Question about Sony VAIO PCV-RS720G (027242658103) PC Desktop
Removed virus and system will not boot. can i reinstall software from the hard drive without a recovery disk
  • 2,427 Answers
Yes you can these system comes with built in recovery partitions,,
1.) restart system,,
2.) look at boot screen it will tell u press a certin key to enter system recovery,, press that key and follow on screen instructions..
another thing u can try is to keep pressing F8 when u turn the system on and select system restore / rescue or repair,, follow on screen instructions..
Posted on Sep 14, 2010
My Sony Vaio laptop has no operating system because my hard drive died. I have a brand new 160 GB SATA hard drive. Tried reinstallation of Operating System with Sony's recovery disks, did not work. Also...
new hard drive needs to be formatted before software can be installed on the hard drive. you need to use advanced setting on the software installation, and then format hard drive.
Jul 31, 2017 | Sony VAIO VGN-AR190G Notebook
Boot device not found, insert a boot disk and press any key
The "no bootable devices found" error can create headaches, as well as occasional heartache if you're a laptop user. This error appears when your computer is unable to find a device or file required for normal operation. It could indicate one of three issues: hard drive failure, software error or motherboard malfunction. Any of these potential problems can render your laptop useless. Hard drive failure or software errors can lead to data loss, which can cause anguish and catastrophe, depending on the files business information, family photos, student projects at risk.
Hard Drive Failure
The interior of a hard drive is akin to a turntable. Most hard drives contain two to three discs, known as platters, which are similar to records. These platters are read and written on by a tiny needle called the read/write head, similar to the arm and needle on a turntable. When a hard drive functions properly, the platters spin and the read/write head accesses the files necessary to boot your computer. Improper function of any of these physical pieces can cause a mechanical failure and result in the "no bootable devices" error. Software Error
In rare instances, a software problem more specifically, a particularly nasty virus may cause the "no bootable devices" error.
Most often, if a virus attacks and corrupts your system, your computer can still detect the hard drive and operating system, and you'll see some attempt at a normal boot.
If a virus attacks certain system and startup files, however, they may not be detectable next time you boot your computer, thus causing you to see "no bootable devices."
This may also happen if you are manually deleting files from your computer and accidentally delete system files.
Motherboard
Sometimes individual components of your laptop's motherboard malfunction, which can cause problems ranging from loss of wireless capabilities to inability to detect an external power source.
If the components that detect your hard drive fail, your laptop is unable to receive signals from the hard drive and therefore may display the "no bootable devices" error.
Repair
Fixing a "no bootable devices" error can prove costly.
If motherboard failure caused the error, you're probably better off purchasing a new laptop; unless it's under warranty; the average motherboard replacement costs $250 to $500.
You can reinstall your operating system to resolve software errors, which is fairly inexpensive by computer repair standards, costing $80 to $130 dollars, but this step may also overwrite your existing data.
In some cases, data may prove so badly corrupted it's not salvageable.
If you can recover it, however, that raises your repair costs. additional fee.
If hard drive failure caused your "no bootable devices" error, you can replace the drive.
If you need to recover data from a malfunctioning hard drive, send it to a clean room for recovery.
In a clean room, technicians disassemble your hard drive and image each platter; this kind of data recovery is extremely expensive, costing up to $2000 depending on the work involved.
Prevention
There is no way to guarantee you will never receive a "no bootable devices" error, but there are some steps you can take to help prevent it from happening.
Keep your laptop on a flat surface when using it, and avoid any bumps that may cause the hard drive's read/write mechanism to lock up.
Avoid transporting your laptop while the hard drive is active; turn your computer off while traveling.
Additionally, regularly run an anti-malware program to catch and remove viruses or spyware before they cause system problems.
http://www.upgradenrepair.com/Issues/N/nobootabledevicefound.htm
also you might
HP laptop no bootable devices found
Turn on your HP laptop with Windows Vista or Windows 7 and press the "Esc" key repeatedly to access the startup Menu. Press "F10" to access the BIOS.
Press "F9" to restore the BIOS to its default settings. Press "Enter" to verify that you want to restore the BIOS default settings.
Press "F10" to save your changes and exit the BIOS. Press "Enter" to confirm that you want to save the BIOS changes and continue booting up the laptop.
HP Hard Disk Test
Hold the Power button down for 15 seconds when the laptop is turned on to turn off the laptop.
