Question about Apple M9034LL/A Keyboard
Apple Pro keyboard model #M7803
Basically, the number lock key will not work allowing the number keys to work. All the rest of the keys function. Is there any combo command keystroke or anything that will get this to work? I'm using a Power Mac G4
I was researching this same problem, and just read on another site that you may be able to use shift-clear, which worked for me. good luck!
Posted on Jun 04, 2009
Unlock number lock
On a laptop, the "Num Lock" key has a function slightly different than the one it performs on full-d desktop keyboards. Activating "Num Lock" on a laptop usually transforms a set of central keys, including many letters, into number keys, allowing typists used to entering numbers on a keypad to type efficiently. While on desktop keyboards "Num Lock" usually has a dedicated key, on laptops it often shares a key with another function on MacBooks, for example, it shares the "F6" key and you must hold down the "Shift" or "Fn" key to activate it.
Look for the "Num Lock" key on your laptop's keyboard. This is usually near the top of the keyboard. If the key says nothing on it except "Num Lock" if that's the only function the key performs you can just press it to activate the lock; a light will probably go on somewhere to indicate that "Num Lock" is on. If the key has multiple functions, you'll have to hold down a different key while pressing it. Hold down "Shift" and press "Num Lock" if the writing saying "Num Lock" appears above some other writing on the key, the way various symbols appear above the numbers on the keyboard's number row. Hold down "Fn" and press "Num Lock" if the writing saying "Num Lock" appears in a different color often light blue that's shared by the "Fn" key.
Feb 28, 2013 | Acer Aspire Computers & Internet
I am not able to work with my keyboard function keys and num keys and function keys . but the the touch pad key is onlyworking .please send a solution to unlock the keyboard. hp pavilion g6-2102tx
Examine your keyboard to ensure your "Number Lock" key is not activated. This activation is indicated by the key being lit up. If the key is activated, press it to deactivate the lock. The number lock key will deactivate an entire segment of your keyboard
Start, click Run, and type regedit to open the Windows registry editor. In the registry, open the below folders.
HKEY_CURRENT_USER\
Control Panel\
Keyboard\
Within the keyboard folder, you should have a string value named "InitialKeyboardIndicators" with a value of 0, 1, or 2. Below is the explanation of each of these values.
0 = Num Lock is turned OFF after the logon.
1 = Disable Num Lock.
2 = Numlock is turned ON after the logon. Hope this helps.
Dec 10, 2012 | Computers & Internet
My functon keys are not working properly
Have you tried going into System Preferences/Keyboard, and see if there is a checkmark next to 'Use all F1, F2, etc. keys as standard function keys.'
May 25, 2012 | Apple MacBook Pro Notebook
Cursor and keys are unresponsive tryed 2 check if it was number lock witch its not
There has been a known issue with the first key (any key) of a Macbook Pro, not responding when typed and Apple appears to have addressed this with this software update for the Macbook and Macbook Pro:
Run the Macbook Pro Software Update v1.1 and the Macbook, Macbook Pro Keyboard Firmware update v 1.0 per this link:
Keyboard Issues with Macbook Pro
Let me know if this helps.
Regards,
-Mactechtrainer
Mar 24, 2010 | Apple MacBook Pro Notebook
My Logitech EX110 wireless keyboard has no light indicators for CAPS LOCK and NUM LOCK. Should it have those indicators?
Your EX 110 receiver has 3 indicator lights (LEDs) that display the status of the Caps lock, Function key, and the Num lock during normal operating mode. These lights will also flash when the connect button on the receiver is pressed.
LED A: Indicates that the Caps Lock (Capital lock) key is on when lit.
LED F: Indicates that the F keys are in Standard F Keys Mode when lit and in Enhanced F Keys Mode when the LED is off.
  • Your EX 110 keyboard has an Enhanced F Keys Mode for F keys that provides additional functions you can program. See Knowledge Base article 9526.
LED 1: Indicates when the Num Lock (Number lock) key is on. This function allows the number pad to produce only numbers
Mar 27, 2009 | Logitech EX110 SP CORDLESS Keyboard/Mouse
Cap Lock on or off
Feb 11, 2009 | Logitech Cordless Desktop EX110
NewTouch Keyboard 200 function keys do not work on a MacBook Pro running 10.5
Normal 0 Go to Control Panel.
1. Click on Keyboard.
2. When the Keyboard Properties come up, CLICK on Key Settings.
3. Then set up the keys by selecting the Key to be changed.
Hope this will help some. Bud
Oct 10, 2008 | Logitech USB (967199-0100) Keyboard
F keys don't work on a micrpsoft keyboard 1000 wireless
Many of the wireless keyboards and Natural Keyboards from Microsoft have the F-Lock key.
Here is a description of what the F-Lock does from a 3rd party website (http://www.mvps.org/jtsang/flock.html)
F Lock Key
The F Lock key on the Microsoft Keyboards is a relatively new concept facility for Microsoft Keyboards. Introduced with the Office Keyboard and used in later keyboards, it essentially allows keys to do more than one operation. The F Lock key, depending on its state, will allow either a function key's "normal" operation or a new "enhanced" operation. The initial state of the F Lock key is "off", and in this state, the function keys use their "enhanced" operation.
The F Lock key is a hardware switch in the keyboard. Its state cannot be controlled programatically. Its default condition is "off". As a result, whenever the keyboard is reset, or loses power, the F Lock key will always be in an "off" state.
For some, this is not a desirable default; some people want "normal" function key operation.
Jun 15, 2008 | Computers & Internet
I can't quit a program using apple key and letter Q and more problems
Hop into your system preferences and make sure you don't have anything turned on in Universal Access. If you don't, it's probably a bad corner of your keyboard there.
Nov 10, 2007 | Dr. Bott Crywolf CoolMac Keyboard
Apple M9034LL/A Keyboard Logo
1,238 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
