Question about Samsung Syncmaster 192N 19" LCD Monitor
Can't find the place to put in speakers for syncmaster 192n monitor
  • 732 Answers
Lemoncaketre, 192N is basic VGA only type monitor!!!! No AUDIO capabilities!! Use a set of external speakers for audio!!!
12fixlouie
Posted on Sep 14, 2010
My monitor was working fine, then this morning it appears to have no power, even though it is plugged in and nothing has changed.
Can be many different problems. check the outlet and ensure the monitor and computer are properly connected.
Sep 08, 2013 | Samsung Syncmaster 192N 19" LCD Monitor
Samsung Monitor 192N light turns green when powered on then goes out after few seconds
this usually means the monitor is not getting a signal
  • i would check the hdmi/dvi/vga cable connections dirk_s.jpg
    both on the back of the pc and on the back of the monitor.
  • if the connections are tight, and plugged in well, maybe try and connect it to a second computer or laptop.
    • If it works the problem probably lies with your gfx card in your computer (verify this by trying another monitor on it)
  • If it doesn't work on those i would try and replace the aforementioned cable (usually pretty cheap)
  • if the problem still persists the monitor would probably need to be replaced as its defective.
Feb 28, 2011 | Samsung Syncmaster 192N 19" LCD Monitor
After several hours of inactivity, the screen on my SyncMaster 192n goes black, and the only way to turn it back on is by hard re-booting my computer. Sometimes even ctrl-alt-del doesn't work, and I have...
My guess is your video card driver has been altered and is causing the problem. Try rolling back the driver before reinstalling the monitor. Here is a link to the manual for your monitor: http://www.flatmonitors.com/Samsung170N.pdf
From the above manual: "The PowerSaver system operates with a VESA DPMS compliant video card installed in your computer. Use a software utility installed on your computer to set up this feature".
FFFF
Mar 18, 2017 | Samsung Syncmaster 192N 19" LCD Monitor
My Monitor samsung syncmaster flashes and like the light of the controls as someone to turn off and on
You need to open it up and inspect he caps in the power supply, look for bad caps with bulging tops or seals. See example of failed SAMSUNG monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Post back what you find so we can guide you further.
Mar 11, 2010 | Samsung Syncmaster 192N 19" LCD Monitor
The control button on the front on the monitor are showing in the locked position
press all buttons on the monitor and keep pressed until;l unlocked massage appeared
Mar 03, 2010 | Samsung Syncmaster 192N 19" LCD Monitor
I have an old Samsung 192N LCD computer monitor, and I have been having problems with it. There is a large black, vertical bar about the size of my thumb on the side of the monitor. I don't have a cable to...
you need to repir the power supply and replace the screen. the power supply may have had bad capacitors on it . crowned or leaking. it will be cheaper to replace the monitor with a preowned on rather than repair it
Dec 25, 2009 | Samsung Syncmaster 192N 19" LCD Monitor
My three year old Samsung SyncMaster 192n keeps turning off. If I unplug the power supply and plug it back in it will turn on for a while. Any suggestions?
You need to replace either the caps or the inverter board. You may require an assistance from a repair person in replacing it. Check this link so that you could see how the inverter board looks like:
http://www.shopjimmy.com/catalogsearch/result/index/?q=inverter+boards&stock=all
Have a good one!
Jun 23, 2009 | Samsung SyncMaster 192 T (Silver) 19" LCD...
Samsung SyncMaster 192N loses picture; requires re-boot
Unfortunately, you two have two unrelated problems. CB, the monitor isn't asking you for the password, that's the computer itself going into hibernation, which shuts down the video output, hard drive, etc. You need to go into the power-save settings and either disable hibernate, or change the settings to your liking.
The other question about the screen staying on for 5 seconds... thats an inverter board problem.
Apr 25, 2007 | Samsung Syncmaster 192N 19" LCD Monitor
Samsung Syncmaster 192N 19" LCD Monitor Logo
78 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
phoenix chi
phoenix chi
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
