Question about HP Photosmart 2410 All-In-One InkJet Printer
How to connect to an HP p650f computer - HP Photosmart 2410 All-In-One InkJet Printer
    Director Badge:
    Uploaded 100 video answers.
  • HP Master
  • 685 Answers
How to install depends on what operating system you're using. There are a couple options on this page that should help you.
http://h10025.www1.hp.com/ewfrf/wc/documentSubCategory?tmp_rule=45762&tmp_task=setupCategory&lc=en&dlc=en&cc=us&product=303753&lang=en
Posted on Sep 14, 2010
How could I connect my home WiFi to my HP computer
wifi is not a proxy,go into your internet settings and change it to connect automatically,not proxy
May 30, 2015 | HP Computers & Internet
I can't figure out how to connect my hp computer to a wireless brother printer
you need a wireless board in your computer you can get them at a computer store read the instr. when puting it in ok
Dec 14, 2013 | HP Computers & Internet
Officejet j3600 seres printer driver
Usually in Hp Injet Printer you should not connect the hardware first. Please install the software provide along with the printer and connect the printer only when the computer ask you to. Hah! while connecting do not forget to power on the printer first
Jul 15, 2010 | Computers & Internet
Connecting the HP OfficeJet 6500 to wired & wireless computers
Use the disk that came with the printer and install the software in both the computers based on the os installed in the individual computers, ping the ip address of the printer from both the computers, and then test for the functionality
Jul 13, 2010 | HP Officejet 6500 Wireless All-in-One...
Dell speakers w/ HP computer - connection failure
Your HP computer may need the Drivers from the Dell Speakers to work properly.
Jun 19, 2010 | Dell A215 Computer Speakers
Photosmart 3210 error 0xc18a0207 will not print
hi there,
The HP All-in-One does not print
Solution
For information on network communication problems or
communication problems involving a memory card, PictBridge camera, or storage
device, see the onscreen HP Image Zone Help. For more information on the
HP Image Zone Help, see Use the onscreen Help.
If your HP All-in-One and computer are USB-connected and are not
communicating with each other, try the following:
● Look at the color graphics display on the HP All-in-One. If the color graphics
display is blank and the On button is not lit, the HP All-in-One is turned off.
Make sure the power cord is firmly connected to the HP All-in-One and
plugged into a power outlet. Press the On button to turn on the HP All-in-One.
● Check the USB cable. If you are using an older cable, it might not be working
properly. Try connecting it to another product to see if the USB cable works.
If you experience problems, the USB cable might need to be replaced. Also
verify that the cable does not exceed 3 meters (9.8 feet) in length.
● Make sure your computer is USB ready. Some operating systems, such as
Windows 95 and Windows NT, do not support USB connections. Check the
documentation that came with your operating system for more information.
● Check the connection from your HP All-in-One to your computer. Verify that
the USB cable is securely plugged into the USB port on the back of your
HP All-in-One. Make sure the other end of the USB cable is plugged into a
USB port on your computer. After the cable is connected properly, turn your
HP All-in-One off and then on again.
● If you are connecting the HP All-in-One through a USB hub, make sure the
hub is turned on. If the hub is on, try connecting directly to your computer.
● Make sure the USB port speed setting on your HP All-in-One is compatible
with the USB port speed of your computer. You might need to change the
rear USB port speed from High Speed (USB 2.0) to Full Speed (USB 1.1).
For more information, see Connect using a USB cable.
● Try printing from a different application or a different file to determine
whether or not it is the file causing the printing issue.
● Check other printers or scanners. You might need to disconnect older
products from your computer.
● If your HP All-in-One is networked, see the onscreen HP Image Zone Help
that came with your HP All-in-One. For more information on the HP Image
Zone Help
● Try connecting the USB cable to another USB port on your computer. After
you check the connections, try restarting your computer. Turn your HP All-in-
● If necessary, remove and then install the HP Image Zone software again.
For more information, see Uninstall and reinstall the software.
For more information on setting up your HP All-in-One and connecting it to your
computer, see the Setup Guide that came with your HP All-in-One.
Hope this helps.
Please rate my response.
Thanks
Have a good day.
Dec 03, 2009 | HP Photosmart 3210 Printer
Cannot access the internet
I have looked at and reviewed your problem with your HP laptop DV6700Z and have the fallowing for you to aces.
First, if you are trying to access the internet via wireless, wait until you have established and wired connection.
If the blue light comes on in the front panel, the wireless is working, if not, you have a problem with the wireless modem.
Run a wire from your laptop to your modem and enter your my network, choose setup a internet connection.
Try to make a internet connection. Once you have established a connection, you can setup your wireless connection.
Hope this has helped you.
Sep 28, 2009 | HP Pavilion DV6700Z Notebook
I have an acer cpu connected to my hp monitor with built in speakers...but I have no sound?
That is a common problem. You need to purchase some new speakers from your local Radio Shack or computer store.Plug them into your cpu. Very cheap fix about $10. The mix and match connection of the HP and Acer never seems to work. The HP monitor will work with the Hp computers but not others.
Aug 15, 2009 | Acer (90.18612.36B) Computer Speakers
I'd like to connect my HP laptop to Yamaha 663 receiver
Connect your S-video output from the computer to an empty S-video input on the receiver. Connect your speaker output from computer to analog audio input on the receiver using a 1/8" stereo connector to RCA patch cable. You may have to set your computer to output video to the S-video jack, consult your HP documentation for instructions.
Dec 28, 2008 | Yamaha RX-V663 Receiver
Hooking up a second computer
If your HP computer is connected with a wire to the router, you don't need to run or install the setup CD of the router you just need to connect the HP computer to the router with an ethernet cable and restart the HP computer and internet should already be working fine, But if your Hp computer is going to work wirelessly with the router meaning the HP will not be connected with a wire to the router, You just need to connect to the wireless network of your router if your not familiar with that I will advice you to call Linksys tech support so one of their tech can walk you through with that process they are open 24/7 this is the number 800-3267114.........
Hope that helps............
Sep 23, 2008 | Linksys Wireless-G WRT54GS Router...
HP Photosmart 2410 All-In-One InkJet Printer Logo
42 people viewed this question
Seeker5211
Seeker5211
