Question about Magic Chef CDB1500AW 24 in Builtin Dishwasher
I push start and my dishwaher wont turn on. I have checked the other buttons and they work. I also turned off my breaker to see if that will help and it still doesn't turn on,
  • Anonymous Mar 27, 2014
    push button on and no lights come on. Electrician confirms there is power to the machine but it won't work
  • 375 Answers
Either:
  1. something blocks the door from latching or closing. Check, if anything is stuck behind a dishrack. try reversing lower rack. check if the door aligns properly and dishwasher is installed correctly
  2. latch switch failed/latch mechanism is broken. Disconnect dishwasher from power. Disassemble door, check latch, check latch switches for continuity
  3. touch panel or control board (less likely) is failing. replace if none of the above is working for you.
Good luck,
Vlad
First Choice Appliance
Posted on Sep 14, 2010
Whirlpool gas dryer WGD5540SQ it is getting power, drum does not turn, just hums when I push start button. I checked for blown circuit breaker, i' ve cleaned lint tray and checked vent to outside. I've...
there is a reset button on the motor more then likely it tripped, there are actually two one resets the other trips, but here is a website it will help with the dissemblance of the dryer, Tim:
http://www.partselect.com/dryer+dryer-wont-tumble+repair.htm
Oct 19, 2010 | Whirlpool WED5520SQ Gas Dryer
Heat dry, lock button
turn off the power on the circuit breaker labeled dishwasher of your house main switch, and wait for at least 10mins before turning on. once you turn on the power it will reset all the setting and your dishwasher should be working as normal.
Mar 01, 2010 | Frigidaire Dishwashers
I have a Maytag PYE2300AYW. Push button but nothing happens. Had breakers to house checked and all good.
Dryer suddenly stop working when pushing start button (knob will make a humming or ticking kind of noise but won't turn on. I cleaned and check the outside exhaust and lint screen passage. Nothing is helping. help
Jan 08, 2010 | Maytag PYE2300AY Electric Dryer
When you press the start button the dryer hums and doesnt turn
first thing you need to do is open the door and try to rotate drum by hand it it is not turn by hand that mean there is some thing stack in your blower fan. if you can turn the drum by hand you need two people to check this problem..one open the door there is one push button, push that button and hold now second person need to push the start button when you heard hums sound the turn the drum by hand again if your dryer stat spin that mean you have bad motor. (forgive me for my english)
Apr 18, 2009 | Dryers
Frigidaire dishwasher wont run
I solved my problem by disconnecting from the power source and then reconnecting, apparently it needed to be reset, it now works fine!
Feb 15, 2009 | Frigidaire 24 in. FDB1050RE Built-in...
I have a kenmore electric dryer it worked fine i dryed a load of clothes in it and went to dry another load and it wont turn on i set the knob to tempature to dry my next load and push the start button and...
This may be a thermal overload switch which is probably located underneath the top of the dryer. When you find it, bypass it to see if that is the problem. If so, replace it for about 10-12 dollars. Check the breakers first, then the connections in the back to see if they are secure.
Dec 29, 2008 | Kenmore 659 Electric Dryer
Dryer shut off towels were not yet dry, turned dial to restart dryer acts as if it isn't getting power I closed door and pushed start button. Nothing! Checked breakers and power cord at outlet all checked...
Hello mdonettaYou said,
Dryer shut off towels were not yet dry, turned dial to restart dryer acts as if it isn't getting power I closed door and pushed start button. Nothing! Checked breakers and power cord at outlet all checked okay. Any ideas.
yes, try unplugging the power cord or turning off the breaker for 5 minutes. Either will due. Some times the system needs to be reset!
If this does not work there are internal fuses that can be replaced!
Let me know how it goes!
Huuum
Sep 19, 2008 | Dryers
My dryer wont start
check and see if you have 220 volts to your dryer using a volt / ohm meter find the cord and remove cover take meter and go across (1 test lead on left and one on right) side of cord there should be 220 volts.check this and get back to me. if no 220v trip breaker back and forth and try again
Dec 26, 2007 | Whirlpool GEW9200L Electric Dryer
My Dryer wont do anything
check your house wiring circuit breaker
Jun 01, 2007 | Equator ED 510 Venting Clothes Dryer...
Wont start
try turning the drum by hand...is it jammed? if not, then: the motor will not turn due to a number of reasons: 1.) simply burned out copper windings 2.) switch not turning on motor or not turning on motor starting circuit-depending on design ...if jammed, then try to find the interference to turning
May 31, 2007 | Estate TEDX640JQ Electric Dryer
Magic Chef CDB1500AW 24 in Builtin Dishwasher Logo
296 people viewed this question
Top Magic Chef Dishwashers Experts
240cpa
Are you a Magic Chef Dishwasher Expert? Answer questions, earn points and help others
