Question about Intel Motherboard
When i start my pc all the fans will start the cpu gets warm but the mouse,keyboard, and monitor do not start u, but my usb dvd drive will start up. any ideas would be greatly apreciated
  • 97 Answers
Problem with *********** board
Posted on Sep 14, 2010
Reset cmos
If the monitor had no signal, what was/were your indications(s) that the keyboard and mouse were not working? It is possible that the CMOS may have erred and caused your lack of video, but not likely.
Check this...look at the heatsink for the CPU? Are the fins clogged with dust/dirt? If so, it is possible that the CPU is going into auto shutdown from overheating. Even if the fan is running, if there is no air moving over the fins, the CPU will overheat. If that is not the problem, then my next guess would be the onboard video has given up the ghost. If you are not getting any kind of beep codes that would indicates CMOS errors, then this is likely.
Jan 21, 2015 | HP Pavilion Media Center a1510n PC...
Blank screen, no signal to monitor, no HD light, no mouse light, no keyboard lights, no beep.
maybe it could be a frayed/broken wire leading to the visual/sound parts. if not then bring it to tech support and have them look at it
Dec 20, 2013 | Computers & Internet
Desktop PC powers up but can't fully boot
Check hard drive cable, remove and insert again, this only u ca do if u see the bios running up but couldn't complete the process because no hard drive detected.
May 17, 2012 | HP Computers & Internet
I was using the computer for a short time, just reading news on the internet when it beeped three times and the monitor went blank and the mouse and keyboard also stopped working. I had to do a hard...
hi your cpu fan might be loose or your RAM open pc and make sure cpu fan is secure if its loose a little tighen it or your RAM might have popped out it can get very hot around RAM and sometimes it pops out ...hope this helps be carefull...bonnell
Sep 23, 2010 | Gateway FX7026 PC Desktop
Dell dimension 2350 cpu fan failure
i can help with the mouse & keyboard.
go into the bios on boot screen you press DEL i think then activate the USB mouse & keyboard option then save & exit.
there will be settings for the cpu fan in there somewhere but i can't remember where sorry.
Aug 16, 2009 | Dell Dimension 2350 PC Desktop
My computer turns on but nothing responds
Most likely your motherboard was DOA. Send it back for a replacement. Sounds like you've done all the troubleshooting stuff.....do double check the power supply connector...especially the P4 connector that I have occasionally forgotten to plug in...that will also cause the symptoms you describe.
Aug 14, 2009 | Intel D915GUX Motherboard
Emachine wont start
remove all external and internal peripherls.
example for external: mouse, monitor, keyboard, printer.
Internal: hard drive, memory modules, video cards, modem (if there's any), optical drive or dvd drives.
just leave the motherboard, power supply and processor intact, try turning on the computer with out those components mentioned. see if you get a beep sound before it turns off, but if not the most logical part that needs to be replaced on this type of problem is the power supply if that doesn't work the next thing to do is replace the motherboard. hope that helps
hit me back on the results. thanks!
May 25, 2009 | eMachines T6211 PC Desktop
Problem:Monitor problem and Dvd drive problem
open your cpu and clean all dust from it.reattch all power connection and harddisk connection .also clean dust form RAM and refix it.
ten enter i bios setup.
then load optimal defaults settings.ten save and exit.
Feb 02, 2009 | HP Compaq Presario SR5612F-B Desktop PC &...
Monitor says
Try and kill the bios. Find the jumper next to the battery on the motherboard and move it from position 1-2 to 2-3 ... press the power button a few times. then put the jumper back to normal and give it a shot.
I would disconnect the cables first before anything and attempt to boot the system.. if it boots, then start plugging hte cables one after another until you find out what's causing the machine not starting correctly.
Good luck.
Jun 15, 2008 | Computers & Internet
Acer L5100 install problem
I think it would get power through the Moniter so I don't think you need a power cord for the CPU. Hope this helped =)
Feb 25, 2008 | Computers & Internet
Intel Motherboard Logo
26 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
