Question about Pontiac Vehicle Parts & Accessories
2003 sunfire autostart as-1755 remote will not work light is working on both devices, batteries have been ,fuses removed and changed . I dont hear it doing anything when i press any button, and only the start and stop button was hooked up . It worked for 3 years then parked for 1 year with the batterie unhooked now it will not work .
RAIN3R
  • 5 Answers
SOURCE: changed batter remote start not working
Hello, What has happened is your remote has lost its programming.. Just like with most electronics, when something is reset or powered off, or even when the battery dies ....the programming software is lost. The remote has to be reprogramed either by a dealer (suggested) or by an aftermarket outsource..Hope this helps...This could help with almost all remotes.
Posted on Nov 22, 2008
SOURCE: boa remote start system is not working
It may very well be that the remote on your key chain needs a new battery. They typcally run out of juice after about a year of use. Its really not a big deal. Test this theory out. Hope everything goes well for you.
Posted on Feb 02, 2009
  • 8 Answers
SOURCE: Hi,
It sounds like either the starter motor or alarm immobiliser although the AA should have check these items I would have them checked again.
Posted on Oct 16, 2009
SOURCE: crimestopper keyless entry remote wont unlock or lock anymore changed battery still wont work
need to program a new remote to keyless entry system it is crimestoppper cs835 rke
Posted on Dec 16, 2009
  • 139 Answers
SOURCE: Cars rpms goes extremely high, have to shut off
The problem you have described do not sound remote start related. A remote start unit does not have the ability to alter the RPM. The remote start system only replicates the process of turning on the ignition, starting the engine and keeping it running for a predetermined length of time.
The heater temperature problem should not be remote starter related either.
As for the day time running lights, although rare, if wired inproperly there is the possibility that the remote starter has caused it to fail. This will have to be determined by a qualified technician.
Posted on Jan 25, 2011
2005 mazda3 with autostart remote 2510 doorrs ,locks work it will start when key is in on position but will not when key is out. it sets up lights come on but does not start and then park lights flash
you will need to check all you fuses on the car its self and for the remote start system. also there is usually a switch to turn off the start function. the switch could be off or bad also. hope these few tips help. you could also have a loose wire to the starter or the relay could have went too. good luck.
Nov 29, 2014 | 2005 Mazda 3
My toyota sienna 2001 was opening by remot control now it is not working roof light not working warnnig
hello
Prius2 is not powering up after one person swapped ower polarityof battery while changing it. We changed Big fuse at the front of the car and couple of small fuses. Now when pressing power button we have engine light and power button orange light fore just one sec. After it just stays dead. While pressing power button you can hear couple relays clicking for a sec and dc to dc giving hi frequency noise for the same amount of time. Help us please. This prius was manufactured in 2003. Many Thanks
Feb 27, 2014 | 2001 Toyota Sienna
Autostart after battery disconnected blue light
do any other functions of the fob work?-Denny
Nov 03, 2013 | Cars & Trucks
My remote car starter from autostart on a grand am 03 won't start or locks won't work after it died for about a week then changed the batteries
Check to be sure the new battery is a good new one, they set on the shelves for some time ya know. Then make sure it goes in the correct direction.Then refer to your owners manual if it needs reprogrammed.
Feb 18, 2013 | Cars & Trucks
Keyless remote stopped working, I replaced battery
The 1997 to 2003 Dodge Caravan and Grand Caravan use a standard key and remote setup with a separate remote fob. However, the 2004 to 2009 Dodge Caravan and Grand Caravan use a combination key and remote on one device. To program a new keyless entry remote for the 1997 to 2003 Dodge Caravan, you must have at least one functional remote, which is required to enter synchronization mode. To program the combination key for the 2004 to 2009 Dodge Caravan, you must have two functional combination keys. If you do not, you'll need to see an authorized Dodge dealer for keyless entry programming assistance.
2004 to 2009 Caravan Programming Instructions
  1. Insert one of your working combination keys into the ignition. Turn it to "On"; leave it in this position for about 10 seconds but no longer than 15 seconds. Turn it to "Off" and remove it.
  2. Insert your second working combination key into the ignition within 15 seconds of removing the previous key. Turn it to "On". After 10 seconds, you'll hear a chime and the "Theft" light will begin to flash, entering synchronization mode. Turn the key to "Off" and remove it.
  3. Insert the combination key you want to program. Turn it to "On." After 10 seconds, you'll hear a chime; then the "Theft" light will turn off. When the light turns off, the combination key--including the key and the remote--is programmed.
  4. Repeat Step Three for each combination key you want to program. A total of eight can be programmed.
Hope this help (remember comment and rated).
May 08, 2010 | 2008 Dodge Grand Caravan
I just had my battery changed and now none of the gages are working. How do I reset these?
The Pontiac sunbird and chevy cavalier share this problem. You must find the fuse for the instrument panel, remove it, make sure that the contacts are clean and the fuse is good, the re-insert the fuse. If this does not work, Take it to a shop. This has worked for my 2002 cavalier, which does this often.
Aug 13, 2009 | 2003 Pontiac Sunfire
1994 integra
Many autostart devices also have security systems incorperated, first I would try to arm and disarm the system then try to start again. Then check the autostart controll unit to see if there is a reset or fuse. If not a reset often times there is a disable for the autostart witch will allow you to diagnos the starting problem without the aftermarket device. If non of that helps post your next message with an update plus make and model # for the autostart.
Jan 18, 2009 | 1994 Acura Integra
Vehicle Parts & Accessories Logo
356 people viewed this question
Top Pontiac Vehicle Parts & Accessories Experts
Jeff Turcotte
Jeff Turcotte
Dan Shibata
Dan Shibata
David Ellis Rhea
Are you a Pontiac Vehicle Part and Accessory Expert? Answer questions, earn points and help others
