Hi how do i change the paper tray for the HP LJ 2430. everytime i print it sets to tray one but i want to use tray 2
  • 32,281 Answers
When you want to print go to File - Print - Properities - Paper/Quality then click thr down arrow on Paper Source and change it from Automatically Select to Tray 2 - click OK - click Apply - click Print
Posted on Sep 14, 2010
Why my HP LJ 4100 is always taking envelopes from tray 1, even when I try to print from tray 2?
Check your feed rollers in tray 2. Sounds like they are worn and the paper cannot be pulled from tray 2 so it goes to tray 1
Sep 20, 2013 | HP LaserJet 4050 Printer
HP LJ 2420 wont pickup paper from tray 2
Replace try2 paper pick up roller..
Dec 01, 2011 | HP LaserJet 2420 Printer
My HP 4100N printer often automatically selects to print from tray 1 (the manual feed), when I want to print from tray 2 (the automatic feed). How do I set the default tray?
HP Laser Jet 4100 HP Not pulling paper from Tray 2
Action: The 4100 will look at tray 1 first then tray 2 If tray 1 is empty it will pull from tray 2 if the papersize matches the job otherwise back to tray 1 and ask for the paper. Your machine likely thinks the paper in tray 2 is not the size you want. For instance you have LETTER in tray2 But the machine thinks it is legal. The LJ 4100 detects the paper size in tray 2 automatically. If you print a configuration page: MENU them INFORMATION then ITEM then CONFIGURATION PAGE then SELECT. The page will print and show what size paper the machine thinks is in Tray 2 if it says LEGAL and you have LETTER you need to Check The Paper Backstop in TRAY 2. The back stop sets the length of the paper if it is not at Letter (8 1/2 x 11) the machine will not detect LETTER. Even if it just a little bit off or between positions.
If it is set at LETTER then you may have bad switches in the machine that are operated by the tray. Or the arms on the tray that operate the switches are not moving properly. You will find the arms on the rt, side of the tray and feel them change position when you move the backstop.
Hope this helps helps. Please keep us updated and remember to rate this answer. TF
Oct 18, 2010 | HP LaserJet 4100n Printer
Hp 4000N 41.3 unexpected paper size
Clean the sep. rollers one in the paper tray and one inside the paper tray port. Then clean the feed roller. Its behind the sep roller in the paper tray port. You must look close with a flash light. It has 4 D feed rollers. It will rotate down to clean them do not knock the spring off. Use only water on a cloth no alcohol. Steven 818-888-0006
Mar 11, 2010 | HP Office Equipment & Supplies
How to change the default tray on a HP 2430?
print config page of printer,see how trays are configured.
Jul 01, 2009 | HP LaserJet 2430n Printer
Hp laserjet must manually push button to print
Please print a configuration page from the control panel of the printer
- Menu > Information menu > print configuration.
- Check for paper handling details.
Following setting should reflect.
Tray 1: Any size / Any Type
Tray 2: A4 size / Plain Type
If the above settings are not reflecting in the configuration page, please change accordingly by browsing on the control panel of the printer to:
Paper Handling Menu >
Tray 1 Size: Any
Tray 1 Type: Any
Tray 2 Size: A4
Tray 2 Type: Plain
Let me know if that helps to solve the issue.
Regards,
Nikhil.
Jun 14, 2009 | HP LaserJet 2420 Printer
HP COLOR LASREJET 3500 41.3 ERROR
hi ray, it's chris. i called your cell phone, but figured you might see this. replace the registration clutch. after some research, this seems to be the solution given that should solve the issue in that printer, and it's an independant part from the paper pickup assembly...
RK2-0247-000CN
chris
May 27, 2009 | HP Color LaserJet 3500 Printer
Settings in HP Printer LJ 4100.
Hope this helps.
Mar 23, 2009 | HP LaserJet 4100n Printer
LJ 2430 Printing Blank Pages
HI there have you tried the toner cartridge as this could also cause this problem? Also change the transfer roller and are the bands going from left to right or from up to down. If the bands are left to right change both if up to down more likely to be the toner cartridge.
Hope this helps you
Thanks J
Jan 11, 2008 | HP LaserJet 2420 Printer
HP 2430tn lj printer with 13.20 jam inside top cover error
What is the exact error message shown on the display ?
Does it makes any strange noise when you start it up ?
Dec 31, 2007 | HP LaserJet 2420 Printer
102 people viewed this question
jasbo
jasbo
