Question about Craftsman Garden
I just acquired a Craftsman weed **** , #00166D. It runs fine but there is no line. How do I take the string holder apart to install the new line?
    President:
  • 1,851 Answers
Turn the nut looking piece COUNTER CLOCKWISE
Posted on Sep 14, 2010
Husqvarna weed eater starts , but blows alot of smoke & then stalls out
Rod, Carb. may need adjusted, try loosening gas cap and start to see if cap vent plugged, there is a in tank fuel filter that you could fish out and remove to see if it is plugged. If still not running remove muffler and clean spark arrester screen, if screen plugged the trimmer will do this.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
String Trimmer Starts Then Stalls
My String Trimmer Starts But Won Stay Running
Craftsman Trimmer starts then dies
How to Clean Spark Arrestor Screen on Small 2 Cycle Engine Quick Fix
How to Clean Two Cycle Two Stroke Engine Carburetor
Sep 06, 2012 | Husqvarna 128 LD Weedeater
I have a craftsman 32cc weedwhacker trimmer and its brand new and it hasnt started from day one it isnt getting any spark at all
If you have spark problems, remove the wire and then remove the plug, reattach the wire and ground the plug to the engine and pull the string, you should see arc and hear it pop, if not, take the plug to another piece of equipment and remove that equipment's plug wire and attach it to the plug from the weed ******* and then ground it and test it. If still no spark, then plug bad, if plug then the weed ******* has a problem with the spark plug wire or the ignition coil.
If you have spark at first test, then the problem with the weed ******* is somewhere else.
Aug 09, 2011 | Craftsman 25cc Gas Line Trimmer
Weed wacker started and wacked some weeds then the strings stopped rotating but engine very strong
pull off string housing check that all parts are there. run machine and see if shaft is turning-- if it is then put housing back on sometimes I havent put the housing on properly. if shaft is not turning. then repair is needed. or just buy a new one. cost of repairs on this stuff is not worth the cost. unless it's a profesional grade machine..
Jun 18, 2011 | Craftsman 27cc 2Cycle Full Crank Curved...
Replace fuel and primer line on craftsman 358-798470EM string trimmer
Try searching Craftsman Weed Trimmer fuel line on this site for numerous responses to this problem.
Aug 07, 2010 | Craftsman Garden
How do I replace the string on a Craftman Weed Eater model number 358.791030?
how do you fix it when the pull rope breaks ? how do you take it a part to puted a new rope on ?
May 15, 2010 | Craftsman 25cc Gas Line Trimmer
I am trying to change the string on a Craftsman Weed Trimmer
Usually you "Push in" as you turn them. Or...there is a knob with a male thread shaft screwed into place holding it all tight. Hold the spool steady as you try to turn the knob off. Or...there is simply a "nut" to take off. But for the most part the newer wacker spools usually just "push in and turn/twist" out. Simple. to reinstall it or replace it with a new one simply push and twist it the opposite removal direction. FYI most lines can be manually "rewound/refilled" by yourself and reused over and over until they really wear out. There are little tricks to doing a rewinding but it isn't anywhere near difficult to do...or learn. Usually the price of a replacement spool is 5 times the cost of rewinding them yourself. Comon its easy! If ya want I'll help ya thru it.
May 10, 2010 | Craftsman Garden
Trying to replace the head of the weeder with a new line system,
I cannot get the head of my craftsman 791050 head off to replace with a new line system
Aug 01, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Need to add new string to a weed eater xt 12
    For manual go to;
    http://www.poulanpro.com/poulanpro/manualSearchPrepare.do;jsessionid=332BA6FC1EA2792C79A0A463204716AA
    Preparation Instructions
  1. Press the lock and rotate the spool counter-clockwise.
  2. Remove the locking ring if your weed eater has one.
  3. Take off the automatic feed button.
  4. Wipe away any debris.
  5. Push down on the spool to release the locking tabs.
  6. Remove the spool from the chamber. Restringing the Weed Eater
  7. Feed the line into the lower deck, traveling the line in an upside down J fashion (almost like sewing on a button but do not tie off the line). This secures the internal end of the line.
  8. Wrap the line following the directed arrows. Do this until it wraps to the depth of the chamber.
  9. Secure each of the lines into its own upper and lower deck grove settings.
  10. Install the spool back into its chamber.
  11. Pass the lines into the left and right holes and snap the spool into place.
  12. Once the spool is in its sleeve and fed into its left and right eye holes, pull both ends simultaneously.
  13. Reinstall the locking ring if necessary.
Do it yourself repair: common repairs for a weed eater Amazingly, weed eaters are one of the simplest yard tools to take care of. One of the first things you should do to keep your weed eater in good condition is to clean it. It is important not to clean your weed eater with water or gas, which may destroy the engine. The best, and easiest way to clean it is by blowing off dirt and grass with an air compressor or a leaf-blower after every use. The next most important thing to maintain on your weed eater is string. When the string gets low you can remove the lower part of the head (the part that the string comes out of) by pushing in slightly and turning the head counterclockwise. Cut the new string no shorter than 6 inches or the weed eater will not advance the string properly when in use. Thread the string back though the guides, making sure to follow the arrows on the guide. If the string is not put through the guides the right way, the head may pop off during use. Next, replace the bottom of the head by pushing and turning clockwise. You can totally skip this step by buying a string replacement cartridge. Though it is much more expensive, it saves you the trouble of having to restring your weed eater yourself. window.google_render_ad(); If you find that the head of your weed eater is worn on bottom or hard to get off to replace the string then it is time to replace it. This can be done very simply by unscrewing the two screws at the top of the head and slipping it off. Then, just slide the new one on and tighten the screws. After a few months of use, you may find that your weed eater is losing power or that it is making a strange lower pitched noise. This may be caused by a dirty filter. To check, unscrew the knob or wing nut on the carburetor. Inside you will find a small square screen, this is the filter. If the filter is gray or black then it is time for it to be cleaned. The easiest way to clean it is to blow it out with an air compressor. It can also be washed with plain water, but you must let it dry before placing it back into the carburetor. Once the filter is white or only light grey it is ready to use again. Always make sure to mix the gas and two-cycle oil in the proportions that are listed in the weed eater’s manual. Never use anything but two-cycle oil, normal car oil will not work and will damage your engine.
Jun 01, 2009 | Garden
Garden Logo
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
