Question about Miele Ovens
I have two H5240B ovens. On one I cannot access the P6 function to change the time to a 12 hour clock. It only allows me to go to P5. On the other, the LED light is not as bright as the oven that won't change the 24 hour clock. Can you advised please
  • 1462 Answers
SOURCE: Main oven problem
I suspect not the oven element at fault. you only way forward is to actually test the resistance of the element to earth with a megga if you can beg the use of one. be cautious about the result as on occasion, elements are only faulty to earth when hot. another way to test if you are cdarefull, is to connect the element to mains independently of the oven and see if the rcd trips
Posted on Sep 22, 2008
  • 3 Answers
SOURCE: Kitchenaid superba 27 double oven clock - can't change the time!
I went to the website:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%203177060.pdf
http://www.kitchenaid.com/custserv/service.jsp
from page 8
Turn the knob to the left until a tone is heard and "time" appears in the display window. The previously set time will appear in the display window.
Continue turning the time knob in either direction until the correct time of day appears in the display window
Press the START button to begin clock operation
Posted on Dec 09, 2008
If you have a built in oven...
Press the Clock Set/Start button once Enter the correct time by pressing the numbers on the numberpad Press the Clock Set/Start button again
Done.
Posted on Mar 09, 2009
SOURCE: how to turn oven on kelvinator wall
Is there a hand diagram labelling one of the button. Auto/Manual switch?.
Posted on Apr 11, 2009
SOURCE: After usung the self cleaning function the oven no longer works
The quickest easiest solution is to call an appliance repair place and have them come and fix it. I have had the internal fuses blow on on three separate occassions, all caused when the self cleaning function was used. Another solution is to place an inline circuit breaker to the fuse so the breaker will pop first rather than blowing a 40 dollar fuse. The circuit breaker should not be greater voltage or current rating than the fuse if you choose to go this route. Otherwise, its pay the repairman to replace it.
Tom B
Posted on May 28, 2009
I have a Dacor ERD48SCH/NG oven/range. Accidentally changed the clock time to military (24-hour) time, and now can't figure out how to change it back. How do I change back to regular 12-hr time?
Step 1 Locate the "Clock" button on the display. The display is located above the oven door. It clearly shows the time and has settings for temperature, time and cooking.
Step 2 Press and hold the "Clock" button until the time starts to blink.
Step 3 Set the time with the number pad. Ignore the colons and enter the number straight through. For example, if the current time is 10:08, just type 1-0-0-8.
Step 4 Set AM and PM by pressing the "#" button. Press "Start" to finish.
Jul 07, 2018 | Dacor Ovens
F&p OB60SL11DEPX1 built in oven. Bought this as an off the floor demo. Just installed it. All the functions, clock etc work but elements not heating up. Troubleshooting says it might be in demo mode!!
It could also be a faulty circuit breaker. If one of them trips internally it may not trip the handle or indicate one is tripped. This situation allows only 120 volts to reach the oven instead of 220. That's why the clock functions but not the elements. To turn off Demo Mode:
1. Press SETTINGS 12 times. "Demo Mode" and "ON. Press (1) to OFF" will appear in the display text area.
2. Press the "1" keypad to change the Demonstration Mode setting to Off.
3. "OFF Selected" will scroll in the text area. Demo Mode has been turned Off.
Oct 22, 2016 | Ovens
On my GE Cafe oven, how do I change the time display from 12 hours to 24 hours?
Not knowing your model number, a generic manual search was done. Unless you have something that says the clock will display 24 hour format, you are unable to change your clock to that function.
Mar 09, 2015 | GE Ovens
How do I change Bosch oven clock from military time?
We have an older Bosch Oven (maybe circa 2010), and the way to access the special settings is to hold down the "Temp" button for 2 seconds which reveals a hidden menu of goodies. I made two changes in there--changed it back to 12 hour instead of military time as well as disabled the annoying beeps every time you press a button. Manual is here: https://media3.bsh-group.com/Documents/9000369981_A.pdf
May 17, 2014 | Bosch Ovens
Wolf ovens getting err message after power outage
I had a Wolf 30F wall oven with a similar problem
after power outage. It wouldnt stop beeping with error message related
to temperature control. My solution was to turn power of at circuit
panel, then reset by pressing and holding the clear button for 5
seconds.
