Question about Electrolux EOB5630 Ultrafan Electric Single Oven
Electrolux EOB5630 oven cuts out
My oven will work fine & then cuts out half way through cooking, the fan stops working, so does the internal light, the grill also cuts out. it starts working again after around 20 mins after being switched off, but then cuts out again. any soloutions
  • 2 more comments
  • Anonymous Jul 11, 2008
    Same as previous person - could it be the thermal cutout?
    It works the next day but then cuts out after being on for a while.
  • ironic Aug 03, 2008
    Oven cuts out after running at temp selected. all functions not responing. Did come back on after about half an hour. However, last time turned itself off but back fan remained on. Could only be stopped by disconnecting supply at wall switch. Have found over heated component that is wired beteen function selctor switch and timer panel. This disintegrated when disassembled. Do not know what its called or its function. It consisted of two thin plates separated by an insulator that were connected acroos the top. Could this be a overheating safety device?
  • jadie123 Aug 11, 2008
    My oven cuts out after 15minutes as well as the internal light. Can you suggest a solution.
  • davewatty Jan 21, 2009
    same problem as above
    Guru:
  • 93 Answers
First thing you would want to check is, make sure you don't have any issues with the electrical connection to the oven first. Possible cuircut breaker issue.
Check these things first, you are probably going to find a loose connection somewhere. If that doesn't fix your problem.
Let me know and we can go from there.
Posted on May 15, 2008
What is the diference between an EOB5630, and EOB5630B, an EOB5630x etc. I have an EOB5630 oven fan element to replace but need to be sure I get the right one. Are these models interchangeable??
I would guess they are the same element in Australia the last letter in electrolux ranges signifies the color or type of clock fitted the B would be for Black ovens the X would be a multi function oven they all have the same fan element
May 29, 2011 | Electrolux EOB5630 Ultrafan Electric...
Eob5630w oven shutting down before set temp isreaced aprox 198c also cooling fan not comingon
The reason the oven is shutting down is because it is overheating due to the cooling fan not working, and a safety thermostat is turning the oven off.
You need to repair or replace the exterior cooling fan.
Jan 05, 2011 | Electrolux EOB5630 Ultrafan Electric...
Electrolux EOB5630X. Oven works fine for about 20-30mins then cuts out (light in oven turns off and grill will not work at this time either). Will work fine again after temp in oven cools but cuts out...
the electronics are heating up and cutting out.that cold be a bad clock assy. or there's a fan in there that could be bad or i've seen on some models there's a screen in where the fan is,it gets clogged with dust and the air can't blow to cool down the electronics.if it is the fan and you keep using it like that it will take out the computer board or clock assy. same part.
Nov 13, 2017 | Electrolux EOB5630 Ultrafan Electric...
Using my EOB5630 oven went bang
the fan element will have shorted out. if you remove the panel from inside the oven you may see where the circular fan has shorted. It will have blown a fuse poss in a plug if connected that way.or tripped a circuit breaker. remember to set the clock when power is restored as it wont work until you do.
Jul 29, 2010 | Electrolux EOB5630 Ultrafan Electric...
Our electrolux eob5630 oven keeps turning off
its the thermal cut out. replace it. ISOLATE oven.
slide oven out a few inches, remove knobs, remove front panel(two screws)
you will only be able to pull panel 3-4" due to wires.
Cutout has 2 blue and 2 white wires..
you may need to snip a couple of cable ties.
Put new cutout in one wire at time( easy to forget where they go)
Tidy up wires. Put cover back. Secure oven in hole.
Turn on power. Reset clock(otherwise won't work)
Done 10 minute job
Jul 19, 2009 | Electrolux EOB5630 Ultrafan Electric...
Electrolux oven wont heat up after power cut
hiya
sounds like the fan element could have blown, causing the electrics to trip out. best thing to do is remove all the racking
and then the rear panel that covers the fan and element. if he element has blown most of the time it will be visible.
hope this helps
please dont forget to rate the helpfulness of this reply thanks kj
Aug 03, 2008 | Electrolux EOB6636X Ultrafan Electric...
The oven stops working
if your light also cuts out intermittenly sounds like a loose connection, when heated moves and loses contact, def check wiring
Mar 01, 2008 | Electrolux EOB5630 Ultrafan Electric...
Overheating?
yes - it is cutting out on overheat. there are two fans - which one was replaced - cavity fan or casing fan?
possible reasons are:
faulty casing fan
not enough ventilation
faulty overheat stat
faulty fan stat
oven operating stat faulty but you would be burning your cooking in this case
Dec 21, 2007 | Electrolux EOB5665G Ultrafan Electric...
Electrolux EOB5630
Not sure that I can help but will certainly try. You need to check to see if the power is getting to the oven. As the grill, light and fan are working it seems that it is. With the Oven not heating up I would suggest that it is possibly the Oven Element. Usually to check these you need to remove the cover inside the oven and also the back cover. You will probably find the power is getting to the element but the element is not working and needs replacing. Before removing it MAKE SURE YOU TURN OFF THE POWER TO THE OVEN. Should only be 2 or 3 wires going to the element which will need to be removed before removal. Usually only a couple of screws hold the element in and once removed you may have to wiggle the element a little to get it out. Replacement is just a reversal of the removal procedure. I had to replace the one in our oven 2 weeks ago as we had the same problem. It is fine now and was only the element. Just MAKE SURE you TURN OFF THE POWER before removing the element. Hope this helps.
regards
Bryan
Nov 16, 2007 | Electrolux EOB6636X Ultrafan Electric...
Electrolux EOB5630 Ultrafan Electric Single Oven Logo
946 people viewed this question
Top Electrolux Ovens Experts
ashburton
Mack Baxter
Are you an Electrolux Oven Expert? Answer questions, earn points and help others
