Question about Samsung SMH8165B Microwave Oven
Fan won't shut off - Samsung SMH8165B Microwave Oven
Vent blower won't stop
I had the same problem with the fan not wanting to shut off after the repair. Once I set the clock though I was able to push the button to shut the fan off. So try setting your clock first and see if that helps.
May 07, 2013 | GE Profile Spacemaker Over-the-Range...
We have a kenmore ultra wave microwave and the fan has stopped working and now the microwave won't operate. Any suggestions?
see this causes and fix it .God bless you
Exhaust Fan Motor If the exhaust fan does not run the fan motor might be bad. Remove the fan motor from the microwave oven and see if the blades can be turned by hand. They should turn very freely, if they're stiff the fan motor will need to be replaced. The fan motor can also burn out. To test this use an Ohm meter. The motor should have continuity. If it does
Thermostat If the microwave exhaust fan is not working the thermostat might be defective. The thermostat senses the air temperature and turns on the fan as needed, if it's defective it won't turn on the fan. Watch our video on testing thermostats.
Main Control Board If the microwave exhaust fan is not working check the exhaust fan motor and wiring. If they are good the main control board might be defective.
Oct 02, 2012 | Microwave Ovens
Kenmore microwave fan won't shut off
The fan is required when the microwave is running, cools the magnetron. The problem may be in one of the interlock door switches, it is to complicated to go through the steps and the testing requirements, plus the alignment is critical.
Mar 22, 2012 | Microwave Ovens
Oven won't shut off
One of the door switches is defective, caused by a build up of food particles or normal ware, to correct this a professional will need to identify the problem and replace it.
Mar 07, 2012 | GE Advantium 120 Convection/Microwave Oven
GE Over range microwave model JVM1443LK01 This started a couple days ago. After removeing something from the microwave and we shut the door, the fan started up. The fan will run as long as the door is...
I would check the door switches for a faulty switch. If it were condensation on the control panel. I would think it would have dried out by now unless it has damaged the control board.
Mar 22, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave works, but not the fan. Then shuts off
The internal cooling fan (blower) is faulty and will need replacing.
Dec 28, 2009 | RCA RMW729 Microwave Oven
Cooling Fan stays on until the door is open
May be a sensor or thermostat for the fan thats faulty therefore it runs all the time.
Sep 16, 2009 | Jenn-Air JMV8000 Microwave Oven
FAN WONT SHUT OFF
My Kenmore microwave oven fan has been turning on and off, almost every hour. Sometimes 3 or 4 times in one hour. It's very random. Model No. 721-80593401 Serial No.503TA03208
Please help!!!
May 31, 2009 | Kenmore 62642 / 62644 / 62649 Microwave...
Samsung SMH8165B Microwave Oven Logo
583 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Henry  Thomas
Henry Thomas
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
