Question about Acer Aspire AM1610-U1201A PC Desktop
My acer am1610-U1201A won't connect to the internet. I have the modem and router hooked up, ethernet cable and all other cables hooked up appropriately, and my computer says it's connected to a "local network." All other laptops are wi-fi and connect to my internet network just fine. Any ideas?
    Sergeant:
  • 194 Answers
Right click "MY NETWORK PLACES " desktop icon.
click "PROPERTIES"
click the Local Area Connection.. "Properties"
click "INTERNET Protocol (tcp/ip)
at the lower part,, click "properties"
thru the "General" tab
click the OBTAIN an IP Address automatically
click the Obtain DNS Server Automatically
then OK..
see to it that the name of the WORKGROUP same in the name of the server computer..
right click the "My COmputer"
"PROPERTIES"
"COmputer NAme"
...if they the same , you can access the net now.. Thanks for sharing your problem in fixya.com
Posted on Sep 14, 2010
My modem and router won't work simultaneously
They chain together. Connect the modem first to the ISP drop. Then the modem to the routers main port. Then the connect the PC to the router.
Modem > Router > PC
Jan 09, 2013 | EnGenius Technologies ESR-9752 300mbps...
New modem installed and router won't work now
First step is to make sure if the modem is working. Connect your computer directly to modem with ethernet cable and see if you can log on to internet! if yes
next step connect modem to your router's WAN port with an ethernet cable and then connect your computer to one of the LAN ports of router with ethernet cable. Power down all devices and power up modem first wait until all lights are on and then router wait until all lights are on then your computer! 9 out of 10 times this works! try good luck!!
Sep 23, 2011 | Dynex 4-Port Ethernet Broadband Router...
Won't connect to internest.
first there should be 2 cables connected the device.
1) power adapter
2) ethernet cable from either a dsl modem or a cable modem connected to the wan connector
with most cable modem service its usually dhcp meaning you are always connected to the internet
with some there is ppoe connection where a user name and password is used to make a connection to be on the internet with the dsl modem
there are some dsl companies that are dhcp just like the cable modem companies.
with the ethernet cable connected the wan port on your router there should be some kind of activity light on the router but check with the type connection from your dsl or cable internet provider. also you will need a second ethernet cable to connect your computer to setup and configure the wireless settings and wep protection.
need more info?
Aug 24, 2011 | NetGear WNR2000 Wireless Router
I followed the CD instructions for connecting the router to my modem, and I am unable to get a connection. I took the thick yellow ethernet cable and connected one end to my PC, and the other end to the...
Contact your Internet Service Provider (DSL or cable) and let them know you're hooking up a router to your modem. They may have disabled the router feature in the modem and will need to identify it on their system for it to work correctly - they should walk you through the process (it's free). The thinner yellow cable you mentioned - is it a USB cable? Sorry, I've never heard of such a cable unless it's USB, Ethernet (the thick cable), or a phone line cable - the cables used for a network.
Feb 15, 2011 | NetGear WNR3500 Router
I hooked up everything right modem to router, router to computer. but i still cant get internet to my computer. if i hook my modem directly to the compiter it works fine but not through the router
Some ISPs (Internet Service Providers) limit you to *ONE* unique computer connected through the cable-modem (or DSL-modem).
Turn the cable-modem off.
Turn the router off.
Connect the cable-modem to the router, via an Ethernet cable to the 'WAN' port on the router.
Turn the cable-modem on.
Turn the router on.
Connect, via an Ethernet cable, from one of the 'LAN' ports on the router to your computer.
Restart your computer.
You should be OK.
If not, telephone your ISP, and get them to trouble-shoot from "their" end towards your end.
Sep 20, 2010 | Linksys Wireless-G WRT54G Router
Trouble connecting netgear wireless router to rca modem DCM425
First try connection the Yellow ethernet cable from the rca modem to your computer's network connection. If you get a connection this way, then your modem will work with a ethernet cable. If not, then call Comcast for help. The modem ethernet out to computer port must be connected to the wan line of the router. Then you can connect an ethernet cable from your computer network connection to one of the 4 ports of the router. For wireless connections you must set up the router and wireless adaptor with the same settings to connect. Follow the routers directions.
Good Luck
Jul 10, 2009 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
Error code 31 4 to 6 network adapter
Check these things:
  1. Is you Ethernet adapter Active
  2. Is your Cable the correct one (NOT a cross over)
  3. Refresh your IP Address for your Ethernet Card
  4. Reboot your computer and power down your modem, then power the modem up AFTER your windows is logged on
  5. Verify your modem "really" can connect, use another computer.
  6. Verify the are no network issues with your ISP
Apr 16, 2009 | Acer AM1610-UD2180A DT E2180 2.0G 2GB...
Vista desktop won't connect to internet cable modem eithernet
power down cable modem, router, and computer. Connect ethernet cable from modem to router/ and connect ethernet cable from router to PC. Power up cable modem first, after modem shows connectivity, plug in router. After router shows internet connectivity, start computer. Be sure that you LAN card operable
Apr 15, 2009 | Acer Computers & Internet
How to change Linksys wireless router?
When you get cable internet, the cable company provides you with a modem (usually). From the cable modem you can hook up the Linksys router with an ethernet cable and it will work just fine. Hook the router up to the desktop or laptop with another ethernet cable if you need to make changes to the router security or whatever. The router address is generally 192.168.1.1. YOu can type that address right into the internet address and you router page shoud show up. If you have been using the Linksys router with the phone line all you need is to connect it to the cable modem to work. An ethernet cable is like a telephone line with a fatter connecter.
Nov 29, 2008 | Linksys Wireless-G WRT54G Router
Hooking ethernet to broadband router and cable modem
Hi Sherry - The etherport port on your modem should be connected to the WAN port on your router. You then connect your pc to one of the 4 ethernet ports on the router. If this answers your question PLEASE rate this as fixed. If you need more help just add a comment and I'll be happy to assist you further. Thanks.
Jeff
Jul 10, 2008 | SMC Universal Wireless Broadband Router...
Acer Aspire AM1610-U1201A PC Desktop Logo
133 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
