Question about HP OfficeJet 6110 All-In-One InkJet Printer
My computer will print from my e-mail but no longer from my quickbooks. It will also not copy. It seems to have happened when I changed the black ink. Can you tell me why it won't print
  • 643 Answers
To help you, I need to know what operating system you have?
windows xp, vista, or windows 7?
Posted on Sep 14, 2010
Epson stylus dx6000 only copy in color mode
Any ink in the black cartridge or can you use clean mode to clean it?
Mar 15, 2014 | Office Equipment & Supplies
Hp 4700 won't print pdf
For QuickBooks Pro, Premier, and Enterprise Solutions working on the Windows XP platform:
  1. Choose Windows Start button and open the Printers and Faxes window.
  2. Right-click the QuickBooks PDF Converter icon and choose Properties.
  3. Click the Ports tab. Click the Add Port button.
  4. Select Local Port. Click the New Port button.
  5. For the new port name, enter PDF1. Click OK.
  6. Close the Printer Ports window.
  7. Select the PDF1 checkbox, if it is not already.
  8. Click the Advanced tab.
  9. Select Spool print documents option.
  10. Clear the Enable advanced printing features checkbox.
  11. Select the Print directly to printer option.
  12. Click the Apply button. Click OK.
  13. Choose Windows Start and choose Run.
  14. In the Open field, enter %windir%. Click OK.
  15. Right-click the System32 folder and choose Properties.
  16. In the Properties window, click the Security tab.
  17. In the Group or user names list, select Users. In the Permissions for Users list in the Allow column, select Read, if not already selected, and select Write.
  18. Click the Apply button. To save the changes, click OK.
  19. Restart your computer.
  20. Note: For the changes to take effect, you must restart your computer.
For QuickBooks Pro, Premier, and Enterprise Solutions working on the Windows Vista platform:
  1. Make sure that you are logged in as Windows Admin.
  2. Choose Windows Start > Printers.
  3. Right-click the QuickBooks PDF Converter icon and choose Properties.
  4. Click the Ports tab. Click the Add Port button.
  5. Select Local Port. Click the New Port button.
  6. For the new port name, enter PDF1. Click OK.
  7. Close the Printer Ports window.
  8. Select the PDF1 port checkbox, if it is not already.
  9. Click the Advanced tab.
  10. Select the Spool print documents option.
  11. Clear the Enable advanced printing features checkbox.
  12. Select the Print directly to printer option.
  13. Click the Apply button. Click OK.
  14. Restart your computer.
    • Note: For the changes to take effect, you must restart your computer.
  15. From QuickBooks, print, email, or create a PDF document.
For QuickBooks Pro, Premier, and Enterprise Solutions working on the Windows 7 platform:
  2. Choose Windows Start > Devices and Printers.
  3. Right-click the QuickBooks PDF Converter icon and choose Printer Properties.
Hope that it will work for you,
Thanks,
She Morillo
Dec 04, 2012 | HP LaserJet 4700 Printer
Printer suddenly stopped working with quickbooks but will still work with all other programs. window states: change port assignments or reinstall software. printer is hooked up wirelessly
  1. Open the QuickBooks sample company and try to print the same form or type of form. If it prints successfully, your company data, form template, or customized report may be damaged.
  2. Reopen your company file and try to print an uncustomized (standard/default) form template or non-memorized report. If the issue occurs again, refer to Verifying and rebuilding the QuickBooks company data and then attempt to print again.
  3. If you were printing a batch of forms in QuickBooks, attempt to print a single form. If successful, try printing smaller batches.
  4. If you were able to print from QuickBooks in the past from this company file:
  5. Turn off the printer, restart your computer, and then turn the printer back on.
  6. In QuickBooks, choose File > Printer Setup and check the printer settings for the specific form you're trying to print.
  7. Click Help in this area for more detailed instructions on these settings.
  8. Ensure that you have the latest printer drivers for your printer. Go to the manufacturer's website to download and install the most current drivers.
  9. Replace the QuickBooks Qbprint.qbp file:
  10. Close QuickBooks.
  11. Rename the qbprint.qbp file.
  12. Open QuickBooks and attempt to print again.
  13. If the issue persists, repair the QuickBooks installation.
Mar 07, 2010 | HP Officejet Pro L7680 All-In-One Printer
Turbotax 2008
Hello There, I found this in their FAQ Guide. Hope this resolves your problems, I know it is a bit of a read. Good Luck!!
What is happening?
Double-clicking on a backup, portable company file, or a file with an extension other than .qbw, the following error occurs:
An error occurred when QuickBooks tried to create, open, or use the company file. Please try again. If the problem persists, contact Intuit Technical Support and provide them with the following error codes: (-6150,-1006).
