Question about LG Flatron L1515S 15" LCD Monitor
After using the monitor for more than 20 minutes eyes become watery and burning sensation starts. I am afraid if it causes heavy radiation. Nirantar B P nirantarbp@yahoo.co.in
  • LG Master
  • 32,281 Answers
CRT screens emit low levels of electromagnetic radiation, mainly from the back of the monitor. LCD a lot less emit less electromagnetic radiation. The backlight from a LCD screen is provided by a CCFL lamp, this is a very small fluro tube about 2mm in diameter compared with a 20-25mm normal fluro tube.
I do not think the LCD is the cause of your problem, I suggest you consult with an EYE specialist about your problem.
For details of electromagnetic radiation of CRT and LCD screens/TVs, please click on this link :-
http://www.lcdtvbuyingguide.com/lcdtv-crt.shtml
Posted on Sep 14, 2010
Hi i have a 98 ford explorer it gets a jerk between 40klm and 80klm its runs well at 100klm please help
Without test driving your vehicle, a jerk(ing) sensation can be a few issues to look at. Some times when an engine is under a slight to a heavy load, a secondary ignition cut out problem that will affect all cylinders for a split second could cause a sharp quick jerk sensation. A crank angle sensor that could possibly going bad can cause this issue as well. Make sure no CEL or O/D lights are on or flashing. The other jerking sensation could also be caused from the overdrive trying to engage from the transmission. Make sure the trans fluid is of the correct type (Mercon). This is usually used in most Ford applications. Make sure the trans fluid level is correct when vehicle is cold and after it has been driven for a few minutes. Trans fluid will need to be checked with engine running, so be careful of moving parts when checking. Safety glasses are also recommended when working around running machinery. If fluid level and condition looks good, you might have a bad O/D solenoid going bad which has been known to be a common problem on Ford transmissions. They are located inside of transmission above trans pan cover. Usually the solenoid is replaced as an assembly. The other cause could be a trans pump starting to get weak but in this case, it\'s not likely the cause of your description.
I also read about you over heating issues when vehicle is towing or under extreme loads. NEVER REMOVE and operate engine with out a thermostat especially in a fuel injected car! By removing a thermostat may cause an engine to run cooler......... maybe yes, but engine will start to over heat again if fluid is not regulated by the thermostat to allow enough time for radiator to remove heat from cooling system. Also if there is no thermostat in the cooling system, the ECT sensor will tell PCM that the engine is running cool and to increase fuel flow to the injectors to try to warm engine up to correct operating temperature. If PCM does not receive the correct signal from the ECT, you will notice horrible gas milage, lack of heat for the HVAC system, major carbon build up in combustion cambers and intake system. Also with the additional fuel being dumped in the engine will also cause premature CAT converter failure since it will be working overtime trying to burn the excessive hydrocarbons from all the unburnt fuel. So what I would look at is to make sure that there is proper airflow through radiator. Check to make sure that the A/C condenser does not have too many bugs and road debris causing a lack of airflow going through radiator behind it. Air flow is very important. I\'m not too sure if you cooling fans are all electric or you have one big fan that is being driven by the engine which is creating the air flow for cooling. If the fans are all electric, make sure that they cycle on and off. If it is the thermal clutch type fan, you should hear a brief roaring noise of air being pulled through radiator as the clutch begins to lock fan up when it senses that the heat coming from radiator or A/C condenser becomes excessive. I\'ve replaced many of these thermal fan clutches. Your radiator could also be restricted with corrosion build up that is restricting proper flow across radiator that won\'t be detected on light driving but more noticeable when towing or going up steep hills. That\'s when the radiator has a difficult time to dissipate the extra heat. Also I\'ve seen that if the coolant was not properly diluted with water, can also cause overheating, knocking and pinging. Hope there were some helpful tips here.
Nov 19, 2014 | 1998 Ford Explorer
Ammonia smell when air conditioning running,is it safe to be in trailer
Ammonia is toxic to breathe, even at low levels. Ammonia fumes are very irritating and corrosive to the eyes, nose and airways. Fumes may cause a burning sensation, coughing, wheezing, shortness of breath, laryngitis, rhinitis and watery eyes, even at low levels. People with asthma or other respiratory problems may be especially sensitive to ammonia fumes, as may individuals with corneal disease, glaucoma, or severe liver damage.
Jul 03, 2012 | Dometic Rooftop RV Air Conditioner
Why do my eyes always burn?
The eyes burn because nerves on the surface of the eye are irritated.
The nerves are irritated because something is wrong with the moist surface of the eyes.
Tears furnish moisture to the ocular surface.
Now, about your problem. The most likely cause for your burning is a defective tear film: inadequate tear production, abnormal chemistry, wrong, pH, etc.
It would be wise to have Dr. Easton evaluate you. It is most likely a simple case of dry eyes, but there are other major medical problems that include tear film deficiencies. Your physician knows what questions to ask and what diagnostic tests to perform. In the meantime, she can recommend the best treatment plan to relieve your discomfort.
Nov 23, 2010 | Health & Beauty
I have the heavy duty 4 cycle Amana dryer. When I turn it on it is very loud and stops after about 20 minutes. It smells really hot so maybe it's overheating? But why?
sounds like motor bearings are failing. causes motor to overheat and cut out on motor protector. I'm afraid a new motor is in order.
Jun 15, 2010 | Amana DLE330RAW Electric Dryer
Replaced thermostat, water continues to overheat and is expelled out the cap to the water reservoir. Water heat gauge show low heat then spikes to extreme high intermittently.
You have air pockets in the system. With the engine cold, remove the radiator cap. Then run the engine until the thermostat opens as you top off the radiator and keep an eye on the temperature gauge. If you think the car is going to overheat, replace the radiator cap, shut off the engine and wait 15 to 20 minutes to let the engine cool. Once the thermostat opens, lightly grab the upper radiator hose to feel for air pockets. You will feel the bubbles as they pass through the hose. Then have someone else rev the engine to 1800 - 2000 rpm and hold it there while you top off the radiator completely and then install and tighten the radiator cap. DO NOT DROP THE RPM BEFORE THE CAP IS SECURED OR YOU MAY BE SERIOUSLY BURNED!! Finally, let the engine run and monitor the temperature and road test. You may have to repeat the steps 2 or more times to remove all of the air but usually it will clear the first time.
May 18, 2010 | 1998 Ford Expedition
My bmw 323i overheats about after 2 hours of driving my heaters work and i dont know why.
check if thermostat is stuck open as too much flow can cause this. start car cold and see how long top radiator hose takes to heat up. shoud stay cold for 3-4 minutes.
if thats ok check thermo fan operation- run can in drive way at idle for 20 + minutes untill fan starts, keep an eye on temp guage.
Dec 15, 2009 | 2000 BMW 5 Series
LG Flatron L1515S 15" LCD Monitor Logo
167 people viewed this question
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
