Question about Fisher and Paykel DEGX1 Electric Dryer
We have a Fisher and Paykel Model #DEC27CW1 All of a sudden it stopped heating. Is there something we can check other than the vent, which is clear?
  • 552 Answers
You want to check the fuse on the heater canister, the link below is to a video that explains how to do so.
http://www.appliancerepairlesson.com/
http://www.youtube.com/watch?v=g0Yf2tRE_dA
Posted on Mar 06, 2011
  • 111 Answers
Dryers work on two 120 volt circuits which is why the breaker in your electrical panel is twice as wide as a normal breaker. If you can get an electrical tester you can check the wall plug to ensure you are getting at least 220 volts from the two straight plug holes. Put the tester on AC Volts, place one lead to one side and the other to the other slot. If you have a problem getting this to work you can also go from the slot to the round plug hole. Then again from the other side to the round plug hole, doing it this way you should get 120 volts.
Posted on Sep 14, 2010
My fisher and paykel dryer will not heat
Check all the fuses on the unit with an ohm meter. Also go to you tube for visuals on how to do this
Feb 23, 2015 | Fisher and Paykel Dryers
Fisher and Paykel dryer dries clothes on medium heat but shuts off repeatedly if I set it to normal dry setting.
you probly have a venting problem disconect the vent from the dryer and try it see if it works ok if so get someone to clean vent ducking out.
Mar 26, 2014 | Fisher and Paykel DEGX1 Electric Dryer
Bought dryer In October 2007. Now the auto-dry cycle is not doing the job. Clothes are still quite damp when cycle shuts off. The lint bucket is not full and we cleaned out area leading to it along...
You may need to reset the breaker for the heating elements or clean and check the continuity contacts. Go to http://fisherpaykelparts.net/techhelp/fisher-paykel-top-load-dryers-us-models/ This forum will work you through your problem
Sep 28, 2010 | Fisher and Paykel DEGX1 Electric Dryer
My fisher paykel DEGx1 dryer top load is only blowing cold air
Could be something simple like a limit popped due to clogged vent or a open heating element. DEGx1 Service Manual
Jul 22, 2010 | Fisher and Paykel DEIX2 Electric Dryer
Won't heat - otherwise acts normally....
You could check for obstructed vent of excessive lint.
I have an old dryer manual for fisher/paykel
for the x1, how different can they be? LOL
Oct 22, 2009 | Fisher and Paykel DEGX2 Dryer
Fisher Paykel Dryer is taking 3 hours to dry(DeIX2)
Check your cvent going outside. also check to see if the vent is smashed. try using the time dry cycle and see how your clothes turn out. if they are still wet or damp. you have a heating problem. try those solutions.
Oct 19, 2009 | Dryers
Fisher paykel elec dryer not heating
Check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Aug 02, 2009 | Fisher and Paykel DGGX1 Electric Dryer
Dryer tries to start - then stops and beeps PLEASE HELP
Check the exhaust hose. If the dryer isn't venting properly it will either stop or the heater will turn off and the clothes will remain wet. If the hose is not clogged check the wall vent tube.
Apr 29, 2009 | Fisher and Paykel Dryers
Fisher and Paykel DEGX1 Electric Dryer Logo
Top Fisher and Paykel Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Bill Eager
Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