Or, if you attempt to double-click the data file without QuickBooks open, the following error occurs:
There was an unexpected error reported while trying to run QuickBooks with company file "path location". Error code 80070057.
Note: More than one error message that includes the error code 80070057 exists. If this is not the exact wording of your error message please refer to one of these other documents:
Error: 80070057 parameter is incorrect" when clicking on a QBB, QBM, QBW, NT, or TLG file from a Google Search Timeline
Error: 80070057 parameter is incorrect" when clicking on a QBB, QBM, NT, or TLG file from a Google Search Timeline
Error: 80070057, the parameter is incorrect. There was an unexpected error reported while trying to run QuickBooks with company file [path and name]
Error: 80070057 the parameter is incorrect" and "You do not have sufficient permissions to delete files...
If your Error 80070057 is different than the ones displayed, perform a new Search.
Why is this happening:
QuickBooks cannot read the company file because the QuickBooks file extension was changed or is the wrong type (.qbm, .qbb, .qbx).
This error can also occur during conversion or creation of a backup or portable company file if QuickBooks detects data damage in the company file.
This error may possibly occur if the QuickBooks installation is damaged.
This error can also be caused by attempting to open the portable company file (.qbm) without having QuickBooks open.
How to fix the problem:
Verify that the file extension displays company name.qbw and not a shortcut.
Copy the company file, change the extension to .qbm, .qbb, or .qbx, and follow the appropriate steps to open a portable file, backup, or accountant's review.
If the error occurs during the conversion or creation of a backup or portable company file, run the Verify utility to check the file for data damage. If it finds damage, run the Rebuild utility.
Repair the QuickBooks installation.
Uninstall, and then reinstall QuickBooks.
Sep 25, 2009 | Microsoft Windows XP Home Edition
How can i make quickbooks 2005 run on a vista laptop?
Here is how to load and activate Quickbooks 2005 on Vista...
First of all, if you already have an activated copy of QuickBooks 2005 on another computer open it and go to "help" "my license information" and print this out so you have the details needed for activating your reinstalled copy (you don't need a fresh activation key and you may have trouble getting one as QuickBooks 2005 is no longer supported by Intuit).
On your new Vista computer, insert the QuickBooks CD but cancel any program install windows that pop up. Go to my computer and find setup.exe on the CD, right click and select the option to "run as administrator"
Once installed, navigate to the QuickBooks folder on your hard drive (typically C:\Program Files\Intuit\QuickBooks) right click on QB32.exe and on the compatibility tab select both Disable visual themes" and "run as adminstrator". Now open this file to run QuickBooks and select "file" "Update QuickBooks" to download and install all updates. QuickBooks will not work properly until you have downloaded the updates, closed and reopened the program.
I had problems with activation but I got around this by unplugging my network cable so that I had no internet connection. If you run QuickBooks without an internet connection, when the screen pops up asking you to "activate" click next and the screen to enter your license details will appear. enter your details (printed out from your previous installation) and you are done. You can restore the internet connection and use QuickBooks 2005 normally.
Andrew
Jul 09, 2009 | Intuit QuickBooks: Pro 2005 for PC
How many copies should a copier produce before changing a drum
I bought a km1620 copier. but copied only A4 size paper. No longer paper can not print except A4 paper. how can I change copying system. And how can I count copy. pls. mail me.
mizan
Jun 12, 2009 | Kyocera Copystar CS-1620 Black and White...
HP Vista Pavilion and Quickbooks 2008
install a new fresh windows vista and then install your printers c6180 printer driver
Jan 28, 2009 | Computers & Internet
Xerox xe80 workcentre prints almost black copies
Hello sir; Just replace drum cartridge, it will take care your problem. GOOD LUCK!
Oct 31, 2008 | Xerox WorkCentre XD125F All-In-One Laser...
Black strips when printing
I'm having the same problem, with the black strip printing on the back of each copy i make... Its very annoying. the circlular lil rubber piece that helps the paper feed out of the machine is wet with black ink. theres about 5 lil rubber things that feed the paper out and ONLY one of those seems to be wet with black ink, so everytime i print, it appears on the opposite side of my document. If someone knows how to fiz this problem, PLEASE PLEASE get in contact with me. My name is Maria M. and you can reach me by e-mail smilz922@aol.com
Thanks
Maria M
May 17, 2008 | Canon Pixma MP500 All-In-One InkJet...
HP OfficeJet 6110 All-In-One InkJet Printer Logo
13 people viewed this question
Seeker5211
Seeker5211
