Question about Honeywell Programmable Thermostat Heater
Honeywell junction Box and QE2 Programmer
I really need your help.
I have 2 Tower motorized valve; fully pumped boiler and when calling for hot water only, the valve does not open at all; I know the valve is not faulty as I have replaced it once. The Central Heating side is perfect.
I have connected the Towerchron QE2 to a Honeywell Sundial Plan Wiring Centre Part number 42005748-001.
Without going into too much details, I connected as follow
Towerchron QE2 Honeywell Programmer Block
Live Brown L
Neutral Blue N
Earth Gre/Yel E
CH On(T4) Gray CH On (Next to E)
HW On(T3) Black HW On
I hope you are able to help.
Many Thanks and Regards
Mehdi
  • Mehdi_1971 May 15, 2008
    Towerchron Honeywell Programmer Block
    Live Brown L
    Neutral Blue N
    Earth Gre/Yel E
  • Honeywell Master
  • 3,239 Answers
Hi check the wiring to the cylinder stat is there power to it then is it going to the valve
Posted on Feb 18, 2010
Boiler not coming on, programmer constantly flickers on/off
if voltage from transformer ok check to pressure switch bad or loose wire
Aug 01, 2016 | Honeywell Water Heaters
How to use Central Heating only on an IDEAL W2000 CF50 boiler
you should have a programmer that will let you have the hot water and heating on or off . You could have a motor rised valve on the system which controls both . depends on what system you have . Fully pumped of just pumped on the heating side .
Jun 14, 2017 | Water Heaters
My Honeywell ST 6400C won't heat the hot water the light comes on but pump doesn't run or boiler fire. But does work on C/Heating.I can get hot water only by running the C/H and manually opening the hot...
it sounds like the motor in the motorised valve is not working on some models you can just change the head /motor , check cylinderstat (hot water stat) is working
Dec 14, 2010 | Honeywell Heating & Cooling
I have a red and a white wire but the heater wont
It sounds like you have at least 2 zones in your system. If this is a normal hot water boiler system with zone valves. When you have your thermostat call for heat it closes the 24 volt circuit that then energizes the motorized zone valve for that thermostat. In that motorized zone valve there is an end switch that will close and complete the circuit to the boiler. Zone valves when they start to clog up with mineralization will not allow the motor to go far enough to close the end switch, so then the boiler and circulating pump will not come on. If this is the case then you need to have the zone valve replaced.
Also make sure your wires at the thermostat are connected correctly. One thing you could also check at the thermostat to make sure it works or not is to jumper the 2 wires and see if your system starts up or not. If the system starts up then the thermostat or its subbase is defective. Hope I was of help to you!! Good luck!!
Nov 29, 2009 | Honeywell Programmable Thermostat Heater
Cannot get central heating working,for honeywell ST6400 programme
with y plan 3 connections on programmer HW on HW off CH on HW on to cylinder stat then HW call to Orange on Mvalve to power boiler and pump HW off to grey wire on Mvalve to close hot water CH to room stat common then heating call to white on Mvalve
Jun 13, 2009 | Honeywell Programmable Thermostat Heater
Cant turn heating off
do you have a separate or built in programmer? if itis separate ISOLATE MAINS undo the screws on the bottom of programmr and checkthat ther are no loose wires ( make a note of where they go for future ref. ). If wires OK check that the valves are working switchoff HW and Heating switch one on at a time and check that each valve is opening and closing and that the boiler and pump fires up ( it could b the micro-switch in the valve is broke! )
Sep 06, 2008 | Honeywell Programmable Thermostat Heater
Honeywell ST6400C programmer
Hi yes sound like it not working on hot water only it would check ou the wiring on this side
Jul 25, 2008 | Honeywell Programmable Thermostat Heater
Honeywell programmer gone dead
lift the face plate off and change the batteries
Jul 07, 2017 | Honeywell 2-way Oscillating Ceramic Heater
Heating & Cooling Logo
454 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
