Question about Intel D946GZIS Motherboard
Ram slot diagram - Intel D946GZIS Motherboard
  • Intel Master
  • 32,281 Answers
You can download the motherboard drivers and manual from Intel WEB site. Select your model motherboard/device, and make sure you select the Windows XP or Vista version of the drivers that matches your Windows operating system.
Please click on this link and select your model motherboard : -
http://downloadcenter.intel.com/default.aspx?iid=gg_support-au+home_downloadctr
Posted on Sep 14, 2010
Where can I get a diagram and user manual for unidentified motherboard?
There will always be some numbers or markings that will help. Often near the ram slots or in between the pci slots. Googling those should yield results. Please post a photo if you require further assistance with this.
Oct 28, 2015 | Computers & Internet
Only one ram slot works
Latops have two RAM slots and they usually are located on the bottom of the laptop.
If you see only one RAM slot on the bottom of your laptop then this is RAM slot is number 2, the other RAM slot is located under the keyboard and this memory slot is RAM slot number 1 and the first RAM module in installed in this RAM slot.
Jun 01, 2012 | Computers & Internet
Fiteed new quad core CPU and 4gb of Ram, when started up getting no signal detected on the monitor. Can anyone help?
Let's back up a second.
A) What HP model is it? (P/N. Product Number. Back of desktop computer tower)
B) What model number of Intel quad core is it?
C) What are the manufacturer ID number/letters on the ram memory module/s?
I need to know what Northbridge chip is used on the motherboard, to know if it will support the particular Intel quad core you're trying to use.
This I can hopefully obtain from HP Support, by looking at the specifications for the motherboard.
(This technology does not apply to motherboards that support the Intel Core i3, Core i5, Core i7, and Core i9 processors)
The Northbridge chip is part of the motherboard chipset.
So aptly named, because on a desktop computer motherboard it sits to the 'North', for one.
(Under the Processor)
[ Chip and Chipset are slang terms for I.C.
Integrated Circuit,
http://en.wikipedia.org/wiki/Integrated_Circuit
The Northbridge chip handles the faster capabilities of the computer.
It handles the Processor, Ram Memory, and High-speed graphics.
AGP and PCI-Express are high-speed graphics technology.
A graphics card plugged into a PCI slot, and Integrated Graphics, is Not high-speed graphics.
The Southbridge chip handles the slower capabilities of the computer.
Motherboard Diagram;
http://en.wikipedia.org/wiki/File:Motherboard_diagram.svg
List of Intel Chipsets, and more specifically the one's that can handle Intel quad core processors,
http://en.wikipedia.org/wiki/List_of_Intel_chipsets#Core_2_chipsets
Secondly;
Make sure the Ram Memory you installed is Compatible.
If the motherboard supports 4GB of ram, make sure it is in the correct ram slots if using two sticks of ram, or four sticks.
There HAS to be a ram memory module ('Stick') in Slot 1. (DIMM 1)
EACH ram memory slot has a Maximum Amount.
For example if there are 4 ram slots, and the Maximum Total Amount of ram memory is 4GB, each ram slot may have a maximum of 1GB.
It may, or may not be that you can use Slot 1 and Slot 2, and use two 2GB sticks.
Third:
Always go slow when upgrading.
Install the Processor first, boot the computer up, see how it works.
THEN shut the computer down, unplug from power, observe Anti-Static Precautions, and install 2GB of ram memory.
Works?
Install the other 2GB.
BIOS has to recognize the changes.
Fourth:
Are you sure your Power Supply is adequate to support the quad core, and the added ram memory?
Post back in a Comment.
