Question about HP LaserJet 3030 All-In-One Printer
Ghost Image I've had my 3030 for about 2 years now. Lately its starting adding to the printout a faint copy of the page but shifted down by about a third of the page. I've tried the cleaning option in the menu but it didn't improve. Can someone help please? Many thanks
    Problem Solver:
  • 13 Answers
The problem is related to either the toner cartridge or the fuser assembly. If you have changed the toner since the problem started, then it is the fuser. The fuser's job is to melt or "fuse" the powdered toner to the page. If the roller in the fuser is worn out, it will repeat the image as sort of a negative further down the page. The part # is RM1-0865 but this part should be replace by a certified technician.
Hope this helps!
Posted on May 16, 2008
Canon ir 3030 printout will be black
Verify charge corona, when you start a new copy, open lateral door when paper is in the right of drum, then look if the drum is full covered with toner.
Dec 05, 2014 | Canon imageRUNNER 3030 Black and White...
HP LaserJet 3030 Printing comes out light but copies are fine.
Have you calibrated your printer after changing ink cartridges?
Mar 19, 2014 | HP LaserJet 3030 All-in-One
After changing the ink catridges and resetting the drum fuse lately (note: it is known that the fuse will be blown off after certain number of prints but otherwise is in good condition), my Epson Acculaser...
The repeating image is a ghost image, and here is described what it can be. Probably if you solve this, you also solve the red-dot problem. If possible, I would suggest to replace the wiper blade.
Repeating images on laser printerThis likely means a faint ghost of the main printout at a distance equal to the circumference of one of the rollers or photosensitive drum.
Depending on where the problem originates, this could be a bad wiper (cleaning) blade, faulty corona, or incomplete fusing.
  • If the distance between successive images is equal to the circumference of the photosensitive drum, it is a wiper blade, erase lamp, or corona problem.A residual latent image or residual toner is sticking to the drum and not being properly cleared.
  • If the distance between successive images is equal to the circumference of one of the fuser rollers, then the fusing may not be complete due to damaged rollers or an incorrect temperature setting.
It is easy to determine where the problem is located: Interrupt a printout in mid-stride (where part of the paper is between the toner/developer and fuser. If the un-fused image has ghosting, it is a fault in the area of the drum
Jul 08, 2011 | Office Equipment & Supplies
My copies are full of black dots plus a ghost image.I have just inserted a new cartridge.
Tonor Cartridge seems to be faulty. Damaged or worn out PCR (which is behind the drum) is the cause. Try replacing cartridge or get the PCR changed
Nov 03, 2010 | HP LaserJet 3030 All-In-One Printer
Smudges and 'ghost image" down the page from true image,little used printer, not even a whole cartridge used
Laser Printers that printouts can be smudged usually means the Transfuser (the part that settles the toner onto paper) is not fully functioning or damaged. Simply replace it and it should be back to normal. However, these Transfusers are quite expensive. So you may be better off to get a quote for a new one if out of warranty.
May 21, 2009 | HP Officejet 5610 All-In-One InkJet...
Ghost image on Epson Acculaser C4000
Ghosting can be caused by several components: 2nd BTR transfer roller, Photoconductor Unit (PCU) or the Fuser unit. The most likely is the PCU contacts being dirty, caused by toner getting between them. Open the front of the printer (cover B) and lift out the photoconductor. Clean all of the metal contacts down the sides of the PCU with a cloth and wipe out any loose toner from inside the printer and give the contacts inside the printer on the R/H side a good clean. Replace the PCU and close the front cover.
Hopefully all will now be well, if not open cover A and clean the transfer roller on the inside of the cover. If problem persists you will need to get a Tech out to look further as without seeing the printer it is pretty hard to diagnose.
Good luck.
May 20, 2009 | Epson AcuLaser C1900 Printer
Ghost Image
mark165,
Are they both about the same age? Also have you recently added a device that is sitting near the monitors such a an external hard drive, printer, new speakers or power cord or cable next to or against the monitor cable? I sounds like EMI to me, shield the cable or plug of the offending devices into another outlet away from the monitors to test that theory, or having them on a separate surge protector should eliminate the noise you are reporting. Some go as far as adding UPS with line filtering (or conditioning) for the devices - you see it with home theater setups when the TV, computer, games and stereo are all plugged in the same outlets on the same home circuit.
randy320sgi
Jan 12, 2009 | Computers & Internet
Poor fax printout quality
I would say you have a bad drum / toner cartridge.
Stuff you receive with vertical lines is probably the sender's dirty scanner.
Nov 04, 2008 | Canon LaserClass 2060P Plain Paper Fax
Ghost images on my hitachi projection tv
i have a faint ghost image that is slightly blured just to the left of images. 50" about 6-7 years old, Driving me nuts, can't find manual.
Sep 05, 2008 | Televison & Video
Epson C1900 "ghost " images
Sounds like the transfer roller or the fuser unit may be faulty. Look at the fuser to see if the roller surfaces are dirty. If so, replace the fuser.
Jul 20, 2008 | Epson AcuLaser C1900 Printer
HP LaserJet 3030 All-In-One Printer Logo
129 people viewed this question
Ben Johnson
