Question about Samsung (SP0411N) 40 GB Hard Drive
S.M.A.R.T Capable but command failed pri master hard disk:S.M.A.R.T Command Failed press f1 to resume
  • 36 Answers
SOURCE: S.M.A.R.T Command failed
It means that the hard disk SMART monitoring system has detected problems serious enough to warn you of the growing possibility of hard disk failure. Sometimes a drive will last quite awhile after this first notification, but there is a good chance of imminent failure, in minutes, hours, days, or weeks. You should immediately look into installing a replacement drive.
You should immediately copy any important data off the drive, perform full backups, and limit use of it.
If you can install drives yourself, a new hard disk (especially Seagates) usually come with software to clone your existing drive to the new drive. Otherwise, a repair shop will be able to do it for you.
I recommend also purchasing a drive enclosure for your old drive. For whatever life it still has, it will be a good backup of your system.
Posted on Dec 06, 2007
imp_squared
  • 56 Answers
SOURCE: "primary master harddisk S.M.A.R.T Command failed , press F4 to resume"
More information is posted here: http://www.fixya.com/support/t286025-s_m_r_t_command_failed
It is recommended to do a hard drive backup as soon as possible. And even replace that hard drive as soon as possible. Before full physical failure.
Posted on Aug 14, 2008
MUKHTAR
  • 2017 Answers
SOURCE: pri master hard disk: S.M.A.R.T. command failed
there is problem with hard drive kindly replace it.
have a nice day dont forget to rate pls.
Posted on May 11, 2010
bronk50
  • 27725 Answers
SOURCE: When I was trying to
this is a warning your hard drive is about to fail
you could run the check disk utility
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive
hope this helps
Posted on Dec 01, 2010
mariolands
  • 2296 Answers
SOURCE: when i stared my pc it massage that primary master
When you get that error it means one of these two: the hard drive is dying or it doesn't support the S.M.A.R.T. technology. If you are sure it's SMART capable, then it means it's dying.
You can download testing tools for HDD and test your hard drive. There are a few tools available on Hiren's Boot CD, you can download the CD image from Hiren's website: http://www.hirensbootcd.org/ under Download menu on the left side.
Posted on Dec 10, 2010
How do I back up my computer when this message appears Pri Master Hard Disk : S.m.a.r.t. command failed Press F2 to resume
restart computer and press delete button and in BIOS menu go to advanced menu set S.M.A.R.T disabled.
Jun 10, 2012 | Sony VAIO PCV-RZ44G PC Desktop
When i boot it always says "hard Disk: S.M.A.R.T. command failed press f1 to resume"
this means the hard disks start up self check has failed. press F1 then backup all data from your pc to another drive.
You will then have to replace the drive.
Feb 28, 2011 | Samsung (SP0411N) 40 GB Hard Drive
When I was trying to boot the system the following error is getting flashed on my screen and asking me to press F4 to continue. pri master hard disk: S.M.A.R.T. command failed
hope this helps
Dec 01, 2010 | Samsung (SP0411N) 40 GB Hard Drive
Pri Master Hard Disk:S.M.A.R.T. Command Failed
You do not seem to have a smart capable hard drive, disable the setting in the BIOS by pushing F2
Jul 05, 2010 | Computers & Internet
Pri master hard disk: S.M.A.R.T. command failed
May 11, 2010 | Samsung (SP0411N) 40 GB Hard Drive
Whenever I boot I get the followoing msgs- pri master atapi cd rom primary slave ide hdd primary salave hd smart command failed no 1de master hdddetected press f1 to continue-- then okay But sometimes...
please change the wire connection in your pc from CD rom to HDD so that HDD become primary master and cd rom become primary slave, check after this, and if still get error check your IDE cable, and for the smart command fail may be your HDD didnt support smart feature, so disable this from advance setup
Aug 21, 2009 | ASUS MB P5KPL-CM C2D LGA775 INTELG31 ICH7...
http://www.tech-forums.net/pc/f77/startup-pri-master-hard-disk-s-m-r-t-command-failed-114514/
sounds like your hdd is failing, backup data by using external enclosure and get a new hdd.
try the solution in the link, it may get your computer to boot up.
Dec 20, 2008 | Averatec 3200 Notebook
American Megatrends is telling us our Pri Master Hard disk: S.M.A.R.T. is bad, backup and replace.
By questions and answers from above, is this telling us to replace hard drive?
Aug 14, 2008 | Samsung (SP0411N) 40 GB Hard Drive
Dec 06, 2007 | Samsung (SP0411N) 40 GB Hard Drive
Samsung (SP0411N) 40 GB Hard Drive Logo
802 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
