Question about Sony Playstation 3 (PS3) Console
Ip address says ip address failed and something to do with LAN????? please help
  • 1 more comment
  • lazysod24 May 16, 2008
    ive got the same problem, are you using wireless access?
  • charmilion May 21, 2008
    my ps3 says obtaining ip adress nd den allways says failed but whe i had an old ps3 it didnt do dis
  • Anonymous Nov 11, 2008
    Mine also I got connected last night but this morning I couldn't connect I was really getting pissed off and I felt like hitting something but I had my little brother their so I calmed my self down but yeah I have been trying to connect the whole day It has happened to me once but in never went over two days.
  • 49 Answers
Yea you may need to call sony on this one the ps3 could have problems with your wireless box
Posted on May 20, 2008
Can the management IP address of an ONT be configured?
ONT management IP addresses are classified as LAN-side management IP addresses and WAN-side IP addresses.
· The LAN-side management IP address can be configured. To do so, choose LAN > LAN Host Configuration from the main menu on the web page.
· The WAN-side management IP address is based on WAN port configurations.
§ If the WAN port statically obtains an IP address, the WAN-side management IP address can be configured. Ensure that the configured management IP address can communicate with the upper-layer device.
§ If the WAN port obtains an IP address in DHCP or PPPoE mode, the WAN-side management IP address can only be obtained from the DHCP server.
May 16, 2016 | Computers & Internet
Can i renew/release the rooter ip address?
The WAN IP address of your router is assigned by your provider (TelCo, CATV provider, etc.). Most IP addresses are dynamic - which means they can change at any time without notice. When this actually happens is determined by them. It us not unusual to have the same IP address for months at a time however. There is not really something that you can do to make it change outside of contacting them specifically to have them do this for you.
LAN address changes are easier - and it is a process you can perform yourself. Do you need instructions for that? Keep in mind that changing a LAN address will not restore connections to a site that has blocked your IP. They have marked your WAN IP and no connection from the local area network (LAN) in your house will be able to connect.
Oct 23, 2015 | Edimax Network BR-6675ND Wireless...
Port forwarding for model number F7D5301
To setup port forwarding on this router your computer needs to have a static ip address. Or you can take alook at our Static IP Address guide to setup a static ip address. When you are finished setting up a static ip address, please come back to this page and enter the ip address you setup in the Static IP Address box below. Open a web browser like Internet Explorer or Firefox. Enter the internal IP address of your router in the address bar of your browser. If you do not know your routers internal IP address please read our How To Find Your Routers IP Address guide.
The address bar has http://www.fixya.com/AnswerQuestions.aspx#top in it. Just replace all of that with the internal IP address of your router. By default the IP address should be set to 10.1.1.1.
We do not currently know the default username and password for your router.
Click the NAT button near the left of the page.
You should now see a new menu. In this new menu, click Port Forwarding.
Enter the name of the program into the Description box. It doesn't really matter what you put into this box, but something that will remind you why these ports are being forwarded would be a good idea.
Enter the port to forward into the Public Port and the LAN Port boxes.
Use the Protocol Type drop down box to select the protocol type of the ports you are forwarding.
Enter the ip address to forward these ports to into the LAN IP Address box. If you are forwarding ports so you can run a program on your computer, you should enter your computer's ip address into that box.
Put a checkmark in the Enable checkbox.
When you're finished, click Save Setting near the top of the screen to save your changes.
And that's it! You're done!
Feb 05, 2011 | Belkin Basic Wireless Router
Hi there,\r\nWe have a Linksys WPS54G print server and I'm trying to re-connect it to the new Veridon Fios router. The print server has a default ip address of IP Address:169.254.53.156 but the new router...
The problem is that your printer can't obtain an IP address from your router so it is kicking back the IP address 169.x.x.x which indicates it can't reach the router. You need to go into the IP address configuration on your printer and set a static IP address on the same subnet as the router. For example your router's IP is 192.168.1.1 so set your printer's IP address to 192.168.1.5 and set the default gateway on the printer to the router's IP address (192.168.1.1) next you need to enter in the DNS Server address which is also the router's IP address (192.168.1.1). Once you do that you will be on the same network as your router. From there you can add the printer on your computer through devices and printers if its a Windows pc. Cheers! J the Guru
Oct 16, 2017 | Linksys Computers & Internet
I have an ibm desktop.and i had a vieis so i redid window xp now i guess the viris also took the ip address and i need to know how can i find the right address for my pc.i cannot get online my internet...
the virus can not get your Ip address ..the issue may be that you did not installed the LAN card driver ..After you install all the drivers ..just try again ..cause with dsl modem you do not have a static Ip address but you just obtain one automatically so ...after you install the driver for the LAN card ..just reset the modem and run the disk that you have from the provider with the settings for the modem ..or call them to advice for the settings ..if they did not provided a disk with automate settings ..
the LAN card needs no further settings but just in case you have a static Ip address..in your case I think you have to leave it like that cause by default it is set to obtain an Ip address automatically ..
If the the modem never been unplugged or something like that it will work after you install the LAN card ..
either use the drivers for your motherboard is the card is on board ..or look for the disk with your lan card driver ..
Sep 29, 2010 | Computers & Internet
Router connection
1. Please check your computer have a static IP address.
2. Please put your computer's IP address shout be automatic.
Mar 13, 2010 | Linksys WRT160N Wireless Router
Dwl-2100ap will not update firmware
1) Reset do default the device (rear reset button)
2) Set your PC a IP like 192.168.0.xxx (defaul IP address for DWL-2100 AP is 192.168.0.50)
3) Connecto via browser to 192.168.0.50, defaul login
To set IP address on you PC: goto LAN devices, click properties on your LAN, scroll down and selectInternet Protocol (TCP/IP), click properties, click set followingIP address:
IP: 192.168.0.1
Subnet: 255.255.255.0
Default Gateway: 192.168.0.50
If this information can help you, please rate me ;)
Aug 31, 2009 | D-Link AirPlus Xtreme G DWL-2100AP...
Can't access the web
Check LAN IP configuration properly, also check Gateway and DNS configuration.
Try to Ping your local host.
Start>Run>Cmd enter ipconfig/all and check your ip configuration.
Also check your server ip configuration.
Just remember to take your time and don't get nervous working on the computer. Please report back to the thread with the results of your work.
Regards;
Hassan
Jul 22, 2009 | Dell Latitude D610 Notebook
Ip address fails test connection
you need to set your 360's network to automatically detect your settings if you have other devices hooked up to the airport and they work it is not the Airport.
When it says IP address failed it has nothing to do with comcast it is your LAN having issues not your WAN
Mar 30, 2009 | Microsoft Xbox 360 Wireless Controller
Can't access my computer onthe internet
  1. Make sure that your ISP is not blocking port 80. You can check that here. (Otherwise switch to another port like 8080 or 805)
  2. Have you setup your DDNS service on your router or ensured by other means that no-ip has your up-to-date external IP? (Make sure that your external IP matches the entry at no-ip.com!)
  3. Set your LAN server to a static IP address
  4. Make sure that port forwarding is enabled and pointing to your server.
    - That means: if you run a webserver on port 80, you have to set the external port to 80 and leave the internal blank, unless your internal server listens on a different port.
If this does not help, what exactly do your mean by "Fail to connect"? Is it a 404 error? Please provide details.
I think this might be interesting for some other people too. So please come back and leave a comment!
Feb 14, 2008 | Belkin (F5D6230-3) Wireless Router
Sony Playstation 3 (PS3) Console Logo
22 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
