Question about Video Game Consoles & Games
I have a PSP 3006 that will not charge. When charging by USB or plugged in the green light is on with the orange light quickly flashing on and off. When I try to run a new update it downloads but won't install because it states the battery is too low and will charge automatically when the batter is charged enough to complete the install. It also is difficult to close the battery cover with any batter in. Can you provide me some assistance? Thanks.
eagle338
  • 4889 Answers
SOURCE: psp battery won't charge
Its a problem with the unit's charging pins..you will have to get it replaced it shouldn't cost you more than 10$..
Posted on Oct 27, 2007
  • 10 Answers
SOURCE: Dell latitude D600 battery charge light flashing
I had the same problem, I removed the bettery while it was still plugged in, tested it, then plugged it back and and now all is fine.
Posted on Nov 26, 2007
  • 47 Answers
SOURCE: Charging a PSP
Sounds like it could be the mains/charger of the psp, have u tried using it on the other psp? If that dont work then it may be the power charging unit of the psp itself, u may have to call Sony and have it replaced
Hope it helps
Z33m
Posted on Dec 10, 2007
Kegtapper
  • 94 Answers
You have a ground fault issue in the DC JACK.
There are escentially 4 circuits in the jack and one is not making contact.
1: Negative Charge circuit (outter ring)
2: Negative Run circuit (outter ring)
3 Positive (Inner Ring)
4: Signal (center pin)
I believe the negative charge circuit (outter ring) is not making contact internally. Typically what happens on that model DC Jack is the tension contact metal becomes fatigued, and does not touch the outter ring.
This could come from Heat causing early fatigue of the metal.
Or normal wear, the metal has simply worn out from regular insert/removal.
Don't forget to rate suggestions
Posted on Apr 01, 2008
  • 998 Answers
That usually indicates battery is beginning to go bad. Eventually it will not hold a charge and will need to be replaced.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Posted on Nov 09, 2008
Battery charging shows quick green light
Ill try to help you, I think the slow flashing green lite is when you first plug it in the longer its on it will flash quickly when almost finished mine blinks untill full then stays on try to wear your battery all the way down then try to charge again good luck
Mar 24, 2014 | Nikon COOLPIX L19 Digital Camera
How to charge a psp with usb cable while it's dead
no you should use a computer an dplug it in to it and then an orange light should come on then just leave it there for a few hours untill the light turns green
May 24, 2012 | Sony PlayStation Portable (PSP) Console
How would i know when my Samsung camerais through charging
you can know if the camera is charging by the indicator light in the usb cable, green light means it was full charged..red light means that unit still charging.
Jan 28, 2011 | Samsung L200 Digital Camera
How would l charge my psp 1001 using my usb. thanks
PSP automatically charge itself when you connect the USB cable from the PSP to your computers USB port you should see the power light change from green to orange that is a sign of a charging state and if that did not happen connect the PSP on a different USB port on your computer because sometimes some USB port supplies less amount of power.
Nov 25, 2010 | Sony PlayStation Portable (PSP) Console
My PSP will not turn on unless it is plugged into the outlet. When I try to turn it on by itself the power light flickers green for two seconds and then disappears. Also, the battery is fully charged. When...
replace the battery as it may be out of CYCLES even tho it says its fully charged if the battry is new your going to need a new element inside usually this consist of a new logic board under the battery pack.
good luck
Apr 27, 2010 | Sony PlayStation Portable (PSP) Slim...
I have a PSP that I charged overnight and a orange light came on when i plugged it in to the wall charger. After charging all night I went to power on the PSP and it will not power on, no green or orange...
Remove the battery.
Plug the PSP charger into the PSP.
Turn it on.
The PSP works with no battery inside.
If you're not getting a green light at all, your PSP has some sort of damaged as it should work while plugged in with no battery inside.
Mar 17, 2010 | Sony PlayStation Portable (PSP) Console
My Dell laptop's battery charging circuit faulty.
try to remove your batt and check if laptop works fine with ac adapter alone.
if yes then put batt in then check how much charge you have if you have about 10% then update the bios immediately.
if fails then have the batt replaced.
Oct 12, 2009 | Dell Latitude D600 Notebook
Psp not charging
try a different charger or battery..? i charge mine from a usb charger that works for me...
Sep 13, 2009 | Sony PlayStation Portable (PSP) Slim...
Thank You.
Nov 09, 2008 | Dell Inspiron E1705 Notebook
PSP won't work
Give more details pls.
While charging, it's normal to have a amber light, when the charging finishes, it will turn to green.
Sep 29, 2007 | Sony PlayStation Portable (PSP) Console
Video Game Consoles & Games Logo
130 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
