Question about Sony KDF-E60A20 60 in. LCD HDTV
Had same symptons as everyone else needing a lamp, so I bought aftermarket one, put it in, now power light blinks red 3 times.
    Problem Solver:
  • 5 Answers
MY KDFE60A20 SONY HAS NO POWER..THE RED LAIGHT BLINKS 6 TIMES..CAN SOMEBODY HELPME PLEASE.
Posted on Oct 08, 2010
Once we turn on the power, the power light blinks green 7 times and then blinks red 3 times. Aftern the pause 3 red blinks again. What type of problem is that? What parts do we need?
What I would suggest is go onto ebay and put in the model number of the t.v. and then the word lamp.
It should come back with the proper lamp replacement model numbers.
Apr 25, 2014 | Sony Kdf-e50a10 50-inch Lcd Rear...
Kdf-e50a11e diagnostic codes
3 blinks is indicating the lamp has burned out. Aftermarket lamps tend to fail quickly. Only use oem replacement lamps for your sony. You can get replacement lamps from www.tvrepairworld.com
Feb 07, 2012 | Sony KDF-E50A11E TV
Replace the 2 bulbs. Unit powered up correctly and turned on like normal. Then Lamp1 and Lamp 2 indicator lights blinked (Indicating Start UP). After some period of time, it switched to Red 6 times blink...
1 red blink every 2.5 seconds indicates a cover error-- for this check the lamp cover
2 times red blinks very 2 seconds indicates temperature error. for this let the projector cool off check filters and fans that there is no blockage of air for proper cool down
3 red blinks every every 2 seconds Power error. incorrect voltage input or internal malfunction.
4 red blinks every 2 seconds indicates Fan Error check the fans make sure they are working and not blocked or need replacing.
i have nothing on 6 ligths go ahead reconect and check for proper count. hope this information helps.
Best of Luck.
Ray.
Jun 05, 2011 | Sanyo PDG-DXT10L Projector
Power light is flashing 3 times consecutively. When hitting the power button the fan comes on then shuts back down..then starts flashing the red light again..I've recently bought a new lamp and installed...
Put lamp cover back in its place as 3 times blinking light shows lamp cover has not been fixed.
Lamp cover is first thing that you removed to replace lamp in tv, make sure it is fixed securely in its position.
Aug 13, 2010 | Sony KDF-50E2000 50" HDTV
Reset lamp hours on sony grand wega
hello
  1. Press "Display" on the remote, followed by the 5 button, then the sound up key, and "Power On." Do this while the TV is in Standby mode.
  2. Step 2 Then press "Jump" 3 times to enter the DE Service menu. The TV screen will display the total lamp time hours.
  3. Step 3 Reset the lamp time by pressing channel 3, then mute, then enter. This will put your lamp counter back to 0.good luck
shaun
Nov 05, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
SONY KDF-E55A20 5 red blinking lights on power button
Symptom shows Lamp is weak in result and causing restart of TV again and again. Your TV requires new lamp as per following part number...
A1085447A* LAMP BLOCK ASSY XL-2200U
It is available in Sony Accessories Store for $200 and replacement procedure is written in instruction manual of TV.
Always buy Sony original lamp for TV and avoid aftermarket / cheap lamp for TV safety.
May 18, 2009 | Sony KV-36FV26 TV
No picture, no sound, power button blinks 47 times, then lamp flashes 134 times, then shuts off
It is symptom of weak Lamp in your TV, replace Lamp with following part number..
A1606034B LAMP BLOCK XL-2100U
It is available in Sony Accessories for $200
Always buy Sony Original Lamp for your Sony TV and avoid aftermarket/ cheap lamps.
Apr 22, 2009 | Televison & Video
Replaced bulb in a kdf-e42a10 and worked for about 8 hours
3 times red light blinks shows that Lamp Cover is Open. Please put back lamp cover properly.
I would recommend to always replace with Original Sony Lamp and avoid aftermarket or compatible lamps.
Feb 21, 2009 | Sony KDF-E42A10 42 in. LCD Television
Sony Wega KDF-55E2000 won't turn on
A 5 blink code is a lamp power supply problem, but I would try a new lamp. I'd say about 90% of the time that fixes the problem.Get an ORIGINAL Sony lamp as the aftermarket replacements are ****. If you replace the lamp and still have the problem, you will need to have the lamp power supply/lamp ballast replaced
Oct 19, 2008 | Sony Grand WEGA KDF55E2000 55" Projection...
Kdf-60xbr950 - red light blinks 3 times for a minute and tv turns off
same problem as others 3 blinking green lights then orangey colors then 3 red blinking lights afterwards shuts down fan runs for about 2 mins solution check your door cover for warpage or deformed just a bit under set screw there is a push in switch try and push it in with q tip while holding turn on tv if it works then that door is deformed and defective change it
thanks for solving my issue tv works again very helpfull thanks
Feb 13, 2008 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Sony KDF-E60A20 60 in. LCD HDTV Logo
99 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
