Screen with text : E.-3 - Office Equipment & Supplies
Why does screen go black or white by itself?
There are 3 step to repair black screen error
If you got black screen error then there is a 94% chance that your computer has registry problems. To repair black screen error you need to follow the steps below:
* Step 1 - Download a black screen error repair tool,install this error repair tool.
* Step 2 - Click the Repair All Button.It will scan you pc for Free.
* Step 3 - Then click the Repair All Button again and your done! It is very easy to repair black screen error.
Here are the url of black screen error repair tool:http://www.FixError2010.com/ttfix-black_... Source(s): http://www.FixError2010.com/ttfix-black_...
Sep 22, 2015 | Computers & Internet
How to change text size
please clarify; what kind of operating system your using? text size of what? application software like word or Computer screen display? for windows screen text you can enlarge by entering control panel-appearance and personalization for win7&win8 - display make item small or larger or by changing screen resolution
May 01, 2014 | HP Mini 1000 Netbook
Need to adjust screen & minimize font and text
just go into settings display and you will find all that you need there
Nov 10, 2013 | Sony PlayStation® 3 (60 GB) Console
Does the toshiba 27a44 have closed captioning?
Hello
You have two options with closed caption feature.
Captions of Text
A caption is a printed version of a dialogue narration and/or sound effects of a programme. Text is information not related to the programme that appears on half of the TV screen when available.
To view Caption or Text
[1] Select the desired programme. Closed captioned programme are usually marked in your local TV listing as "CC"
[2] Press CAPTION/TEXT repeatedly to select caption or text mode.
[3] Press 1/2 to select the caption or text channel.
[4] To turn to off the closed caption feature, press CAP/TEXT repeatedly until captions or text no longer display 0n-screen.
Ok.
Nov 15, 2010 | Toshiba 27A44 27" TV
How do I enable closed captioning on my Zenith PIP System 3? Thanks.
Hello
To enable close cationing on your TV follow this:-
[1] Press "Menu" button on the remote control to appear "Setup" menu on the screen.
[2] Use "Up and Down" arrows on the remote contol to select "Captions/Text" on your screen.
[3] Press "Right or Left " arrows to select any one of the following options. Caption-1, Caption-2, Caption-3, Caption-4 Text-1, Text-2, Text-3, Text-4.
[4] Press enter to return TV viewing.
To turn the caption feature to "On" or "Off'
[1] Press menu key on the remote control to display "Setup" menu.
[2] Using "UP/DOWN" buttons to select captions on your screen.
[3] Press "Right or Left" arrow to switch the captions feature 'ON" or "OFF" or "EZ Mute"
[4] Press enter to continue.
Ok.
Oct 22, 2010 | Zenith C27A24T 27" TV
Cannot get closed caption
To view captions or text:
1. Select the desired program. Closed captioned programs are
usually marked in your local TV listing as “CC.”
2. Press CAP/TEXT on the remote repeatedly to select caption or text mode.
3. Press 1/2 on remote to select the caption or text channel.
4. To turn off the closed caption feature, press CAP/TEXT
repeatedly until captions or text no longer display on-screen. I hope this helps. Thanks for using Fixya. Good luck
Nov 04, 2009 | Toshiba 20AF45 20" TV
When I text I get an underline and I can't get anything but the first letter of a 3 letter set on the keys
You must disable your Predictive text option, T9® predictive text mode allows you to type words with only one keystroke per letter, and the phone interprets what word you want. For example, to type the, press 8, 4, 3. To enable/disable T9® predictive text mode, select Options. Scroll to and select Prediction on or off.
Oct 22, 2009 | Nokia 2610 Cellular Phone
HOW DO I PUT A SIGNATURE AT THE END OF MY TEXT MASSAGES ON MY G1
You have to download an application called text easy bt that will only give u a signature for every new message. In order to get a signture under your original text message is you have to go into text easy, select the person or perons you want to send a text to ( bt dnt write nothn) Then jus go back and it will be saved in your drafts into the messaging icon
Mar 25, 2009 | Google Android
Black Box on the screen
It sounds like a text box that isn't receiving any text. If it covers almost the entire screen, then you might have accidentally got the settings into DEMO mode. It could also be a box for closed captioning, but that usually covers just the lower part of the screen. Either way, the solution is to go into the setup menu and restore facotry presets.
Nov 27, 2008 | Toshiba 27A33 27" TV
jasbo
jasbo
