Question about Refrigerators
GE SmartWater Filter - Model MWF
I just replaced the filter in my GE Profile friday with a MWF SmartWaterWilter. How, when I attempt to access water from the fridge door there is a total lack of water pressure (it just dribbles out). Any ideas on how to get the water pressure back up to normal pressure?
Note - I've replaced the filter several times over the last 4 years and I've never had this problem before. The water line into the fridge is ok too as I've checked that.
  • 4 more comments
  • teresa1kay Jan 11, 2009
    WE bought the GE profile french door Nov of 2007. The first filter lasted about 6 mo. After replacing it , after about 2 weeks it produced a very low waterflow-almost a dribble and when trying to fill anything more than 1 to 2 cups the flow woud just stop. GE sent me another filter-lasted maybe a month. The repair man came couldn't figure it out-put another filter in , and that one lasted about a month. When I take out the filter and put the bypass plug in the water flow is what it should be. At a minimum of $30 a pop this isn't cutting it. They are supposed to last 6 mo!! Anyone else hav this issue?
    Thanks Terri
  • Anonymous Feb 25, 2009
    I have the same problems. I have changed the filters several times. Once filter is changed, pressure will return for a couple of weeks then starts dwindling away until it completely stops. Also affecting my ice maker. It is like the water is not getting through. I also have an outside filtration system on our well. That still do not stop the filters from clogging up quickly.
  • Gareth Young
    Gareth Young Jan 03, 2014
    Yup. Same issue here. Mine lasts about 2 - 3 weeks and then starts dribbling out. Ticks me off. Fridge is about 3 years old now.
  • Gareth Young
    Same issue here. Fridge is about 3 years old now. It used work just fine, but the last 2 filters have only lasted about 2-4 weeks before losing water pressure and dribbling out. Drives me crazy.
  • Anonymous Mar 28, 2014
    I have a FFHS2622HW3 and my Pure 2 filter will not go in. I have turned off water bled off pressure and it still pops out any ideas. Thanks
    Have left the water off for 4 years and after hooking up the water it only gets to the filter
    Scholar:
  • 150 Answers
Make sure filter is installed correctly (not to doubt you but it can happen) make sure there isn't some foriegn object or packing materialetc in the filter end. You could have a bad filter. also make sure the unit is purged well
Posted on May 15, 2008
I replaced my GE profile MWF water filter (identical GE part) and now I dont have water dispensing and don't have a working ice maker
Quite frequently carbon fines can be flushed from filter and plug the filter. If you have the bypass plug to replace the filter. Put that in and flush system completely. Take the filter and flush it at the kitchen sink. It is best to fill these with water before installing and flush the carbon fines before installing in fridge.
RJ
Mar 09, 2011 | GE Mwf Ge Refrigerator Smart Water Filter...
After installing a new mwf filter no water comes out of the dispenser. It worked before changing the filter. With the filter bypass plug installed - still no water. I held the dispenser for more than 3...
the inlet valve has jammed shut & needs to be replaced it's just coincedence that it happened when you changed the filter unless the taps turned off it has to be a faulty inlet valve.
Feb 18, 2011 | GE 3 Ge Mwf Smartwater Water Filter Fits...
I have a GE MWF water filter that is dripping water into the refrigerator. Fridge is about 8 yrs old and have changed many of the MWF water filters. 1st time with this problem.
Many times fines from these filters become dislodged and plug up the filter housing. If you have the bypass plug for the filter, install it and run a couple gallons of water through fridge to flush the system completely. The install the filter again. Make sure none of the water lines feeding fridge are pinched or kinked and valve is on all the way.
RJ
Nov 30, 2010 | General Electric GE SmartWater Household...
GE SmartWater MWF Refrigerator Filter is making noise when dispensing water
The filter body for the unit is poorly designed and can only stand maybe 8 filter changes before it starts failing to open fully with the new cartridge. As far as I can tell the only solution is to replace the filter body.
Oct 14, 2010 | GE GSH25JFT
Replaced my GE double wide refrigerator SMARTWATER FILTER #GWF With a which is supposed to be better. Yet, the water stream has cut down to half. Do I need the adapter collar for this newer model? ...
I have exactly the same problem. Replaced my GWF filter with the "new improved" MWF filter and the same thing happened. Tried replacing the filter not once, but twice - same low water flow. If you install the bypass plug the water flow is normal, so don't bother checking for water restrictions, bad hoses, tanks etc.. My refridgerator is a GE Profile 26 cubic foot purchased in 2004. I'm afraid these MWF filters don't work well in older models.
Oct 07, 2010 | GE Replacement SmartWater Filter for GE...
Do add water ge smart water mwf cartridge
i dont believe so water will fill it, it should reconize the filter and fill it... i believe i may be wrong but that is how it usually is.... did it come with instructions?
Apr 19, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Replaced GE SmartWater filter in my GE refrig and water wil l not flow thru it,why?
We replaced the water line to the refriderature. It was plugged by a coroded copper sleve.
Apr 23, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
Refrigerators Logo
2,126 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
