Question about Fisher and Paykel GWL11 Top Load Washer
Hi guys! I am having a similar problem with my Fisher and paykel smartdrive 508. Every thing goes well apart from the rinse and spin cycles where it needs to get ride of water. The is no panel flashes or error codes. It just stops there making a semi loud noise. I tried spining the fan at the bottom few times. Any help please. Leo
    President:
  • 1,932 Answers
These are the things which causes the above problem 1. The drum pulley is loose 2. The drum bearings have gone (collapsed) causing the drum pulley to wobble 3. The drive belt was to slack 4. A motor fixing bolt or bracket securing the motor to the tub has broken or come loose 5. Water has got onto the belt causing slippage 6.An obstruction or item of clothing temporarily jammed the drum causing the belt to spin off.
Check the drain pump and the drain pipe.There may be some debris like coins got which may prevent the impeller from rotating which may prevent from draining
Thank You
Posted on Sep 14, 2010
My fisher and paykel eco washer spins weirdly and makes lots of noises
Noisy
If the user is complaining about noise, it may be in a number of different areas. Is the noise during
spin? Is it a banging sound? This would typically be the drain hose, inlet hoses, mains lead or
harness. If it is an out of balance noise, check that the machine is level and stable. Check the
bias spring and balance rings. Remove the inner bowl and check that its weight is within
specification (Refer Section 1.12).
If it is a 'clunk' that occurs up to 3 times per cycle, this would be a bowl check and is completely
normal. It occurs when SmartDrive is draining and 3/4 empty. This is a 'feature' and a noise that
cannot be reduced.
Other things to check are:
• Is SmartDrive level and on all four feet equally.
• Check the mains lead, inlet hoses and drain hose outside the wrapper, behind SmartDrive.
• Check the harness and drain hose inside is not banging on the wrapper during spin.
• Check the bias spring is fitted correctly.
• Check the 2 balance rings in the inner bowl contain water. Check the bowl weight.
• Check for noisy suspension rods.
Apr 04, 2013 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher and Paykel Washing Machine "Pride 5.5" Smartdrive 8 Model MW058U. Washing tub thrashes around violently when wash cycle starts any spinning - even during rinse cycle. Load looks even around...
Hi just found your posting.Do you still require help?The problem with your machine sounds like your suspension rods are faulty.Please reply and I can help you rectify this fault.Looking forward to your reply.
Jul 14, 2010 | Fisher and Paykel Washing Machines
Fisher & paykel smartdrive 508 filling slowly
remove the hoses and check for any kind of clogging or restriction in the line there may also be a problem with your fill valves
Mar 08, 2010 | Fisher and Paykel Fisher & Paykel Washer
Fisher paykel smartdrive 601
I can talk you through diagnostics if you want to go on live chat cheers
Mar 13, 2009 | Fisher and Paykel Fisher & Paykel Washer
My fisher and paykel smartdrive 708 stops at rinse/spin cycle with machine still full of water
with no error code ... I would check you drain pump or drain hose... you first may want to try a shop vac connected to the end of a drain hose .. let me know if it helps
Dec 15, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Doesn`t finish cycle
Thanks for the information !
Sep 19, 2007 | Fisher Paykel EcoSmart GWL15
Fisher n Paykel Smartdrive 9
Most waashers rinse with cold water and if your cold water screen on the valve is plugged and it can't let water in it may cause your problem.
Aug 30, 2007 | Fisher Paykel EcoSmart GWL15
Fisher and Paykel GWL11 Top Load Washer Logo
77 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
marley mcelhinney
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
