My Element ELETT221 has a USB connector on the back panel with no information in the manual or in onscreen menus about how it works or how I can access it. I plugged in a thumb drive with photos, videos and MP3 files on it, the busy light on the drive flickered for a few seconds, but nothing showed up on the screen. How do I use it or what is it for? Is it a service access port?
Delav3
  • 8 Answers
SOURCE: USB Storage
Is there an indicator light on the drive? If so, is it on?
Posted on Oct 05, 2007
SOURCE: Not being recognized on any computer
The only support available for this product is located at www.samsungsemi.com
You must select the "contact us" option at the bottom of the page next to "site map" and send them your problem.
Posted on Feb 05, 2008
vicer
  • 32 Answers
SOURCE: Philips DVP 5982 DVD Player USB issues
try formating the thumb drive with a fat32 partition before using it in the dvd player
Posted on Mar 16, 2008
SOURCE: This morning the screen is black...
The black screen with audio working ok is the inverter card.
Just replaced mine. It is CMO part number VIT70002.00
The inverter provides the high voltage necessary to drive the cold cathode lighting.
A new card is about $180 but shud save having to dump the set.
Card is located on left side of the display (as viewed from the back).
Howard
Posted on Aug 12, 2008
  • 60 Answers
SOURCE: My tv screen keeps flickering on and off
  1. Need Model # of set and the brand so I know if its a plasma, LCD, or CRT set keep me posted
Posted on Aug 23, 2009
How do i view photos on a flash drive?
If your TV has a suitable USB port, and the USB drive is formatted correctly (usually FAT 12, FAT16 or FAT32) then use the TV menus to navigate to the flash drive and then follow the onscreen prompts.
Sep 09, 2014 | Televison & Video
Zenith z50px2d stuck in zoom how do i adjust
Read the manual about changing the Aspect Ratio. There'll be a button for it on the remote and also an option to change it via the TV's onscreen menus.
Sep 06, 2014 | Zenith Z50PX2D 50 in. Plasma HDTV
Can I update codecs for my lg bd610 to play all avi files
Go to the http://www.lg.com/us/support-product/lg-BD610 Then enter the model in the search on the lower left side (IF YOURS IS DIFFERENT THAN A BD610). Look for "Software update" under downloads "Manual". Get the download and transfer it to a USB drive/memory stick. Follow your machines instructions in the onscreen menus.
Jul 24, 2012 | LG Televison & Video
Reset pixels on panasonic HD tv
Unplug the set for at leasat ten minuts, then after plugging back in re program it following the onscreen menus to get the settings you wish
Mar 25, 2012 | Panasonic Viera TH-50PX80U Plasma TV
I can't find the usb comnector for my wireless mouse and keyboard do my new HP 310 touchsmart desktop...where is that thing? Thanks
this is the your work let the follow of instruction ..
Front USB connectors removal
  1. Review the safety considerations before performing the steps listed below by clicking on the following link: Click here to view the precautions . CAUTION: Failure to comply with the precautions could result in damage to your product or loss of data.
  2. Power down the server.
  3. Remove the bezel.
  4. Remove the access panel. Click here for instructions on how to remove the access panel .
  5. Disconnect the front USB cable from the system board and unroute it.
  6. Remove the two Torx T-15 screws that secure the Front USB connectors to the chassis.
  7. Remove the Front USB connectors from the chassis and thread the cable out of the opening in the chassis.
Front USB connectors replacement
  1. Thread the front USB cable through the opening in the chassis and insert the Front USB connectors to the chassis, ensuring that the key aligns with the slot.
  2. Replace the two Torx T-15 screws that secure the Front USB connectors to the chassis.
  3. Route the front USB cable to the system board and reconnect it to the system board.
  4. Replace the access panel. Click here for instructions on how to replace the access panel .
  5. Replace the bezel.
Apr 17, 2011 | HP Televison & Video
No ELETT221 will not display computer.! Windows Vista 32 bit run by Toshiba Satellite
My ELETT221 works awsome at 1920x1080 from the VGA port. You must not have configured your 2nd monitor correctly.
Apr 22, 2010 | Televison & Video
Show me where the printer should connect to the back of dimension 3000 tower windows xp
google for dell dimension 3000 and you find the manuall see below i found it on :
http://support.dell.com/support/edocs/SYSTEMS/dim3000/en/SM/index.htm
Connectors
External connectors:
Serial
9-pin connector; 16550C-compatible
Parallel
25-hole connector (bidirectional)
Video
15-hole connector
Network adapter
RJ45 connector
PS/2 (keyboard and mouse)
6-pin mini-DIN
USB
two front-panel and four back-panel USB 2.0–compliant connectors
Audio
three connectors for line-in, line-out, and microphone; one front-panel connector for headphones
Mar 12, 2010 | Dell Computers & Internet
I have a 26 in insignia tv i need i need help. i do not know how to turn off the subtitles some plz help me
Go to Setup in the onscreen menus, then select Captions and use the arrow keys to highlight OFF; press PLAY to select. Press the back arrow, then Exit. More information can be found in the owner's manual.
Dec 20, 2009 | Insignia 26 in. LCD Flat-Panel HDTV
Onscreen volume display not showing up naymore
Try this out:
Click the Start button on Windows Taskbar located at the bottom
side of the screen and then select Programs, Hot Key Manager,
Configuration from the menus that appear.
To enable onscreen volume control message,
check the Show volume controls onscreen checkbox.
This is the recipe for the 2000-model, but I believe it should be the same for the 5000.
The manual for the 5000 can be found here: http://support.benq.com/files/Joybook/Manual/5000_English.pdf
Dec 03, 2008 | BenQ Joybook 5000U Notebook
Surround speakers don't work
Hello barstep,
Let's go through some steps that will help alleviate your problem. We'll start from the simple to the not so obvious:
1.- Perform a visual inspection on the back of the receiver and verify that all speaker connections (specially the surrounds) are not loose, shorting out another connection or are pushed too deep into the speaker connector so the wire insulation prevents proper contact. If this is not the problem then...
2.- Get into your receiver's "Manual Setup" and verify that your surround speakers are set either to "SML" or "LRG" but not "NONE".
3.- Verify the receiver is not in "Straight" mode, shown on the receiver's display. I f so, press the "Straight" front panel button until indication disappears.
Your owner's manual can give you detailed information to access the setup menus.
Hope this information helps. Let me know if we can further assist you.
cancerags
Dec 30, 2007 | Audio Players & Recorders
Televison & Video Logo
503 people viewed this question
Top Televison & Video Experts
