Question about Canon PIXMA MP600 all-In-One InkJet Printer
I am getting a paper jam in the outfeed message when there is no paper jam. I have rebooted the printer several times. Does not solve it. How do I get the printer error message to correct?
  • 1 more comment
  • hcarruthe829 Sep 14, 2010
    Paper output slot. The paper is jammed. Clear the paper and press OK
    Are you still working with me?
  • 10,515 Answers
Kindly mention the exact message that you saw?
Thanks!!
Posted on Sep 14, 2010
  • taran_2005
    taran_2005 Sep 14, 2010
    Thanks for your response!!
    Hold on...i am writing the solution :)
    Thanks!!
  • taran_2005
    Thanks for your response and patience!!
    To start with this is a common problem on this model after the paper jam. You could read different forums and details where we discuss the same. There are few things you could try. Unplug the printer for few minutes, say 15 minutes and then turn ON the machine.See, if that reset's the error.
    Again, have you checked that there is no paper jam? Have you checked the paper feed area at the back of the printer(right back side where the vertical feed tray is).Sometimes you may find a small sliver of paper sticking out of the intake slot or Buried beneath the large drive wheel could be a piece of plastic wrap from an ink cartridge.
    You could download the manual from the below link :-
    http://www.mediafire.com/?urdtnzdwunz
    Also use Compressed air to clean it from inside.You can get compressed air can at local superstore.
    If all those would not work, unfortunately this is a sensor error and the unit has to be send for repair.
    Let me know,if needed further assistance.
    Hope i helped you.
    Thanks for using ' Fixya ' and have a nice day!!
As soon as I started using recycled ink cartridges, I started getting a paper jam error on my printer. The control panel message instructs me to remove the back panel and clear paper jam. I've done this...
As soon as I started using recycled ink cartridges, I started getting a paper jam error on my printer. The control panel message instructs me to remove the back panel and clear paper jam. I've done this several times but there is no paper to clear and the message keeps coming back. I've tried turning of the printer and unplugging it to clear the memory, but that doesn't help. Could it be that the chip on the ink cartridge is messing with the printer's operating system?
Oct 14, 2010 | HP Photosmart C7250 All-In-One Thermal...
Paper won't feed into printer & output slot jam error message
reboot your pc.unplug cables make sure you remove papers jams located at the back of your printer
Jun 24, 2010 | Canon PIXMA MP610 InkJet Printer
Roller drags several sheets of paper and results in a paper jam
Open your printer and release jam paper then solve problem.
Apr 09, 2009 | Lexmark E322 Laser Printer
Paper jam message, but actually no paper jam
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Mar 25, 2009 | Lexmark X83 All-In-One InkJet Printer
Paper jam paper jam error message continues even no jam, have to feed by hand sever times before paper will feed into printer.
try this
alternative :
Dec 23, 2008 | Canon Pixma MP450 All-In-One InkJet...
I can`t solve paper jam.
try this, its probably a small part of jammed paper or then theres a problem with the pickup, try cleaning it.
alternative :
Dec 20, 2008 | Canon PIXMA iP1600 Printer
Paper Jam
try this
alternative :
Sep 21, 2008 | HP OfficeJet 4315 All-In-One InkJet...
Paper jam
give this a shot
alternative :
Jul 08, 2008 | Brother Multi-Function Center MFC-665CW...
Jam in Exit Area
On the top of the printer there is a button that you need to push down which releases the lock on the paper outfeed. If you put your right hand on the paper outfeed and pull up on it when pushing the button it will open and that just might be where the paper jam is located.
May 13, 2008 | Samsung CLP-500 Laser Printer
Paper Jam error message
try this
alternative :
Apr 02, 2008 | Dell 942 All-In-One InkJet Printer
Canon PIXMA MP600 all-In-One InkJet Printer Logo
247 people viewed this question
old marine
old marine
