Question about Canon PIXMA iP1600 Printer
I am using a refilled cartridge; when I get the message about the ink cartridge having been used and do I want to continue without the function for detecting the remaining ink, I cannot get it to reset by pressing 'resume' on the printer. The message keeps coming up after I hit 'OK' and eventually the printer turns off, haing lost the print job.
  • Canon Master
  • 27,725 Answers
Remove the cartridge and clean it again using a piece of white paper with a small amount of methylated spirits or mineral turpentine i cant gaurantee this you might have to buy a new one you must have touched the sensor tabs on the cartridge
hope this helps
Posted on Sep 14, 2010
  • Larry Davis
    Larry Davis Feb 03, 2011
    MY PROBLEM IS VERY SIMILAR , I PUT A NEW CARTRIDGE IN THE PRINTER WITH IS A Canon PIXMA iP1600 . THEN IT DID.T WORK SO I REMOVED IT AND PUT IN AGAIN AND THE SAME ANSWER , BLACK, IT WIL NOT WORK WHEN YOU PRESS RESUME. NEW CARTERIDGE ?
  • Brian Sullivan
    Brian Sullivan Feb 04, 2011
    You might have to uninstall the printer restart your computer then reinstall your printer
    click start control panel administrive tools computer management device manager scroll to ports(COM
Pixma 2200 series all in one
Don't use refill kits, they are no good in quality printers. Also the cartridges in the newer models have a chip in them that knows when the cartridge is empty. When it becomes empty, the chip has to be reset, and this is what those mall cartridge fillers do.
E, 1, 3 The ink may have run out. The function for detecting the remaining ink level will be disabled since the ink level cannot be correctly detected. If you want to continue printing without this function, press the machine's Stop (Reset) button for at least 5 seconds. Canon recommends to use new genuine Canon cartridges in order to obtain optimum qualities. Please be advised that Canon shall not be liable for any malfunction or trouble caused by continuation of printing under the ink out condition. Checking the Ink Status Checking the Ink Status with the Ink Lamps on the Operation Panel The ink level detector is mounted on the machine to detect the remaining ink level. The machine considers as ink is full when a new FINE cartridge is installed, and then starts to detect a remaining ink level. If you install a used FINE cartridge, the indicated ink level of it may not be correct. In such case, refer to the ink level information only as a guide. When remaining ink cautions or errors occur, the error code will be displayed on the LED (Light Emitting Diode) to inform you of the error. Check the error code and take appropriate action. -> [ An Error Code Is Displayed on the LED ] See[Checking the Ink Status ]
Oct 27, 2015 | Canon PIXMA Office Equipment & Supplies
U162 error on black ink cannon printer
This error occurs when printer fails detecting ink level or printer assume that no ink in the cartridge. We cannot use print, copy,scan, and fax function before the problem fixed. It's recommended for you to replace ink cartridge. To continue using the printer without replacing the cartridge we must deactivate ink level detection function. Be aware that printing in this condition can damage the printer while sending fax or scan is not problem.
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Original source: http://ij-forum.blogspot.com/2008/12/error-message-check-ink-u162u163.html#ixzz2Cpr4Be1K
Nov 20, 2012 | Canon PIXMA MX340 Wireless Office...
I am trying to scan a document, however the black ink is empty. It only shows the error message that I should refill my ink. Shouldn't I still be able to scan documents?
Must be using PG830 or PG40 50?
For Canon, if either color or black cartridge is empty or out of ink, "Scanner" doesn't work.
That's why your scanner is not properly working.
It's all connected... That's Canon.
Are you refill your cartridge by yourself?
Try "ROADINK" inkjet refill kit. No drill or sharp needles are needed.
It's not only easy to refill, you can have quality printing.
Check out my youtube video, will find how easy refill can be done.
