Question about Acer D-Link 2.4GHz Wireless Router 802.11b (DLINKROUTER)
I have a dlink router and I'm trying to get it secured. Can you tell me how to do this?
  • Acer Master
  • 32,281 Answers
To secure your wireless network from unauthorized access, please click on this link and follow my insrtuctions :-
http://www.fixya.com/support/r3559128-wireless_router_security
Posted on Sep 14, 2010
3 Suggested Answers
T3KK
  • 171 Answers
SOURCE: we have aa dlink DIR615 router. Can you tell me
This button is used to quickly set up wireless networks with the WiFi Protected Setup.
Wi-Fi Protected Setup is used to easily add devices to a network using a PIN or button press. Devices must support Wi-Fi Protected Setup in order to be configured by this method
more information is available in your manual and this forum
If this helped you then please help me and vote kindly, thank you.
Posted on Oct 12, 2009
router-user
  • 550 Answers
SOURCE: Can not connect to internet thorough my dlink 614
You will need to check the wireless settings of the router
is there any computer connected to the router ?
If yes then you can open the router set up page on that computer.
Router set up page is the page where you can check all the wireless settings of the router.
Click here for step by step instructions
Posted on Aug 09, 2010
How do I make my Dlink wireless router secure
There are several methods for "Securing" your router. I'll answer in general first, and if you need more info, just ask. Here are the top three methods to make your Router "Secure":
1. Create a Password for the ADMIN access to your router. This ensures that no one can get to your router through your IP address, and make changes (like adding their own computer to your DHCP Table). Be sure and record this somewhere safe.
2. Along with this password, Create a "Passphrase/Security Code", and install this code in your Router's Wireless Settings. I recommend sixteen digits, mixed alpha and numeric (recommend using lower case alpha only).
3. Create a Table of TCP IP addresses which emcompasses ALL the devices you will be allowing access to this router. For added security, make your range OUTSIDE the default range. Example: 192.168.0.210 to 192.168.0.214. That would give you Five devices, and ONLY those five devices could connect (this is your own situation). Then set the "Number of Devices" to just "5".
4. There's actually a fourth step called "Locking it Down" to those devices ... but first get to the point where you can actually SEE these devices connected within the router's DHCP Table. GOOD LUCK!
Jan 11, 2015 | D-Link DIR601 WirelessN 150 Home Router...
I have a dlink n150 router dir-600L. i tried to configured it and changed the SSID and network key. the problem is, i cannot connect it to the wireless connection even though the network appears on my
Did you enter the security key (password)? It may be your laptop? Try resetting the D-Link to default settings and connecting to the laptop. They reconfigure the SSID and Security Key. Write down the info for future use. Here's a user Manual: http://www.dlink.com/uk/en/home-solutions/connect/routers/dir-600-wireless-n-150-home-router
Jan 24, 2013 | D-Link DIR601 WirelessN 150 Home Router...
I'm trying to reload my dlink wb1310 but I don't have the security key.
Most router have a reset in the back. Hold it in till it cycles. This will clear ALL custom settings. Then use the defaults.
Jan 08, 2013 | D-Link Computers & Internet
My DLink router is out of warranty, and I need the security key?
Only you have the security code. Do a RESET of the D-Link, this will reset to default settings. Press and hold the RESET button until the D-Link resets , 30 sec. or so, Reconfigure the SSID and Security code. Take a look at this: http://support.dlink.com/emulators/wbr2310/index.htm
Dec 06, 2012 | Computers & Internet
Can not connect to internet thorough my dlink 614 router It tells me the internet security key is incorrect even though i know it is not
Please access the web interface of the router and confirm the security key. Also, you can try to change the security key. It can be a possibility that your computer is not synchronizing properly with the current security settings.
If you find that you are putting the right security key then please change the security type to wep 64 bit or wep 128 bit and configure a new key. Also, change the SSID or the network name and try to connect.
In case of any issues please let me know which windows you are running and the security settings on the router.
Thanks,
Rashish
Aug 09, 2010 | D-Link AirPlus DI-614+ Wireless Router
I changed the security settings on my dlink 625 router
is wii showing available network?call dlink they should be able to help!!! :)
Jul 05, 2009 | Nintendo Wii Console
Needed to secure my dlink dwr 655
ok...
first you need to find the default gateway of the router,u need to do this settings in the computer which is wired to the router,securing the network over a wireless connections is not suggested..
click on start,run,and type in cmd,hit enter,a black box should appear in that box type in ipconfig and hit enter,once you hit enter it will give u a lot of results check the default gateway the generic default gateway is 192.168.0.1,might be different in your case incase if you have setup in a different manner,now open an internet explorer page and remove the website name that present in the addess box,now without http or www type in the numbers,it will tell you to put in the user name and password,username is blank and password is admin (this is generic to all the delink routers provided you have not changed it earlier,if u ave changed it then put in the user name and password that you have setup,now it should open a dlink router page,now in that router page you will see an option that will says wireless,under wireless you will see an option that says security,click on security,and then under security page you will see security mode,from here you can use the security type that you want to use and then save the changes once it has saved the changes you wireless netwokr will be secured.
PS:make sure the computer is connected with a wire to the router when we are setting the security in the wireless network....
vedhick.........
Feb 21, 2009 | 2wire Computers & Internet
Lost disk for d-link router
You may download it on the Dlink's download site. You may go to this link and select the correct model number and revision of your router.
http://support.dlink.com/downloads/
Just download the Quick Router Setup.
You may also manually configure the wireless security of the router. The instructions is posted on Dlink's Knowledge Base.
http://support.dlink.com/supportfaq/
Just select the model number of your router and click GO. Then click on Wireless Encryption and select the type of encryption you want to configure on the router.
Apr 17, 2008 | D-Link Wireless
How do I secure my dlink wireless connection?
Type 192.168.0.1 (you can type the router address if you have changed) and enter on browser's addressbar. Router's interface will appear.
Click on SETUP and Click on the WIRELESS SETTINGS at left side. on the page you will see the option of WIRELESS SECURITY by drop down menu you can choose the Security mode that you wish. here is the link for the emulator
http://support.dlink.com/emulators/wbr1310_revB/wireless.htm
Please post your question if you need further assistance
Good Luck
Jan 19, 2008 | D-Link 802.11g Wireless Router WBR-1310...
Acer D-Link 2.4GHz Wireless Router 802.11b (DLINKROUTER) Logo
127 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
