashes. Then get back to me
Feb 05, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Canon i320 amber light flashing will not print
I believe that 7 amber flashes refer to a cartridge error. Check that the cartridge is seated correctly.
Nov 05, 2008 | Canon i80 InkJet Printer
My cannon printer pixma ip1800 cannot detect ink pls help me...
If after you install the cartridge you get a yellow light and error message:
“The following may have run out of color. The function for
detecting the remaining ink level will be disabled since the
ink level cannot be correctly detected. If you want to
continue printing with out this function, press the printer’s
start button. Canon recommends using new genuine Canon
cartridges in order to obtain optimum quality.”
Do not click “cancel printing”. Press printer start button
to start printing. This action will bypass the ink level
detection from the recycled cartridge. It will not damage the
printer! With a recycled cartridge this action needs to be
done one time.
A full recycled cartridge ink level may not display correctly.
It may show empty.
If you want to check the ink level, you can do a “Nozzle
check” by follow the directions below:
Go to menu File select print click on “Property” click
on “Maintenance”
Click on “Nozzle check” to print out the color check.
Click on “Cartridge Alignment” to align the cartridge.
See pictures for above process at Inktelligent ip 1800 topic
Also the refills refered to above are at the IP 1800 inkfilling page
Sep 23, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
CANON IP 1880
i need install canon ip1880.. how?
Mar 21, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Canon PIXMA  iP1800 InkJet Photo Printer Logo
216 people viewed this question
old marine
old marine