Also note: in my case I had to close the display
before switching the panel off. When I tried to the reset process with
the panel showing, it wouldn\'t reset.
To reset other
various parts of the control panel Instructions said:
Time-of-Day Clock
Immediately after the oven is installed, set
the 12-hour clock to the current time of day. It may need to be reset
after a prolonged power failure. The clock is visible on the control
panel during all modes. If the upper oven timer is set, the clock will
not be visible in the upper oven control panel display.
SETTING CLOCK
1) Touch CLOCK.
2) Touch number pads to
set current time of day.
3) Touch CLOCK or ENTER to start
clock.
24-HOUR CLOCK
The time-of-day clock can be
changed from a 12-hour clock to a 24-hour clock. After the clock has
been set, touch TEMPERATURE for three seconds, touch CLOCK, and then
touch ENTER. Follow the same sequence to change back to the standard
12-hour clock setting.
Fahrenheit to Celsius
The
oven can be changed from Fahrenheit (°F) temperature to Celsius
(°C).
Oct 26, 2012 | Wolf Range Ovens
My Maytag oven was shut off when a breaker was tripped. We turned everything back on however the clock says " 5ab" and none of the buttons work to reset the clock. Without this function, we can't...
That is the sabbath feature, to get it or defeat it:
1. Push the PREHEAT pad and set the oven
temperature to 500°F/260°C or more using the UP
ARROW pad.
2. Push the PREHEAT pad within the next 2 seconds
for 3-4 seconds. A beep sounds and a number
appears in red to the right of the display. For the
conversion, "3" must be displayed. If another number
is displayed, push the PREHEAT pad and select
"3".
3. Push the UP or DOWN ARROW pad to change
from 12 hour to 9999 in the display, for no 12 hour
shut-off.
4. Push the CANCEL pad to confirm your choice.
Thanks for using Fixya, let me know.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 06, 2011 | Maytag Ovens
I have a Frigidaire Range model PLES389DCC, it's top cooking function well, but display panel PF show, the clock start from 12:00 (after off/on circuit breaker) and kicking. I have order the control panel...
The clock may be set for 12 or 24 hour time of day operation.
The clock has been preset at the factory for 12
hour operation. When the range is first plugged in or when
the power supply to the range has been interrupted, the
timer in the display will flash and PF (power failure) will
appear in the display.
To set the clock:
1. Press Clock . "CLO" will appear in the display.
2. Example for 1:30. Press the numbers 1 3 0 to
set the time of day to 1:30. "CLO" will disappear
after 4 seconds and the clock will start. Or you may
press Start. "CLO" will disappear and the clock will
start.
Nov 29, 2010 | Frigidaire Ovens
I wanted to change the time hour. I pushed clock and up arrow at a time and the clock is showing 5 AB. The screen is frozen. I can't use any options. How could I get it back to normal? Thank you for your...
To
provide sabbath feature (or to cancel this setting):
ARROW pad.
"3".
shut-off.
Other Displays:
When proceeding through steps 1 and 2 in the
Temperature Scale Conversion or in the elimination
of the Sabbath feature /12-hour Shut-off time limit,
two other words can be seen in the display. One is ESC
with O in red. It cannot be changed. The other is USE or
SALE with 3 in red. This one is for factory use and should
stay on USE.
Nov 20, 2010 | Magic Chef 9112 Gas Double Oven
Changing the clock time
If you mean simply adjusting the 12 hour LED to the time of day...Push the area on the glass control panel printed "clock". Enter time of day by using same "buttons" you use to adjust oven temps, as in 1-2-0-5, which would be 12:05. then push clock once more. If you meant changing from 12 hour time to 24 hour time, that is complicated, takes two people, and is on page 30 of your owner's manual.
Jan 23, 2009 | Thermador SC302T Electric Double Oven
Dacor ECS230 Wall Oven Control Panel Time functions not working
Try turning the power off at the breaker for 12 hours.
I had the same problem, tried turning the power off for a few minutes but that did not fix the problem.
Leaving the power off overnight seems to have fixed it.
Nov 09, 2007 | Dacor Millennia MOV130 Electric Single...
Ovens Logo
Top Miele Ovens Experts
Paul Bade
John
Are you a Miele Oven Expert? Answer questions, earn points and help others
