Question about Whirlpool Dryers
My Maytag MED5840TW0 dryer overheated yesterday. After some research, I replaced the thermal fuse tonight, and it ran for one load and then stopped again. The dryer gets hot to the touch. I've checked the venting, and the vents are clear and lint trap is clean.
  • brianedward Sep 14, 2010
    I assume this is something I could check myself with a meter?
  • scott7486
    scott7486 Apr 29, 2014
    IT COULD ALSO BE THE HIGH TEMP LIMITER (THERMO FUSE)
    Master:
    Sergeant:
  • 449 Answers
Have your blower motor checked
Posted on Sep 14, 2010
Why maytag bravos keeps blowing thermal-fuse
Lots of videos here about that problem.
maytag dryer thermal fuse replacement YouTube
Which thermal fuse. The one on the heater or the one on the lint filter housing? If it was the one on the heater did you replace the thermostat too.
Is the dryer vent blocked, has too many elbows, or too long or otherwise restricted, or is the dryer overloaded.
https://www.youtube.com/results?search_query=maytag+dryer+thermal+fuse+replacement
Sep 08, 2014 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
Lg dryer is overheating blowing the thermal fuse
you have an airflow problem. Check the vent hose all the way out and the outdoor vent hood.
a simple verification can be performed by disconnecting the vent hose from the dryer and see if this solves the problem.
Mar 03, 2014 | LG DLE5977 Electric Dryer
I have a maytag admiral dryer (ade7000ayw) stopped working over tonight? It's plugged in and the outlet has power.
The thermal fuse is what the problem very likely is. It is located on the side of the heater housing on the upper part of the back wall of rear drum support. To check it UNPLUG DRYER,remove the 2 white wires on the right side of where the heat element goes and check the thermal fuse for continuty (zero ohms resistiance) using a meter set to measure ohms of resistiance
Aug 12, 2011 | Dryers
Amana dryer model YNED7200TW will not start. there is power, but start button does nothing. Resetting breaker did not work. Any ideas?
Thermal Fuse
Item #2986 (OEM Part)
$10.70
Thermal fuse. If the dryer overheats, this device stops the flow of electricity to the heat source and/or the entire dryer. It is located on the blower housing and cannot be reset. The most common cause for overheating is a vent tube clogged with lint, a birds nest or other debris.
Manufacturer Number 3392519
More
  • Admiral Dryer Thermal Fuse
  • Amana Dryer Thermal Fuse
  • Crosley Dryer Thermal Fuse
  • Estate Dryer Thermal Fuse
  • Kenmore Dryer Thermal Fuse
  • Kenmore Refrigerator Thermal Fuse
  • Kenmore Washer/Dryer Combo Thermal Fuse
  • KitchenAid Dryer Thermal Fuse
  • KitchenAid Washer/Dryer Combo Thermal Fuse
  • Magic Chef Dryer Thermal Fuse
  • Maytag Dryer Thermal Fuse
  • Roper Dryer Thermal Fuse
  • Roper Washer/Dryer Combo Thermal Fuse
  • Whirlpool Dryer Thermal Fuse
  • Whirlpool Washer/Dryer Combo Thermal Fuse
In Stock
Quantity: http://www.repairclinic.com/PartDetail/Thermal-Fuse/3392519/2986#repairHelpVideoTabs
Jun 08, 2011 | Amana Dryers
Maytag dryer is less than 3 years old. Blew thermal fuse. Cleaned all of the venting inside and out. dryer still overheating and blowing the thermal fuse. Replaced the thermal fuse and the high temp sensor...
Have you tried replacing the operating thermastat it's what shuts it off at the right temp and would cause the thermal fuse to go if it is not shuting.off at the right temp. It happens.
Hope this helps.
Dec 05, 2010 | Maytag PYE2300AY Electric Dryer
Maytag dryer overheating
have u replace heating sensor
Oct 22, 2009 | Maytag PYE2200 Dryer
Maytag Dryer will not start again
Check list:
clear vent pipe
dryer clean of lint
blower wheel tight
drum turns freely
fuse tight against heater.
Wires not shorted on high limit mounted above heater
electric bill paid.
Feb 07, 2009 | Maytag PYE2300AY Electric Dryer
Dryer
hI YOU MIGHT JUST HAVE A VENTING PROBLEM iF YOU REPLACED THE THERMAL FUSE & IT WENT AGAIN tHE VENTING SHOULD BE LOOKED AT tHANKS FOR THE QUESTION tHE APPLIANCE DOC
Aug 30, 2008 | Maytag PYE2300AY Electric Dryer
Dryers Logo
160 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
