Question about Frigidaire FWS933F Top Load Washer
How do i bypass the lid switch on my Frigidaire washer
  • 333 Answers
SOURCE: How to bypass Lid Switch Admiral Washer
The only way to bypass this switch is fist pill the plug, gain access to the switch from under the hood. put a jumper wire on the 2 wires on the switch. that will do it. I hope this helps you out.
Posted on Nov 28, 2008
Maytag317
  • 1136 Answers
SOURCE: kenmore washer lid switch bypass failure.
HI. Check and see if you might have tripped the breaker. If there is a ground fault outlet close by. check that as well.
It sounds like you bypassed it properly. Try and reconnect the wires with the wire nut. Sometimes it doesn't connect properly.
I hope this helps you.
Please let me know if I can assist you further.
Thanks
Vic
Posted on May 30, 2009
  • 37 Answers
SOURCE: Maytag Washer lid switch
Ohm out the blue/ blk terminals on the sw (remove wire harnes first and notate wire color connection) with an ohmmeter-- Reading should be zero (closed lid position)
Then ohm the ylw and white sw terminals-- reading should be 0 as well.
If I am not mistaken this sw has a plunger that sticks out, if hte unit goes off balance this could push the plunger in. to reset- pull the plunger out
Lou
AFFORDABLE APPLIANCE REPAIR
(949) 855-0788
Posted on Jun 20, 2009
Maytag317
  • 1136 Answers
SOURCE: maytag washer stops at spin cycle
Hi, You can get to the lid switch by removing the screws that hold the control panel to the cabinet. This model has a fuse included with the lid switch.
Please let me knwo if I can assist you further.
Vic
Posted on Jul 01, 2009
SOURCE: How to bypass a lid switch on a Kenmore 90 series washer?
I took a small screw driver and inserted it into the hole, pushing down gently, further then the little plastic arm on the lid could reach. It continued on with the cycle so I knew that was the problem. I took a plastic sheet rock anchor,(the kind that you drill a small hole in wall then slip it in, and when a screw is inserted it expands behind the sheet rock and will not pull out) and slipped it over the little plastic arm on the lid (it pushed the switch a little further in, which enabled me to use until I could replace. The I went to youtube and they have lots of video's on how to take the cover off and fix.
Posted on Aug 23, 2009
Wont start, fill, nothing
A lid switch can be bad and click but still not work. The only way to be sure is to bypass it but Frigidaire uses a double action switch sometimes that makes it more difficult.
Sep 27, 2015 | Frigidaire Washing Machines
Can you by pass the lid switch
I appreciate your inquiry, friend!
Based off what you have described you would like to bypass the lid switch on your Frigidaire washer. It is not recommended to bypass this part. Doing so could lead to a fault within your washer. I hope this information is helpful. -Matt
Feb 13, 2015 | Frigidaire ATF7000ES Stackable Front Load...
Bypass lid switch
Never ever bypass lid switch. Legal liability forever. Any future owner of machine has 2 years from the day they discover bypass to sue the crud out of you for injuries. Not worth it for cheap lid switch. Do it right. If you discover bypassed lid switch on customers machine, fix it or leave machine inoperable.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/perry_14036f9bc71cde6a
Jan 12, 2015 | Whirlpool WTW6400SW Cabrio Washer
How to bypass lid switch fws1233f50
I DO NOT THINK YOU CAN IT WILL BURN THE MOTOR UP
Jun 15, 2014 | Frigidaire FWS933F Top Load Washer
Washer will not drain or turn on
You have a bad lid switch. It is usually just 2 wires which you can cut and splice together to bypass the switch. The motor on those runs the motor which spins the tub and pumps the water out, the lid switch is there to interrupt the motor if lid is opened. Now some of these models have a door lock incorporated into the switch as well. if that is the case here then you need to replace the whole switch/lock assembly.
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
Dec 11, 2013 | Frigidaire FEX831CS Top Load Stacked...
Lid lock bypass
Your "lid lock" really is an interlock to prevent machine operation when the lid is open. I use a plastic clothespin to close the interlock because the lid on my washer got bent
May 12, 2013 | Frigidaire Washing Machines
How do i bypass the lid lock switch on my amana top load washer
I had that problem with a top loader and wedged half of a wooden clothespin between the lid and the switch to close it. Problem solved!
Feb 18, 2013 | Amana Washing Machines
I have a old Frigidaire stackable. My lid switch is bad. I can bypass it, but i was told the motor would burn out if left in the bypass position. I was told the manufacture doesn't make a switch f
if you can find any lid switch that will fit, use it, just make sure that the wires are the same size and you'll be fine. the switch only interrupts a sigle line to break the circuit when the lid is open. just like the light switch in your wall. So again if it fits and the wires are the right size do it. What is the model number of this washer?
Jun 09, 2012 | Frigidaire Washing Machines
Whirlpool washer doesn't spin or empty. Could the lid switch cause both issues
Yes , you have a bad lid switch . You can bypass the lid switch , which will cause the washer to spin and drain with the lid open ( after you raise the console ) , but if you have kids in the house , it would not be adviseable to bypass .
Apr 18, 2010 | Whirlpool Washing Machines
Nov 28, 2008 | Admiral AAV7000A
Frigidaire FWS933F Top Load Washer Logo
2,147 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
