Question about Maytag Performa PAV2200
Spin cycle My wash machine doesn't spin. It will drain but not spin at all. Can we fix it ourselves or do we need a repairman?
  • madbushman May 18, 2008
    washer barely spins and wont spin out clothes checked belt it is fine
  • 868 Answers
Ok,first off this machine has a clutch brake assembly on it that is known for sticking.It will sometimes hit a very high squeak at the last spin as it stops.Ive come up with the solution to fix this but Id have alot of trouble explaining it this way .Please contact me and assist you in depth any time you need.  archieferrarini@yahoo.com
Posted on May 23, 2008
Will not spin or drain tried unplug and lid switch is fine fill ok
Susan call your service repairman the warranty should cover the fix .
Dec 09, 2015 | Washing Machines
Tip
Washing Machines will not rinse or spin
If the water won't drain out of your washing machine, either something is stuck in the drain hose or pump, or the pump is broken. Both fixes are simple if you're even just a little bit handy with tools. We're showing the repair on a Maytag washing machine.
What is wrong with a washer that does not spin?
If your washer fills with water but doesn't agitate, the problem is likely to be a faulty lid switch, a broken belt, or a problem with the motor. (Note: Direct-drivewashing machines do not have belts.) To diagnose the problem, do the following: 1Check the washing machine's spin cycle.
How to Drain Washing Machine That Won Drain Family Handyman
Washer Doesnt Agitate or Spin
Error codes in front load washers
Washing Machine Not Rinsing How To Fix
My washing machine stops at Rinse Does not DRAIN or SPIN
What causes a washing machine not to drain and spin?
If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing.
SOLVED Why won my washer spin or drain Kenmore 110 Series Washing Machine
Maytag Washing Machines will not rinse or spin Google Search
on Dec 12, 2017 | Washing Machines
Having problems with my kenmore he2 plus front loader washing machine on spin cycle....we've removed all panels and check wire connections and drained both the front and back drain. Ran the machine on...
The two most common reasons the washer won't spin with a load is either the belt needs to be replaced (pretty cheap to fix) or the transmission is going on it (may as well buy a new machine). There are other less common problems, depending on your model. I would suggest calling a repairman who deals with all makes of washers, rather than the Sears repairman, unless it is under warranty. My front loading Kenmore had a problem and the Sears guy tried to tell me I was overloading the machine. He charged me a fortune and did nothing. Called an all makes repairman and he found a baby sock had made it's way to the drain and was clogging it.
Nov 29, 2013 | Washing Machines
Washer fills with water but doesn't begin to agitate to wash. It also drains but doesn't spin when we set the dial to that
Your agitator pindle. has come loose From the spline. Try to lift up on the agitator. If it lifts off the spindle easily then it has worn out the spline. That is what connects the agitator to the s
Feb 06, 2013 | GE Profile WPRE6100G Top Load Washer
Maytag washer model mav5920eww won't spin
It is either your gearcase or timer. They both are recommended to be replacd by a repairman.
Apr 30, 2012 | Washing Machines
Filling with water then does not finish cycle
There should be a sensor on the door that tells it the door is shut. Check that this is being pressed when the door is shut. You should see it where the doormeets the washer and can use something to press it. Put your washing in spin cycle and press it if it starts spinning there is your problem( make sure the washer is empty ). If it still doesn't work you will most likely need a repairman.
Apr 18, 2012 | Candy Washing Machines
Spin cycle doesn't work
bad drain pump or clogged drain line. some units have drain trap you can clean,if so you can clean it out yourself but will make a huge mess if you don't pinch close the drain hose between the tub and pump.
Nov 12, 2011 | Haier HLP21N Washer
Washer won't finish the cycle because of imbalance during spin. It just shuts down, but I have time left over. I need to cancel the wash cycle in order to run the spin only cycle. ATF8000FG
I called a repairman since it had 5 more days under warranty. The problem was the drain tube from the washer into the drain was pushed too far down into the drain pipe. He did have an error message that it was taking to long to fill. Well no wonder, it was siphoning out the water as it drained.
Seems to have fixed the problem.
Nov 03, 2009 | Frigidaire ATF6000ES Front Load Washer
Waher wont spin
first, if it's under warranty, have them service it, if not then....
the maytags work mainly on belts with a forward and reverse on the motor. forward washes, reverse drains and starts spin cycle. if the motor does reverse and drains the water, then it's probably the transmission of the washer. these washers have 10 years parts on the transmission, so I would have a service repairman come out and fix it. you'd only pay for the labor and the transmission would be free.
Jun 21, 2008 | Maytag SAV2655A Top Load Washer
Washing Machines Logo
80 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