Regards,
joecoolvette
Jul 24, 2011 | HP Computers & Internet
Motherboard P5B-TMX-GB-SI diagram need to add addition RAM could do with contact numbers
DDR2 Upgrade for the ASUS P5B-TMX-GB-SI Motherboard 4GB kit (2GBx2), 240-pin DIMM, DDR2 PC2-8500 memory module
Part Number: CT2KIT25664AA1067
Guaranteed-compatible with the ASUS P5B-TMX-GB-SI
http://www.crucial.com/store/listparts.aspx?mfr=ASUS&model=P5B-TMX-GB-SI
you can see all of the crucial updates for this motherboard ram
hope this helps
2q==
Jun 16, 2011 | Computers & Internet
Need to upgrade ram in desktop
easiest way is they only fit in the ram slot its usully to the right of the cpu fan, there are usually two or more slots pretty much touching each other they have a little divider thing in the middle of the slot where you put the card, if thats to confusing just go to google and type in ram slots and look at the images you should be able to work it out from there
Jan 14, 2010 | Computers & Internet
Changing the ram in my toshiba stellite a45 laptop
I don’t have a diagram for upgrading memory in this particular model, but it’s very easy. You can access both memory slots from the bottom of the laptop if you remove the memory cover. The cover is located in the middle, right beside the fans. All you have to do is remove 2 screws and remove the cover. I believe Satellite P15 memory is expandable to 2GB in both slots (Slot A + Slot B = 2GB) and you can use PC2100 DDR RAM, PC2700 memory should work too (it will run at PC2100 speed).
Check the laptop specifications before you buy new RAM module. I just discovered that different Satellite P15 models use different memory types. For example, according to Toshiba specifications Satellite P15-S409 uses PC2100 DDR memory, but Toshiba Satellite P15-S479 uses PC2700 DDR memory (I think it might be a typo, but not really sure).
Jul 31, 2009 | Toshiba A45-S121 Notebook
I want to add RAM, but I haven't yet found the slots. Can someone tell me where they are?
The slot will be on the bottom (the part of the laptop that sits on the desk). Remove the screw(s) that are holding the cover and you will see the existing RAM (usually a green module about 2 inches in length).
Apr 13, 2009 | Computers & Internet
I have a Philips Easylife LX3000 computer and wish to upgrade the RAM from 2Gb to 4Gb. Please would you send me a diagram or describe which panel I need to remove to reveal the RAM ports. Also would you...
Go to http://www.kingston.com and look up your model there, and find out what memory is available. Not all computers can take 4 GB of memory.
To access the RAM, you need to power down the machine, and open the case. RAM sits in DIMM slots on the motherboard.
To remove RAM, there are small latches on each side of the slot, open them carefully so they don't break. Lift the memory stick out gently.
If you break the latches (happens to all of us!) just make sure the memory is seated firmly in the slot. The computer will still run.
To insert RAM, notice that there is a small notch along the bottom of the stick, it needs to line up with the corresponding bump in the slot. Push the stick in gently but firmly until it locks in place.
Go slow, have plenty of light available, and you should be able to make this upgrade yourself.
If I've solved your issue, please mark this problem as "Fixya", if not please let me know what else I can do for you with a comment.
Good Luck,
Airoff
Jul 21, 2008 | Computers & Internet
Ram
You can try this link for diagrams.
http://repair4laptop.org/notebook.html
If you're looking for the ram, it will be under a panel on the bottom of the machine. If there is only one slot under the panel, the other slot will be located under the keyboard.
Jun 27, 2008 | Dell Inspiron 630M Notebook
Server
Hey there chandru 2020, the configuration problem which you are experiencing is related to the positioning of your ram in the appropriate slots. Servers work with matching pairs of ram, installed in either two, four or eight sticks of memory. The placement of less than a full set , in your case two minimum is also very specific. You should go to the Dell website to access configuration diagrams for your server model. Also check to ensure your ram is compatible, and try installing just one pair at a time. There is also a possibility that a blank may need to be inserted in empty dimms. I hope this helps. Good Luck!
Jan 28, 2008 | Intel D845GVSR Motherboard
Intel D946GZIS Motherboard Logo
73 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
