Question about Canon MV920 Mini DV Digital Camcorder
My canon MV 920 handy cam does not start.. I have checked the battery and the connecting adapter as well which is absolutely fine.. It does not even charge or switch on when direct current is supplied removing the battery.. Please help
    Genius:
  • 1,812 Answers
This is usually caused by a failed component in the power circuit within the camera and can usually be repaired fairly inexpensively. However, it’s not a user serviceable problem and will need to be repaired qualified service technician.
My name is Rick and I’m a professional repair technician with over 20 years in the business and have repaired many of these. I’m semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Posted on Sep 14, 2010
Even with absolutely fresh batteries properly installed, I keep getting a "change the batteries" message, and then the camera shuts down. It worked fine for two years!
Peter,
Try using a Q-tip and some alcohol to clean the contacts inside the battery housing of the camera - it's possible there's enough build up to prevent a clean connection.
Thank you.
Mar 22, 2011 | Canon PowerShot A560 Digital Camera
I have an acer 5740G laptop to which when i am connecting the MV 920 cannon cam corder through the camera's port in to the laptop's USB port, the laptop does not recognise this as an external removable...
This type of camera usually downloads better with a Firewire (DV) connection. Some mini-DV cameras only use the USB connection for stills (if they have one) and can only download video by Firewire. This is because you have to play the tape into the computer, not just copy a file.
Most PCs have a USB port, but no Firewire port. Macs often have a Firewire port but may not have USB. With desktop Windows PCs, you can fit an add-on Firewire interface card. This comes with a driver for the card. If your laptop doesn't have a Firewire socket, then you are probably stuck.
Nov 07, 2010 | Canon MV920 Mini DV Digital Camcorder
How to chrge it?
You will need a charger like the one listed below. Just remove the battery and place it on the charger.
CA-920 Compact Power Adapter
This is the standard charger and power source for the GL2. It will charge one battery at a time.
Oct 03, 2010 | Canon GL1 Mini DV Digital Camcorder
I turned on my dc100 today and it powered on, then went off. It will not power back on, even with the adapter attached. Earlier I was getting a "set date and time" message
sounds like the power adapter is failing, have you got a multy-meter to test if your gettin a voltage out of the adapter, the adapter should have an output voltage printed on the side, Also if the adapter is faulty it wont charge the battery so in turn wont fire up your cam it will just show on for a few seconds till the battery drains again. if you take your adapter to the local electrical store they will fined you one thats the same amperage/voltage and the correct polarity.
Jan 21, 2010 | Canon DC100 DVD Camcorder
New 2008 MV F4 R will not start
trickle charge 16 hours on a 1-2 amper charger /after that keep battery charged regularly ie once weekly
Feb 01, 2009 | 2008 MV Agusta F4 1078RR
Canon mv800i fault
OK after searching the net to fix this problem and no one having the answer I decided to fix it my self.
My Canon MV 800i cam had the same fault to I took it to bits. Inside there’s the cams main board that has loads of ribbon cable connecting on to it from its bits like lens, power supply, viewfinder , cassette deek. I unplugged all of these and removed its main board and cleaned all the ribbon cables connecting end with isopropyl alcohol, you can use most electrical cleaners should do the some trick. Then just reassembled the cam and tested all fixed
Give that a go and see how you get on
Jul 31, 2008 | Computers & Internet
Hi-- This is actually a problem with the Canon LK-51B battery pack that goes with the iP90v portable printer. We've charged up the battery pack and all the lights have gone out, indicating full...
electronics should not be relied on to realy confirm u need to use a second battery pack to connect ur printer n see if the same thing will occure. i guess the battry inside d pack may be dead even though its a new one.
May 24, 2008 | Canon Office Equipment & Supplies
YH-920 problem
My napster YH-920 Doesnt switch on...what to do?
Feb 13, 2008 | Samsung Napster YH-920 MP3 Player
No picture in rec mode, cam switches off in 10sec
Try using the Dummie Battery and connect that end to charger.
This way you will know that you don't have battery problems.
atdlee@netzero.com
Dec 24, 2007 | Canon XL1S Mini DV Digital Camcorder
Digital camera
1. Check batteries.
2. Connect camera to an AC adapter.
3. Remove all batteries, disconnect AC adapter, wait a minute, reinsert batteries and reconnect adapter. Turn on camera.
Dec 01, 2007 | Cameras
Canon MV920 Mini DV Digital Camcorder Logo
98 people viewed this question
Top Canon Video Cameras Experts
Chance Miller
Lawrence Oravetz
abdul rauf
abdul rauf
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
