Question about Bunn BT10B Coffee Maker
Need the lid seal or gasket for a BUNN BT10-B
  • 189 Answers
Please call customer service with the model and date code and we will be happy to assist you with this problem. The number is 800-352-2866.
Posted on Oct 20, 2010
Bunn VPR 12-cup pourover is leaking water from the back at the bottom every time I pour water in. It leaks about 1/2 cup or more. Is there a seal or gasket I can replace to remedy this?
VPR has a semi-sealed tank that keeps +1 pot of water heated and ready to brew. Pouring in a full pot of cold water will fill the top tray and allow a slow trickle of cold water into the top which forces hot water to over flow into the brew basket. This continues until all the cold water drains into the heater tank. So the brew is matched volume per volume. UNLESS the thank was empty or not filled prior to brewing. Follow the brewing instructions from Bunn (on line for *FREE* download at Bunn.com)
* If it leaks (from the bottom) only when you pour in water. Then your pouring it too fast and over flowing the fill tray. slowdown, watch the level in the tray. do not fill past the lid.
* If it leaks just sitting (not brewing) then there is a hole in the tank. Call for service.
* If it leaks after filling the tray half way. then the top of the tank has a leak, loose, cracked, or missing gasket. There is quite a few gaskets on the lid. Call for service.
* Final; Leaks are always bad around electrical equip. Best to unplug and call for service to be safe.
Aloha, ukeboy57
May 12, 2017 | Bunn Coffee Makers & Espresso Machines
Bunn coffee maker leaks
VPR has a semi-sealed tank that keeps +1 pot of water heated and ready to brew. Pouring in a full pot of cold water will fill the top tray and allow a slow trickle of cold water into the top which forces hot water to over flow into the brew basket. This continues until all the cold water drains into the heater tank. So the brew is matched volume per volume. UNLESS the tank was empty or not filled prior to brewing. Follow the brewing instructions from Bunn (on line for *FREE* download at Bunn.com)
Aloha, ukeboy57
Jun 17, 2014 | Bunn VPR Coffee Maker
How do I fix my bunn #053213cs from leaking from the bottom
Aloha, ukeboy57
Jun 04, 2014 | Bunn VPR Coffee Maker
I have a BUNN BT10-B Coffee Maker that started leaking. I believe it it is the gaskets between the top trank and the heater. How do I het these gaskets new?
The seal kit is available free of charge through Customer Service at Bunn. If you will call 800-352-2866 and have the model and date code from the bottom of your brewer and we will be happy to assist you.
Jan 16, 2011 | Bunn BT10B Coffee Maker
I have a Bunn BT10-B coffee maker. I need the two rubber parts to replace the old ones which is causeing it to leak.
If you will call 800-352-2866 with the model and date code, we will be happy to help you.
Jun 15, 2010 | Bunn BT10B Coffee Maker
When pouring coffee it drips, also doesn't keep coffee hot
Hi - Any time I've had an issue with my Bunn BT10-B, I go to the website, www.bunn.com , and go to their Customer Service area. They have been extremely helpful and informative.
Aug 16, 2009 | Bunn B10 Coffee Maker
Bunn BT10-B silicone washer
Yes, you can get a washer from your local Bunn repair shop. For a list of repair facilities in your area, go to www.bunn.com And yes, the heat is a problem, so you can't use just any washer.
Jan 24, 2009 | Bunn BT10B Coffee Maker
Bunn coffee maker bt10-b is tripping gfci. I had leakage from the tank, and after fixing, the gfci problem started. I suspect the zig-zag wire that is wrapped around the bottom of the tank has some water...
The heating element inside is problably broken. Thats what mine does. just disconnect it and you will see that cures your problem. You cannot buy parts for this. I have tried already.Junk
Jul 10, 2008 | Bunn BT10B Coffee Maker
Bunn BT10B Coffee Maker Logo
195 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
gbob59
evans_lloyd
Level 1 Expert
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
