Question about Miele 24 in. G656SCi Plus SS Built-in Dishwasher
Hi, my miele G892 SCU PLUS shows a red indicator light by salt (P C). I don't know what that means and how do I fix it?
gwshaw71
  • 83 Answers
SOURCE: Miele G638 CS Plus - Salt PC light flashes and will not run
have you added salt to unit?If so then you have a water intake problem or unit is oversudsing.
Posted on Dec 08, 2007
  • 4 Answers
SOURCE: Miele G892 SC Touchtronic
check drain pump impelar is free, it can be found under the non-return valve below filter. also make sure drain hose and S trap is clear.
Posted on Apr 03, 2008
SOURCE: G892-SC Miele water intake/drain light blinks
The intake/drain light blinks. How do I fix this problem?
Posted on Sep 18, 2008
  • 122 Answers
SOURCE: miele g892 and just like everyone the red light
The red light tell you there is a fault. You have to read the fault code and it will give you a general idea of the problem - to do this you have to enter the service mode of operation - close the door and turn the dishwasher on.
The Start/Stop light must be blinking. If the Start/Stop light is not blinking, press and hold
the Start/Stop button for at least 3 seconds to exit the cycle. The Start/Stop light should now be blinking.
Press and hold the Start/Stop button while turning the dishwasher on. Release the
Start/Stop button and immediately press it 2 more times. Flashing Intake/Drain and
Salt lamps and a lit Rinse lamp indicates successful accessing of services mode
Fault codes
F00 Pots & Pans Lit
F01 Sani Wash Lit
F02 Normal Plus Lit
F03 Normal Lit
F04 Economy Lit
F05 Rinse & Hold Lit
F06 Pots & Pans Lit
F07 Sani Wash Lit
F08 Normal Plus Lit
F09 Normal Lit Flashing
Posted on Sep 23, 2009
  • 177 Answers
SOURCE: Have Miele G653 SCVi plus. We have inlet/drain flashing red light
Sounds like something is caught in th drain pump as the unit has to drain first before anything else happens. Remove the filter and the non return valve which is under the clip in the sump of the unit. In the manual it shows you this. Make sure the drain pump is free of any foreign particles like broken glass. Then start the unit again so it goes to drain without the non return valve in place. This will then throw out any foreign particles as well.
or it could be the drain pump is activated all the time which is the noise you hear as there is a flood in the base of the unit which activates the float switch and constantly activates the drain pump until the water has gone. Isolate the unit at the power switch and remove the bottom panel under the door panel. Dry up the water as best possible with a towel. You will see the float at the front. Run the unit again and check for any water leaks. You may just have over sudded the unit with too much detergent. Only use 2 teaspoons of powder. To start with while testing don't use any detergent. Good luck
Posted on Mar 02, 2010
Testimonial: "Thank you for your excellent advice, the machine was flooded in the base when the panel was removed. "
Our water is soft and does not require salt. how do we stop the red light
I think it might depend on the model # and it should be in your manual.
Example for a G858 SCVI plus instructions (without pictures) are;
Bypassing the salt indicator
If your water is soft (below 8 gr/gal) the
salt reservoir should not be filled with
salt. The indicator will remain lit and
should be disregarded or bypassed.
Remove the salt reservoir cap.
Looking into the salt reservoir, you will
see the top of the float chamber on the
right hand side, a.
Using a screwdriver, carefully pivot
the float chamber towards the center
of the reservoir.
Using needle nose pliers, pull the
cap, b, off of the float chamber, and
remove the float, c.
Replace the float chamber cap, push
the chamber back into its upright position,
and replace the salt reservoir cap.
The "Salt" indicator should no longer be
lit.
Feb 17, 2013 | Miele Premier-Plus Built-in Dishwasher
On my Dishwasher Miele G638 Plus, a red light shows up and it says PC salt, I dont know how to solve this, please help me.
Hi - its possiblily the following issues if its flashing rapidly then the electronic module maybe faulty. The other possibilties are the float switch inside the salt conatner is jammed or the reed switch for the float switch in the salt container does work.
May 30, 2011 | Miele 24 in. G638 Plus Free-standing...
I need a diagram and fixing help for a miele G892 SCU plus. The dishwasher starts up with the intake draining light blinking and the saltpc light on. Then the start stop button turn green on. It sounds...
Water pump is for removing water. Check the fill solenoid for water getting into unit. If defective unit will not fill. If stuck in on position you will have flooding. Go to this site for parts help Search Over 2 1 Million Appliance Parts
Sep 03, 2017 | Dishwashers
Miele g892 and just like everyone the red light comes on and dishwasher stops running> why cant you answer thic common problem>
Fault codes
F00 Pots & Pans Lit
F01 Sani Wash Lit
F02 Normal Plus Lit
F03 Normal Lit
F04 Economy Lit
F06 Pots & Pans Lit
F07 Sani Wash Lit
F08 Normal Plus Lit
Sep 19, 2009 | Miele G880 Dishwasher
Inlet/drain light has come on on Miele G892 SCU plus dishwasher how do I sort it without an engineer
I haven't worked on your model. However in general you first need to go through the user manual checks to make certain you've not got a silly. Follow their safety instructions. Manuals are available on their websites e.g. http://www.miele.com/manuals/display_manuals.aspx?bhcp=1
Check the drain pump and non return valve are OK and not blocked.
Check the inlet pipe strainer is clear, and if necessary clean it and descale it.
Check you've got water coming out of the outlet on the wall (carefully, its wet - make certain it doesn't go on the electrics)
Test the fixed drain and hose if the machine is empty by putting some water in it and then turning it on - it should drain in my experience.
If all the above is OK, its possible that the machine has leaked into the bottom tray. You'd need to shut off and disconnect the electricity then open up the bottom compartment of the machine - often a plate on the front behind the kickboard trim. If it has got water in, I'd mop it out and then put it back together. i'd then try running the machine. If it worked in that state I'd bother to replace the leaking seals e.g. on a pump shaft.
Good luck with yours.
rupertvdP,
Dec 14, 2008 | Miele 24 in. G892SCU Plus Built-in...
Salt PC indicator light
I downloaded the manual off line and it gave me the facts I needed.
Thank you,
Markus
Sep 08, 2008 | Miele 24 in. G638 Plus Free-standing...
Aug 11, 2008 | Miele 24 in. G665 Built-in Dishwasher
Miele G893
you should have a dispenser on the door to add salt,regardless get c.l.r. calcium lime rust remover from a supermarket,lowes,home depot.put a cup in the unit ,run for 15 minutes and then put a cup in again.let the unit complete its cycle.if you still smell the odor repeat until its gone.you could also use baking soda,flour or vinegar.
Jan 05, 2008 | Miele Touchtronic G892 Built-in Dishwasher
Dishwasher ran with wrong soap
add some salt in the cabinet and a bit of water. salt acts as a foam suppressant
Feb 18, 2007 | Miele Touchtronic G892 Built-in Dishwasher
Miele 24 in. G656SCi Plus SS Built-in Dishwasher Logo
108 people viewed this question
Top Miele Dishwashers Experts
Mike
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
