Question about Philips MCD288/37 DVD Micro Theater System Theater System
Philips MCD177 Micro Theatre wont read disks, have cleaned lens very carefully. Wont spin the dvd either but I can see the laser reader going off and on. No Disk msg is displayed. Radio and usb go no prob. pete paynta@yahoo.com
4 Suggested Answers
bluenadas
  • 203 Answers
SOURCE: Phillips Home Theatre mx5060d no reading disc
Your pickup is bad. Take it to a servicer for replacement or try to find one online.
Posted on Jun 08, 2007
SOURCE: HTS 3300 - No Disk Error
i had the same ploblem sometime last year and all i did was to put a cleaning disk(the ones with a cleaning brush on) in it a couple of times...and it works fine since then!
Posted on Jan 04, 2009
SOURCE: my philips 3100 home theatre system will play
Change the motor disc spindle
Posted on Sep 09, 2009
My disc reader motor wont spin. it refuses to read the disc
Hi,the unit needs to have the laser reader lens cleaned but DONT use regular rubbing alcohol.
Get pure stuff....the rubbing type leaves a glare on glass and plastic lenses.
Also ,the chrome rails that the laser moves along need to be cleaned and lubed with liquid silicone.
This method clears read problems most of the time.
when a disk reader refuses to spin, sometimes it might be from the motor mechanism that allows it to spin when you insert a disk inside the disk reader is damaged that's might be the reason it does not spin.
You can check both the lens and the mechanism to be such which needs to be replaced.
Take care.
Oct 08, 2010 | Nintendo GameCube Console
Tip
My player does not read disks
When you get no disk error, that is usually because of a problem with the optical laser lens that is dirty, faulty or opaque, and will start operating on certain disks better than others.
In that case you will hear disk spinning, whirring and clicking, but the TOC (table of content track at start of CD/DVD will not be read, therefore the error.
Whe this problem is starting you may be able to read only CD, DVD or Blue ray, or for example only DVD-R and not +R , or only to read and not to write and so on. After more prolonged usage , often the unit goes losing the rest of functions, and ends up not reading anything at all.
If instead there is no noise, and disk does not spin at all , then there is a faulty motor, or the motor micro-switch is bad. This situation is far less common than the lens problem.
Try first using a CD/DVD or Blue ray lens cleaner disk to clean the lens. If that does not work you will need to disassemble the drive , and clean lens directly with q tips and isopropyl alcohol, or to replace the CD/DVD lens, or the whole drive unit.
on Apr 21, 2009 | Philips Magnavox DVD/VCR Dual Player
DISC WONT READ
Sep 08, 2009 | Audio Players & Recorders
Dvd player always says no disc . will not load
That happens because of a problem with the optical laser lens that is dirty, faulty or opaque, and will start operating on certain disks better than others.
Whe this problem is starting you may be able to read only few CD, DVD. After more prolonged usage , often the unit will start losing the rest of functions, and ends up not reading anything at all.
Try first using a CD/DVD cleaner disk to clean the lens. If that does not work you will need to disassemble the player, and clean lens directly with q tips and isopropyl alcohol, or to replace the CD/DVD lens, or the whole drive unit.
Aug 28, 2009 | Philips DVP3962 DVD Player
The problem is i cant play mp3 or DVD s in my philips dvd player when i insert sometimes it plays but sometimes it says LOAD but doesn't play.product code is philips dvd dvp3268
When the unit does not load any disk, that is usually because of a problem with the optical laser lens that is dirty, faulty or opaque, and will start operating on certain disks better than others.
Jul 21, 2009 | Philips DVD625 DVD Player
Wont recognise any disk
May 04, 2009 | Televison & Video
Not reading DVD and CD's :-(
May 01, 2009 | Philips HTS3450 System
Latitude C840 wont reconize optical drive in BIOS
Try first using a CD/DVD or Blue ray lens cleaner disk to clean the lens. If that does not work you will need to disassemble the drive , and clean lens directly with q tips and isopropyl alcohol, or to replace the the whole drive unit.
Apr 25, 2009 | Dell Latitude C840 24X CD-R W/ DVD Combo...
Dvd player wont read disk
If when you insert the disk you hear a whirring and clicking noise, CD spins, and does not read, then that is a problem with the DVD lens.
The DVD lens try to focus on the DVD track, by moving lens pickup and spinning the disk, but cannot read the tracks because the lens is dirty or defective.
Try first cleaning the lens with a DVD cleaner disk. And also if you can see the lens from the outside try blowing some canned air on it.
If this still does not help, then the lens pickup may be faulty, in this case you often replace the whole DVD drive unit inside the DVD player.
Apr 07, 2009 | Televison & Video
Reads cd's but not dvd's
Feb 21, 2009 | Philips Magnavox MPD845
Philips MCD288/37 DVD Micro Theater System Theater System Logo
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
