Frequent restarts My computer crashed a few days back and for some reason my system recovery funtion was not working (and still isnt) so I reloaded windows...this has caused nothing but problems. 1) i think the old, corrupted version of windows XP is still running because when I start up I have to select one of 2 different XP options so Id like to somehow get rid of the corrupted version 2) ever since this happened my computer will restart itself when it becomes too stressed. I thought this might be because of a problem with the heat sink or fan so I opened it and put a fan up to the inside to cool it...the problem still persists... 3) since reloading windows, I plugged my ethernet cable into the back and it doesnt recognize that it is even connected to a network, Ive tried the connection wizard and all that but still nothing. Ive lived in 3 apartments in 3 years and everytime i move i just plug the cable in and its good to go... If anyone can help me with any of these problems i would appreciate it.
  • Dung Nguyen May 11, 2010
    make and model of PC. Did you install all the drivers ?
  • 67 Answers
1 problem. if you can, take the harddisk and format it complety.
but if you have a rocvery system on it you may should consider if it's a good thing.
please let me know and I will help you.
2. maybe I'm stupid but check if the CPU fan is working problely. consider installing a bigger or overclock the CPU fan. I can tell you how to.
3. the formatting and reinstalling of windows should fix that problem.
hope that my solution helped you forward.
CS.
Posted on May 15, 2008
My computer crashed, how do I recover my NTI Backup Now EZ program? My computer can't find the NTI setup.exe.
Many people confuse system back-ups with system restore and/or recovery programs. They are very different. A backup makes a copy of selected (or all) files and stores them to a disc, tape, hard drive, or other device that will allow you to protect your files in the event of data loss. Say you accidentally delete an entire directory instead of a single file. Your backup would allow you to re-load that directory. System restore/recovery files are used in the cases where you either want to reload the computer back to a certain condition (factory restore), or need to completely recover your computer in the event of a crash. These types of files usually need one of two things to work. If the recover/restore software was OEM manufacturer supplied, there may be a BIOS routine that, using a hotkey on boot-up, will allow you to access the recovery/restore file. If it is an aftermarket program like your, recovery/restore files usually need to create a bootable USB or CD/DVD that can be inserted on boot-up, and then the files on that device will perform the recovery/restore. If all you have a a system backup, you may have to reinstall the operating system, drivers, and then the backup software. After that, you can use you backup file to recover your remaining programs/data.
Sep 29, 2015 | NTI Computers & Internet
My computer keep restating randomly
If you are using Win XP,Win 7 the most obvious problem is that there is a system crash taking place, go toDesktop and then My Computer ->Right Click on it and select properties->Advanced System Setting->IN the System and Recovery click the Settings button->Then in the resultant dialog box if in System Failure section Automatically restart is check then uncheck it the next time it will not automatically restart but show you the reason of restarting, and depending on that you can sort out the problem, most probable reason may be Failure or Unstable Driver's or probably Hardware fault like overheating of CPU etc, or a failing component
Hope it helps !
Jan 05, 2013 | HP Compaq nc6400 Notebook
I wanna know how to reset my laptop back to factory settings Gateway windows 7 model# NEW90 NV59C
usually if you dont get a recovery disc with your laptop you would then use those discs to reload the system from scratch. the other is that you would have to create recovery discs as soon as you started using the laptop. if the sales person did not make you aware of it then he is a very bad sales person. the other solution would be to go to the web-site of the manufacturer of the laptop and under the support section or drivers and downloads you will find drivers and recovery disc image or iso or a self extracting file which you will then have to copy to disc then use the created disc to reload the system
Feb 28, 2011 | Computers & Internet
Hi there, A girlfriend of mine has a 2nd hand Toshiba Tecra A5, which unfortunately crashed after being hit with a virus. The person they got the laptop through was going to provide them with the...
if you have another operating system disc, you can try to use it to reformat the hard drive and reinstall the operating system. you can also try to restart the laptop and press F12 a few times as it tries to restart to get to the One Time Boot menu to see if it has an option to do recover/restore the computer to factory settings. if none, try to restart it and press F8 a few times as well as it restarts to get to the advanced options menu and see if you can find a utility to restore to factory configuration hope this helps
Jan 26, 2011 | Computers & Internet
My computer turns off and on again for a few seconds. (this time it will bootup) when i pressed the power button. i already change the ram to 1gb but the problem still occurs. What can i do to fix this...
