Question about SAMTRON 98BDF 19 in.CRT Conventional Monitor
I have a Samtron 98BDF crt monitor that has a focusing problem. I notice the more I turn down the contrast, the image will eventually get sharper. If I turn the contrast up the image will eventually get blurry. Any suggestions on this weird problem?
  • Matt
    Matt Sep 14, 2010
    Sorry, but I do not have an account.
I have a Samsung Samtron 97BDF and i have problems with the information cable, so i need to change it, how can i do? Maybe someone have pictures about how to make..
Posted on Nov 19, 2015
5 Suggested Answers
8thWonder
  • 16 Answers
SOURCE: Samsung SAMTRON 55V
just find it on http://www.eserviceinfo.com/download.php?fileid=4374 just vote for me so that i can help u again
Posted on Aug 29, 2007
  • 68 Answers
SOURCE: samtron 98BDF
Since your monitor is recieving data I would look at your computer hardware for the solution. Did you recently add a program to your computer? Or change a BIOS setting ? Did you have problems with your hard drive?
Posted on Sep 20, 2007
SOURCE: My CRT Monitor Samtron 15 becomes yellowist
rgb base drive voltages droping this happens either one of voltage is lower
Posted on Feb 18, 2009
jdvillanueva
  • 2098 Answers
SOURCE: CRT monitor screen is out of focus.text and other
This kind of symptoms can be correct by the focus adjustment at the flyback transformer. FBT mostly has two control knob (Focus and Screen), focus is usually at the top one like in the sample picture below.
Open the back cover of your unit and then locate the FBT. Power on the unit and try to adjust the focus knob.
If the symptoms can't be cured by the this step, this is an indication that the CRT socket is already faulty. You have to replaced this parts and then make some adjustment at the focus knob of the FBT and your unit will back to normal again.
CRT(picture tube) socket
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Jdvillanueva
Posted on Jul 14, 2011
I need display of 56v samtron monitor
Did you check the adjustment setting on the brightness and contrast?
These two setting can be moved and stop the CRT from displaying,
Please move these two setting to MAX and see is there any image on the display.
Jan 31, 2011 | SAMTRON 55V 15" CRT Monitor
I am trying to clone my lapptop image with a samtron 73.v and the samtron seems dead :-( It says Test Good but does not work
Most laptops have three video-settings:
* output only to internal screen
* output only to external monitor
* output to both internal and external
Select the appropriate video-setting.
Set your laptop's screen-resolution to 800-by-600 by 60Hz -- a resolution that should be compatible with any 15" Samtron monitor.
Dec 26, 2009 | SAMTRON 55V 15" CRT Monitor
I have a samtron 97bdf monitor borrowed the logistics office. It still works but the resolution is so bad my eye strains. I adjusted the contrast and light but to no avail.
tyson_gal, You will need to locate something called the FOCUS adjustment somewhere on the monitor. Maybe Samtron has info at their website under Troubleshooting or something similar? hope this was of some help 12fixlouie
Nov 09, 2009 | Samtron 96BDF 19" CRT Monitor
To open the Samton 45Bn crt monitor
turn off power.
Get a long philips screw driver and remove the base and all fixing screws. some are hidden behind blanking plates and the com off with a sharp knife and a getle lifting at the join.
After all screws are removed the lie the screen downwards and start to pull away the backing.
you should get the case apart easily.
You must be aware of the tube holding a full charge at its end. DO NOT touch this at any point. The only thing you should try to inspect is the fuse or adjustment to the focus slant contrast etc.
AndystUK
Aug 30, 2009 | SAMTRON 55V 15" CRT Monitor
ControlLock
It seems monitor 's problem plz check memory ic and command ic for fault.And check all components that is placed near front panel keyboard's buttons.normaly it is the problem of command ic and memory ic.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FIXYA.
Mar 23, 2008 | SAMTRON 55V 15" CRT Monitor
Samtron 98BDF
Sep 18, 2007 | Samtron 96BDF 19" CRT Monitor
I have the SAMTRON 56 V 14" COLOUR MONITOR .
change the eprom (A41dDC) after connect pc then switch on monitor
sushil91077rajbanshi@rediffmail.com
Sep 04, 2007 | SAMTRON 78DF 17" CRT Monitor
Dark image
Flyback transformers usually have 2 adjustable rods - 1 is for focus the other is for screen (G2) voltage. try turning Clockwise the Screen adjust with brightness-contrast at max. Till you see white diagonal lines, then go back until the lines disappear - then tune the brightness to your desired level.
Apr 27, 2007 | LG Flatron Ez T710BH 17" CRT Monitor
Usercontrol automatically displayed when bootup
it is due to the 5V regulator ,replace that
Sep 15, 2006 | SAMTRON 55V 15" CRT Monitor
My samtron 55 monitor becomes hazy and out of focus
Focus and brightness (sometimes called screen control) are usually adjusted in the flyback transformer. Check for a bad connection where the flyback is soldered to the board. This could also indicate a problem with the CRT.
Sep 06, 2006 | SAMTRON 55V 15" CRT Monitor
SAMTRON 98BDF 19 in.CRT Conventional Monitor Logo
164 people viewed this question
Top Samtron Computers & Internet Experts
William Miller
William Miller
Richard Lilja
Richard Lilja
Ted Maxwell
Are you a Samtron Computer and Internet Expert? Answer questions, earn points and help others
