Pioneer PRO-510HD 53" Rear Projection Television Logo
Posted on Sep 14, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi, i'm trying to fine tune my convergence on my pro 510 hd set.I have gone through the advanced convergence grid,but I can't get to all the sections of the grid.so some sections of the picture have bad convergence . Is there a way to adjust the con. from inside the set (without using the remote?) Any help would be great.
Chi Chu
Level 3:
  • Pioneer Master 8,457 Answers
  • Posted on Sep 14, 2010
Chi Chu
Pioneer Master
Level 3:
Answers
8457
Questions
0
Helped
2822734
Points
26282
No.Ur tv convergence is dead.The tv convergence board require changes 2 STK convergence ICS and some or all it resistors to solved the convergene problems.The shop,will cost u $300-350 for parts and labors.
  • woodyw May 21, 2012
    replace them by yourself. it costs only about $20 for the convergence chips.
How i adjust horizontal size and vertical size
To answer your concern, all you have to do is to change the setting of your aspect ratio on your TV.
Here is my suggested way to procede:
1. Apply 1080i signal, which should produce an oversized HD image on ColorStream1or 2.
2. Select an HD channel that is broadcasting standard 4:3 image, not wide screen.
3. Switch to the Service Mode ( Please refer to the above links). In the Service mode, press channel up/down to find the Adjustment parameters needed for the following steps.
4. Adjust HIT with volume up/down control for the image height to 22.5 inches.
6. Adjust WID for image width of 30 inches, (22.5*4/3)
7. Adjust HPOS to center the image.
8. Adjust PARA and TRAP to minimize geometric distortion.
9. Switch into Convergence mode and Adjust VLIN to get equally spaced horizontal grid lines.
10. Measure the length of the central grid lines and note the number of horizontal and vertical grid lines. This information is used to create an overlay grid.
11. Create the overlay grid on 40x25 x0.003 inch clear Acetate sheet, which you can get at the Art Supply store for under $2. Draw the grid with a fine line erasable pen. Draw vertical and horizontal lines through the center of the sheet so that the lengths are the same as the central grid lines. Now draw the grid so that it has the same number of lines as the convergence grid but are equally spaced, with the outer ones at the ends of the central lines.
12. Cut off about 1/4 inch from the right side of the sheet so that the sheet can lay flat against the screen, which is slightly less than 40 inches.
13. Put a reference mark on the TV frame 2.5 inches down from the upper left side of the screen.
14. Place the overlay on the screen so that the upper edge lines up with the reference mark. The overlay sticks by electrostatic attraction.
15. Use convergence controls to remove grid distortion and converge grid colors. Refer to the Anamorphic link for details.
16. Enjoy 1080i.
Other Comments:
I didn't realize I could create the overlay grid before placing the Acetate sheet on the TV screen, until I finished drawing the grid with the sheet placed on the screen. I added grid lines as called for in the procedure. I'm sure this method took much longer no only to draw the lines but some of them were difficult to see.
Part way through the convergence procedure, I became concerned that the image width was off since I did my screen adjustment with wide screen image. Thus, I decided to repeat that step with a 4:3 screen.
I confirmed the need to press 7 often to save results since after I adjusted one grid color without it, I accidentally hit a key that switched me out of convergence mode and when I switched back, all settings were gone.
Another mistake I made was not realizing that the cursor color determines which grid gets moved.
Projection TV Convergence problem
go to the Mitsubishi service center to solve your problem
2answers
Mitsubishi ws-65809 Convergence will not align correctly
You may also have a resistor burnt out for the convergence ICs.. They are all right in front of the ICs and will usually show browninsh if burnt up. If bad, replace the pair and maybe the ICs as well if they've failed again. If your new ICs fixed the lines so they'll move, then you may have problems with the centering magnets on the yokes of the crts. Dont move the yokes or magnets if you can help it, but look to see if some of the manufacturers glue broke free and let the magnet spin around the neck of the tube. If so, try to put it back where it was and then re-converge.
Samsung HCL4715W
IF THE CONVERGENCE IS NOT ADJUSTING COMPLETELY THEN IT PROBABLY NEEDS NEW CONVERGENCE IC's . ALSO CHECK OUT THE SHARPNESS OF EACH PICTURE TUB (CRT) THESE SET ARE NOTORIOUS FOR HAVING BAD CRT''s (WHICH ARE NO LONGER AVAILABLE).
DON.
3helpful
Pioneer 710 hd power/not turning on 10/12/08
When the set goes into protection BANG like that, without any intermittencies, usually the convergence ICs have gone out and need replacing. I recommend using the STK 392-180s, which are the stronger upgrade to the 392-110s used originally. You'll need 2.
Mr Bob
www.imageperfection.com
510-278-4247
bob at imageperfection dot com
HD issues with ws-55805
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
Hitachi 53uwx10b Convergence
The grid (called an overlay) is put in place to fine-tune one of the colors, usually green. Once one color is adjusted perfectly, the other 2 colors are adjusted to match the first color. For example, if the convergence data is completely erased, the tech will set up the overlay and align the green using to the overlay, and then align the red to the green and then the blue to the green. If the alignment is being done after replacing the convergence IC's because one or 2 colors are slightly off in the corners, the green is usually very close to perfect and the use of the overlay is not absolutely necessary. It is pretty easy to align one color using the outer edges of the screen itself. If you do need the overlay it can be purchased from any Hitachi parts distributor such as Herman Panson, Fox or Union Electronics.
Convergence issues
Drifty convergence IC's need replacing..located on center PC board......STK392-570...change them both for reliability...T.
4answers
Top Pioneer Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