It may be owe to software problem 1, the virus "shock" virus attack will prompt system will automatically start in few seconds. From the remote control you Trojan program all the activities of the computer, including let your computer restarts. Remove viruses, trojans, or reshipment system. 2, the system files damage system files destroyed, as the KERNEL32. Win2K DLL Win98 features, the font list below such basic execution system files destroyed at startup, system will therefore cannot finish initializing and forced the restart. Solution: cover installation or reinstall it. Hardware problem: 1.Chassis power is not enough, dc output is pure, the dynamic response sluggish. Users often ignored or assembling businessman, using cheap price of power supply, so is the largest system of automatic restart suspicion. (1) the power output power shortage, when run large 3D gaming occupy CPU resource of software, the CPU needs power supply, power is not caused by overload protection, stop the power output. After the output power to stop, load, reduce power restart. Due to the protection of the recovery/time is short, so we are hosting automatic restart. (2) power dc output is pure, pure dc power supply of digital circuit requirements, when the power output of too direct, the harmonic content will result in digital circuits, performance is often work to crash or restart. (3) working load of the CPU is dynamic, on the current requirement is dynamic, and the dynamic response speed quickly. Request Some of the poor quality power dynamic response for a long time, could also lead to crash or frequent restart. (4) high-end graphics update equipment (large disk/video card/equipment (increased), after the hard disk) / burners, power supply of original beyond rated output power will cause the regular crash or restart. Solution: now in high quality high-power computer power. 2.The memory chip thermal stability, incorrect or damage to restart the system memory problems to restart the system of risk. (1) the poor thermal stability of memory, boot can work normally, when the memory to a certain temperature, temperature is can not work normally, which leads to crash or restart. (2) memory chips, slightly damaged, also can pass on self into the system, when the operation can be some big software throughput will restart or crash. Solution: replace memory. (3) memory of CAS value too small can also lead to instability caused by system memory, automatic restart. General had better use the default Settings, don't roll change yourself. 4.The CPU temperature exorbitant or the cache damage (1) the CPU temperature exorbitant often causes protective automatic restart. The basic reason of high temperature is due to poor cooling chassis, CPU, the CPU is undesirable reasons: the heat radiator thermal conductivity low, radiator material with a foreign body between CPU interface (1) for quality assurance, fan speed is low, the fan and radiator dust too much, etc. And P2, P3 motherboard CPU temperature probe damaged under the mp4 or within the CPU temperature detection circuit on the mainboard damage, the BIOS BUG in a special conditions of temperature, the CPU CMOS setup to protect low temperature, etc. Can also cause protective restart. (2) of an internal CPU, level 2 cache damage is CPU common fault. The extent of damage, or can start, when running into the system, the software (some throughput big media player, games, 3D graphic) will restart or crash. Solution: in the CMOS setup of shield (L2) or level 2 cache cache (L1), 1 or replace the CPU. 4.AGP display, PCI CARDS (nics), cat restart automatically (1) the external card or poor quality work not standard, AGP/PCI bus signal misoperation cause system RESET to restart. (2) and graphics, loose network system may cause restart. 5.Parallel, USB access is serial, fault or the incompatibility of external devices restart automatically (1) the fault or not compatible with the parallel damage, such as printer, a foot of short-circuit, USB equipment damage of short circuit, signal level sutural definition, opaque, etc. (2) hot swaps external devices, shaking, cause signals or power instant short-circuit. 6.Mainboard failure In case of automatic restart motherboard is rare. Generally RESET circuit are associated with a fault, Socket weld is empty, slots, contact undesirable, Individual chip, capacitance elements such as damage.
Jun 23, 2010 | Acer Aspire 4315 Notebook
Recently crashed. reloaded with original recovery
After you restore your computer, you must also reinstall the drivers for things like your wireless receiver. This is found on the Drivers disk, also gotten with your computer. Follow directions to recover all drivers are found on the disk.
Dec 13, 2009 | Toshiba Satellite A60 Notebook
Error : 0x400110020000100A
Look carefully at the hard drive that you are replacing. When you take it out of the [mine is a Compaq f750us] computer you might see, for want of a better term, a "STRETCHER" attached to the contacts/connectors, remove it. Put it on the NEW hard drive, put hard drive into computer. Try it again. I did and I did NOT get the "error" code! Why because the HD is now CONNECTED...touches the contacts..
Jul 22, 2009 | HP Pavilion DV6700T Notebook
Sony All in one desktop Clicking/Screen doesnt illuminate etc
Because it does this a few times and then boots the day may some when it wont give you even one chance. Try Doing full system restore after backing up your personal stored data.Dont waste any time Your boot sector has a problem maybe from a virus, and I have heard some viruses act slowly so you will eventually crash
Mar 10, 2009 | Sony Computers & Internet
Recovery...
You don't want to do a eRecovery, eRecovery is used to format the hard drive and install the drivers like you just got it. You want to do a system restore.
1. Click on the Start bar to the bottom left of your screen
2. Select All Programs
3. Select Accessories
4. Select System Tools
5. Select System Restore
6. Click Next
A calender will come up, select the day it was working, probably the day before, click next. After this the computer is going to restart. All done.
Have a nice day!
Dec 22, 2008 | Acer Aspire E380 - Athlon 64 X2 4200+ 2.2...
Re-Loading Software
Since they installed a generic copy of xp, there are none of the sony installed add-ons present on the computer. go here to view the available downloads for your system provided by sony, you will have to select the "EVERYTHING" tab to see the giga downloads if it does not load there.
Otherwise you will have to contact sony for a recovery disk specific to your system.
Oct 08, 2008 | Sony VAIO Digital Studio PCV-RZ22G PC...
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