Press the Power button again to turn on the laptop and press the "Esc" key repeatedly to access the startup Menu.
Press "F2" to access the System Diagnostics.
Click "Hard Disk Test" to begin testing the hard drive.
If "Pass" is displayed after all of the tests then the program fixed the error.
If "Fail" is displayed after any of the tests, proceed to Section 3 if you are using Windows Vista and Section 4 if you are using Windows 7.
Recover Windows Vista Factory Settings
Click "Start," "All Programs," "Recovery Manager" and "Recovery Manager" again to open the HP Recovery Manager.
Click "Advanced Options," then click "System Recovery" and "Next."
The laptop will restart and will boot up to the HP Recovery Manager.
Click "System Recovery" and click "Next."
Click "No" when asked if you want to use Microsoft System Restore and click "Next."
Select "Recover without backing up your files" and click "Next."
Click "Next" to begin the recovery process.
When the process is finished the laptop will restart and boot to the Windows Vista setup screen.
Recover Windows 7 Factory Settings
Click "System Recovery."
The laptop will restart and will boot to HP Recovery Manager. Click "System Recovery," then click "Next."
Click "Recover without backing up your files" and click "Next."
When the process is finished the laptop will restart and boot to the Windows 7 setup screen.
Jun 26, 2013 | Acer Aspire One PC Notebook
As soon as i start the computer, it does that... I cant acces the recovery menu, and i need to recover it to defeult
It looks like a job for your operating system disk in the CD player! Put it in and boot from it going into repair disk mode.
Jan 13, 2013 | Computers & Internet
How to format my hard drive in dos
Rita,
Most computer recovery disks will perform the formatting for you. (This depends on the Manufacturer and Model though...)
If you put the recovery disk into the computer CD/DVD Drive and restart the computer - to boot to the disk, it should launch the recovery process and warn you that the hard drive will be erased and all data will be lost. This warning step is the recovery disks way of informing you that it will format the drive.
To boot to the CD/DVD you will need to tell the computer to do that. When the computer first turns on, you should see a brief message at the very beginning of the boot up process. The message will say something like: "Press Del for Boot Device" or "Press F12 for Boot Menu" or something of this sort. If your recovery disk is in the drive and you can get to the boot menu by pressing the key the computer prompts you to press, then you should be able to start up with that recovery disk.
Allowing the recovery disk to run through it's full process should format the hard drive and set your computer straight.
Make sure to run all of your updates once the recovery is complete and also make sure to install and update a good anti-virus software of some sort.
Nov 19, 2011 | Computers & Internet
My operating system is corrupted by a virus i tried to slave my hard drive but i can only see my hard drive in bios and i cannot see it in my local disk drive and im hearing clicking sound inside my hard...
Try to boot from your OS cd or recovery disc. Run the disk check software and see if your hard disk is mechanically ok or it crashed. If your hard disk is mechanically functional then run virus check on your hard disk. This will clean all the virus infections. And you will be alright hopefully.
If your hard disk's boot sector is damaged you may want to format the hard disk and place the boot sector in another portion of hard drive.
Nov 07, 2010 | Samsung 250GB HD250HJ SATA II 300 7200rpm...
Stop 0x00000024 (0x00190203, 0x82F8FA28, 0x0000102, 0x 00000000) appears on my screen. Blue background. What can I do to repair this?
Your system has suffered an unrecoverable error. Either vital operating system files have been corrupted, deleted or overwritten or your hard drive has failed. I suggest reformatting the drive and reloading the operating system from scratch. This can also be cause by some virus infections currently in the wild ( viruses that are currently circulating the internet) so make sure you boot from a system disk and reformat the drive or drives from this boot disk. Sorry but you have very few chances of a successful recovery from this without reinstalling your operating system.
May 21, 2010 | Dell Dimension 2400 PC Desktop
Emachine w3650 recovery disks....
The recover section will allow her to restore from the recover partion as long as the recover partition has not been removed.
Jan 09, 2009 | HP Compaq Presario SR1620NX...
I have a bad virus and need to crash my hard driveand relaod
There is no virus in existence other then bios viruses that can survive a reformat restore.
find your restore disks or call the original manufacturer to obtain the original software.
if you do not have a name brand machine. you will need to reformat yourself and re install the OS manually.
May 01, 2008 | Computers & Internet
Sony VAIO PCV-RS720G (027242658103) PC Desktop Logo
102 people viewed this question
Top Sony Computers & Internet Experts
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