Apr 20, 2011 | Canon MP490 InkJet Printer
I changed theblack ink cartridge twice and it still won't print in black, colours are printing but no black
Ink level data is stored in a chip of the cartridge. Once the cartridge is empty, ink low message will appear eventhough you refill the cartridge. You need to deactivate ink level detection function to continue printing in case of usage of refill ink .
Search google on how to change ink level detection
Chris Thrash
B52Computers
Jan 10, 2011 | Epson Office Equipment & Supplies
I have Canon multifunction MX310 I was using
press the Stop/Reset button for at least 5 seconds with the ink cartridge installed. Then printing can continue under the ink out condition.Canon do not like you to use refills and generic carts so the function for detecting the remaining ink level will be disabled
Jun 19, 2010 | Canon PIXMA MX310 All-In-One Printer
I have the error message that it can not recognize the ink cartridge and it is blocking me from using the macine in any function. I have removed the ink cartrdige and it still says it cannot recognize...
An ink tank which has once been empty is
installed. Replace the applicable ink tank with
a new one.
Printing with a once-empty or refilled ink
tank can damage the print head.
If printing is continued without replacing the
refilled ink tank, press the Stop/Reset button
for 5 sec. or longer to record the use of a
refilled ink tank.
Oct 08, 2009 | Canon MP610 Photo All-In-One Printer
Lexmark E120 black cartridge
In their determination to keep you purchasing their ink whether you like it or not, Lexmark has circuitry built into their ink cartridges that based on measured use tell the printer when the cartridge theoretically should be empty, whether it is or not.
In the case of the black cartridge they are somewhat more lenient than in the case of the color cartridge. Eventually, when the circuitry tells the printer that the black cartridge should be empty it will continue to be refillable, and work, but will present the owner with annoying messages ranging from "you're using an unauthentic cartridge" to other things. The best thing to do in this case is to check the box that pops up telling it not to continue giving you the annoying messages. This works, but eventually may start again, after which you again check the box telling it to stop. It's quite livable though.
In the case of the color cartridge the built in circuitry will eventually tell the printer that the cartridge is empty, even if it's not because you have properly refilled it, and it simply will not function any longer. You've just wasted your ink. Natually they don't want to see you destroy your printer, which costs less than purchasing only two of their 2400% profit ink cartridges. Good luck.
Jun 03, 2009 | Lexmark X5470 All-In-One InkJet Printer
Canon ip1200 black cartridge wont recognize after i refill
Dear lim,
Here a solution for you. The cartridge of this printer has memory chip that store ink level data inside. Once the cartridge is empty we cannot restore ink level data to be full. To continue using refilled cartridge you need to deactivate ink level detection function first. Perform this step: when the message 'The following cartridge cannot be recognized' appears press Resume/Cancel button. Do this for each cartridge you refill;if you refill both black & colour cartridge do this tip two times (once for each cartridge).
Please rate this as fixya ok.
Regards,
Dec 02, 2008 | Canon PIXMA iP1600 Printer
IP 3300 refilling of ink tanks possible or not
Yes it is possible, Try injuctions to refill your cartidates.
Feb 22, 2008 | Office Equipment & Supplies
Refilling Ink in Canon Pixma MP830
Hello, I found this in a repair manual for the MP830. summery is to press and hold the stop/reset button for 5 or more seconds. I copied the info from the manual too. The remaining ink amount unknown. [1683] (Applicable ink tank icon) The remaining level of the following ink cannot be correctly detected. An ink tank which has once been empty is installed. Replace the applicable ink tank with a new one. Printing with a once-empty or refilled ink tank can damage the print head. If printing is continued without replacing the refilled ink tank, press the Stop/Reset button for 5 sec. or longer to record the use of a refilled ink tank. Note: After the above operation, the function to detect the remaining ink amount is disabled.
Jul 17, 2007 | Canon PIXMA MP780 All-In-One InkJet...
Canon PIXMA iP1600 Printer Logo
330 people viewed this question
old marine
old marine
