How do i adjust the headlights for my 1995 Toyota 4runner. I just repleaced the bulbs, but now i need to adjust the headlights so that they are equal in distance at night. I hope that makes sense.
    Scholar:
  • 120 Answers
You should not need to adjust after replacing the bulb. You need a adjustment board to aim and adjust correctly most collision shops will adjust correctly fairly cheap $20 to $30 and it only needs to be done when you notice an issue. As it will affect safety I would recommend having you headlights adjusted professionally this way they will be exact and perfectly even on both lights.
Posted on Sep 14, 2010
  • 864 Answers
When you replaced the bulb you should see that there are larger screws on the backside of the light. By where the 2 screws were that you needed to remove to get the sealed headlight bulb out. These large screws are the adjustment screws. They should sit level on the road for 25 feet ahead of you. If you need further assistance please let me know. Thanks, Midwest-tek
Tip
How To Replace Change Headlight and Bulb 1995-96 Toyota Camry 1AAuto.com
on Apr 26, 2012 | 1995 Toyota Camry
How to replace headlight bulb on 2004 toyota 4runner
BE AWARE THAT THE PASSENGER SIDE IS EASIER TO INSTALL THAN THE DRIVER'S SIDE. ON THE DRIVER'S SIDE YOU MAY HAVE TO MAKE ROOM TO REMOVE AND REINSTALL THE BULB.RAISE THE HOOD. LOOK BEHIND THE HEADLIGHT, THERE IS A PLUG WITH A CONNECTOR. DISCONNECT IT. NOW TAKE THE LITTLE METAL SPRING THING AND PINCH IT, THAT HOLDS THE BULB IN PLACE. TAKE OUT THE BULB, PUT THE NEW ONE IN. FOLD THAT LITTLE METAL THING OVER AND PINCH INTO PLACE. CONNECT CONNECTOR AND RUBBER PLUG AND THAT'S IT.
Read more: http://wiki.answers.com/Q/How_do_you_replace_the_headlight_bulb_located_on_a_Toyota_4Runner#ixzz1dzmGIRan
Nov 16, 2011 | 2004 Toyota 4Runner
White plastic bracket holding headlight
headlight bracket, headlight adjuster, or headlight adjuster bracket
Mar 28, 2010 | 1994 Toyota 4Runner
How do I change the bulb in the driver's headlight of my 95 Toyota 4Runner?
You must remove the four screws that hold in the side marker lenses (two per side/lens) pull the lens forward & out to the side. Next remove the grille, to do this you need to push in both top & bottom of the plastic clips that hold it in place. These clips usually break since they are old (1995) & made of plastic. Each clip costs $1.99 from the Toyota dealership (for .02 cents worth of plastic!) you will probably need a few even though they are way overpriced. Then once the grille is removed you can remove the four bolts that hold the lens assembly in place, once it is removed you unplug the bulb & then unscrew the plastic retaining ring that holds the bulb in place & remove the bulb from the housing. Installation is the reverse of removal - BEWARE; do not touch the glass of the bulb, oil from your skin will cause hot spots on the glass & lead to premature failure of the bulb. If you do happen to touch it, clean the bulb with alcohol prior to assembly.
Method #2; remove the air box on the drivers side (behind the headlight & you can remove the bulb from the back. On the passenger side, remove the battery & the washer fluid reservoir & you can remove it from the back also. Either method is time consuming & an unusually bad hassle for something as routine as changing a headlight.
Jan 26, 2010 | 1995 Toyota 4Runner
Where do you begin raplacing a 93 4runner headlight?
if this has the old style bulbs you're on the right track--just havent found all the retaining screws however if this is the newer style with the small bulb it goes in from behind, some times the battery is in the way, but on this type there is a cap over the wires and a retainer which have to be removed
Oct 26, 2009 | 1993 Toyota 4Runner
Headlight adjustment
make sure its the right one there is heaps of screws there but if it is the right one culd b a worn thread
Jul 21, 2009 | 1997 Toyota 4Runner
4Runner headlight has moisture inside. Light works fine
yes. it should be a fairly easy job, just be careful when removing the glass, and make sure you get your headlight re-alligned when it is done, as it will fail its mot if not done.
hope that helps.
Mar 18, 2009 | 1999 Toyota 4Runner
Headlight Problems
there are two headlight fuses in the engine compartment fusebox. one for each side. keep an eye on them. also, go ahead and change your bulbs (wether sealed beam or Halongen swap bulbs).
Jan 28, 2009 | 1994 Toyota 4Runner
220 people viewed this question
 Grubhead
Grubhead
