We are having lg wp 9032 top loading washing machine.it's drain selector is not working,that means the switch is slipping.that why the used water is not going out.may be the switch gone.where can i get a service person and also where i can get the spares for it.please kindly help me in this matter. N.Narasimharao
  • 1,056 Answers
Make sure first the there is no sock or something stucked in the drain pump.
Posted on Sep 14, 2010
LG 5kg fuzzy logic model WFT5005T Top Load and it keeps screening PE and I don't know what it means.
PE stands for Pressure Error. This washer is equipped with a water level pressure switch. As the machine fills, the pressure increases on the switch, at the set pressure, the switch cuts power to the water inlet valve and the water stops flowing into the washer. If the pressure switch fails to sense properly, or the water inlet valve fails to shut off the unit can overfill. This situation can also be caused if the machine does not drain properly. First, check to see if water ever enters the machine when it is turned off. If so, replace the water inlet valve. Next, check the drain line to be sure it's not clogged or kinked. Next, check to see if the drain pump is working properly and removing the water from the previous cycle. If all of those check out, you may need to replace the pressure switch.
Apr 23, 2017 | LG Washing Machines
WATER IS NOT DRAINING IN MY LG TOP LOADING WASHING MACHINE
The first thing I'd check is the water pump if the timer's working ok...
Mar 06, 2014 | Washing Machines
LG Intellowasher 7kg WD-14125RD shows DE error
DE is for a door lock error and you will need to replace the lock. Here is the part to order.
Dec 07, 2012 | LG WD-12126RD Front Load Washer / Dryer
Owner Manual fo LG WP-9032
You will need to type into your search engine 'LG manual' and you should be presented by a number of sources from where you can either download for free or have to pay- sorry don't know how much ;-0(
Hope this helps,
John C in SW France
Feb 07, 2011 | Washing Machines
Water gets drain cannot remain in the tub for wash ...type of my washing machine is LG WP 9031 top loading semi automatic..
The drain is pull the knob which will pull up the drain valve. So if this is not working then the connecting bowden is broken and is not connecting the link to the bottom drain valve.
Look at the bottom and connect. Clean the drain valve, if choked.
Sep 14, 2010 | Washing Machines
Water keeps draining LG WF-561SPP top loader
If the cycle does not stop draining that is usually because of a faulty membrane switch that controls the water level in your appliance.
The faulty sensor cause the machine to think that there is still water inside, even when water has drained completely.
Apr 02, 2009 | LG WM3677HW 3.7 cu.ft. Front Load Washer...
Water is not draining out
Check that the drain hose is not clogged.
Access to the drain pump and check the drain pump intake, that is probably filled with debris.
Ensure that the drain pump is working, the pump should be energized directly by a technician to test it.
If the drain pump is fine , and you already tested water level switch, then it is either a bad control board, or a lose contact on the drain pump wiring harness to control.
Feb 18, 2009 | LG WM2487H Front Load Washer
GE Top Load Washing Machine -- Agitator will not cycle
Agitator's don't spin on wash cycle.
I would suggest washing the clothes without soap until they rinse clear. If you have hard water, the soap will not easily rinse out of clothes, or off of you when you use soap to wash or shower.
Reduce the amount of soap you use in each wash if this is the case. It sounds like your washing machine is working right.
Jan 26, 2009 | GE WBSR3140DW Top Load Washer
LG WM2233H* Clogged drain
After draining and cleaning filter, reset washer--Unplug unit and hold Start (selector) button for 10 seconds. Plug unit in and restart.
Oct 28, 2008 | LG WM2277H Front Load Washer
LG Toploader Wash cycle won't work
check for the water seal first if it is leaking! if it does, then it might just be the one causing slipping.
Nov 13, 2007 | LG WFT1071TP Top Load Washer
Washing Machines Logo
71 people viewed this question
Top Washing Machines Experts
