Question about GE Profile Spectra JGBP90 Gas Kitchen Range
The oven spark is firing constantly, please advise how to stop it
  • 1 more comment
  • stuart725 Sep 14, 2010
    Hi I used the hair dryer but does not work. The one burner ignitor is still firing like crazy. How do I stop it. I gues it is most likely what you say. Please help
    Can you recommed who I can get in to replace the igniter. It's a GE profile. Any suggestion would help. Thank you.
    Thanks so much for your help
  • 10,515 Answers
You have to use the hair blower on all switches ,Take the knobs off and really dry it well Most of the time it works
If the problem persists, it could be a problem with spark module or ignitor.If they all ignite, but only burner continuously sparks, it is more often ignitor ( if it would crack, it could spark like this ) unless it is more likely a spark module.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Sep 14, 2010
  • taran_2005
    taran_2005 Sep 14, 2010
    Thanks for your response!!
    Unfortunately, in this case ignitor has to be replaced ( if ONLY burner continuously sparks ).
    Hope i helped you.
  • taran_2005
    It all depends on your location. This is not a very tough job, so if you could catch a local repair tech in and around you area , he would charge much less than what GE or any other major repair center would charge you. If you are unable to find a local tech, call GE at :-
    http://genet.geappliances.com/ServiceNet...
    Hope i helped you.
Why wont myoven stay off? I have to unplug it everytime because it turns itself back on and goes to the stay on setting?
The problem should be a melted wire of a melted control., either of which allows the electricity to flow constantly.
To prevent a fire, please stop using this appliance.
Mar 05, 2018 | Toaster Ovens
I have a 1991 Dodge Stealth Dual Overhead cams with no turbo. Vehicle will not run. Several test have been done. There is no mechanical or computer error that can be found. Please advise
Do you have spark? Fuel? Compression? Does it fire at all? Does it sometimes fire when you let go of the key? If you have spark, are the spark plugs dry or wet? Did it just stop running or has it been sitting? These are very important questions that need to be answered in order to narrow down the problem. With a vehicle of this age, you could have a dead distributor triggering coil that would not show up in a computer test.
Feb 17, 2011 | 1991 Dodge Stealth
Everytime i turn it on sparks fly
If they is any exposed metal in the cooking bay of the oven or grease it will cause it to spark and catch fire. If it is please clean the oven throughly. If it is sparking from the back the magnetron is bad and need to be replaced.
Aug 27, 2010 | Emerson 025806092806 Microwave Oven
My Neff U1721 element went with a bang. We have replaced before on 3 occasions successfully - but the elements have not lasted very long. On this occasion have replaced element - but not working. Please...
Hello Helen. You should not have to replace the elements often unless you are a commercial establishment using the ovens constantly. If you are commercial you may not have any thing wrong. Otherwise, I would recommend that you check the wiring that feeds the elements and those connections. If the connection to the element is loose you may be getting intermittent sparking which would shorten the life of the heating element. J.
Jul 31, 2010 | Neff U1721 Double circotherm Electric Oven
Sharp r-930ak microwave oven is sparking
A dirty or damaged wave guide cover can cause sparks, fire and noises. You can order a replacement wave guide cover from many appliance parts websites for less than $15 in many cases. It should fix the problem.
May 03, 2010 | Sharp R-930AK Convection/Microwave Oven
Grill ignition is sparking when the oven is on
if the grill is constant sparking when the oven was on and turns off when the oven is not in use then u either have a defective pcb/ht lead or electrode if it is self lighting or if you have to push in a button then this button or control will have a problem
Aug 21, 2009 | New World G70m Gas Double Oven
Ignitors keep firing by themselves after my aunt cleaned them 24 hours ago After she did the major cleaning of the stove I used the oven and it worked fine. I lit a burner (Probably front?) and the left...
If they ignitors worked properly before you aunt cleaned them, the problem could be with the way they were cleaned and what they were cleaned with. Please tell me how she cleaned them and with what. Also, had she cleaned them before without incurring any problems, or was this the first time she had cleaned them?
Dec 03, 2007 | DCS RGS-486GD Gas Kitchen Range
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
319 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
