Question about Samsung PS50P7H 50 in. HD-Ready Plasma TV
Whats involved in installing a new power supply board in an HP-T5404 Samsung Plasma TV?
  • 2,427 Answers
Hmmmm its easy really..
  • unscrew rear cover
  • cables from power board to other components
  • unscrew and remove power board
  • put in new board and screw down
  • re connect cables
  • screw back on the rear panel
  • plug in
  • turn on
  • watch!!
Posted on Sep 14, 2010
Testimonial: "Thanks for the easy fix!"
Samsung plasma hp-r4272c, i dont have VS volt output on main power supply board
Just replace the main power supply board if there is no vs voltage output.
Sep 21, 2015 | Samsung HP-R4272 42 in. Plasma HDTV
Samsung 50" plasma HPS5033X/XAA shut off and will
HGi:
This model is nortorious for Y-sustain board failure, replace the Y-sustain board and you should be good to go. The Y-sustain board is the one while standing with back off the set is the board on the left side of the television.
Jul 05, 2011 | Samsung HP-T5044 50 in. Plasma TV
When i turn on my samsung plasma it makes a hissing noise like stakick?? sound like an old tv when you disconnect the feed .When It started it would last 1 minute 2 monthes later it takes 20 minutes to...
This problems is the cases by the power supply board is dying.That the board,where the power a/c cord plug into it.Try website like Ebay.com to buy a refurbish power supply board for the replacement.After u replaced it with a different power supply board,tv will work normal again.
Nov 17, 2010 | Samsung HP-R5072 50 in. Plasma HDTV
Samsung model HP-T5054 Plasma TV .. Push power button it lights up and Tv clicks like it is comeing on but then dont..
When you remove the back of the set. You will fined a couple of caps on the power supply board that are bulged and they need to be replaced, or you can buy a new power supply at www.partstore.com. If you want to just purchase the caps, you can get them at www.mcmelectronics.com
Oct 16, 2010 | Samsung HPT5054 50 in. HD-Ready Plasma...
Lg 42pg20 Plasma Will not turn on
If there is no LED burning to indicate there is power than the power supply is faulty.Repair is not verry easy to do with these complicated power supply's.
Nov 02, 2009 | LG 42PG20 42 in. Plasma HDTV
Samsung TV Power Supply Board
I doubt that moisture damaged the SMPS bd.
There are many circuit boards in your set and it will take a trained samsung tech to find the problem.
Jul 17, 2009 | Samsung HP-T4264 42 in. Plasma HDTV
HP-R5052 reboot
It's definitely an overheating problem if your plasma turns off by itself after a while. I would suggest to place a cooling fan near the back of it as a temporary fix.
There could be a power supply issue along with a Ysustainer board but in order to know that for sure, you should use a hair drier and blow hot air to the power supply and see if the TV turns off, if the time that the tv turns off is shorter when blowing hot air to the power supply; then is the power supply issue.
Good Luck.
Jan 31, 2009 | Samsung HP-R5052 50 in. Plasma HDTV
Samsung Plasma PPM42S3 Dead
Hello karnevil925,
I would suspect a problem with the power supply board (the switching power supply) or the power connection to the ignition board. You will need a schematic and a multimeter to test the power levels on the board.
I would suggest that you take this TV to a qualified TV technician for repair, since there is a possible shock hazard involved.
I hope this helps,
Thank you,
Shuttle83
Sep 27, 2008 | Samsung PPM42S3 42 in. Plasma Television
Samsung PS50P7H 50 in. HD-Ready Plasma TV Logo
256 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
