Question about Vacuums
Can't find the manual for Biddeford electric blanket (warming blanket) '08. Controls are acting up. One side keeps turning itself off and says 'E'. I'm assuming this means error. The other side only registars '8' and can not change or turn off unless I unplug.
  • Jeff Riley
    Jeff Riley Nov 03, 2013
    I had the same problem, and in my case it was just that the plug from the controller the the blanket had become disconnected when making the bed. I re-plugged it and it was fine. Hope your problem is solved so easily!
5 Suggested Answers
  • 377 Answers
SOURCE: I received this electric blanket
Appears to be that the power is not getting to the temperature controllers. Suspect a problem in the wiring between the wall outlet (if not the wall outlet) to the temperature controllers. Look for broken plug at end of cord or a break in the cord between the plug and the controller. Last, you may have to look at the connections inside the temperature controller the power cord goes to in order to see if there is something loose inside. But do this with the blanket unplugged.
Posted on Sep 19, 2010
  • 37 Answers
SOURCE: AirVac ZX6000 won't turn off!
There is a relay board inside your unit which is most likely bad. If you have the make and model, you can contact me and I can order the board for you(pending your mechanical abilities). If not, contact your local central vacuum installation company. www.thevacdudes.com
Posted on Jun 12, 2009
  • 383 Answers
SOURCE: The one of the controllers
I did some searching-- and I came up with this Linkedin page-- seems to have some information-- Let me know if it helped-
http://www.linkedin.com/companies/jla-home
Mack B
Posted on Jan 20, 2011
emissionwiz
  • 79077 Answers
SOURCE: Electric blanket controls
What exactly is your question here. Please keep in mind that Fixya.com is a technical support site only and we have no parts resources of any kind, we can't order parts or supply parts or look up part numbers..
Posted on Apr 21, 2011
Brushes dont turn
If you are referring to the two main brushes underneath the Roomba (not the side-sweeper) then there are a couple possibilites:
1. The gears need to be cleaned/regreased inside the brush unit. There are several videos/guides online that will show you haw to dissassemble the gears, clean out the gunk, and reassemble. Basically there are four screws that hold the unit in; once it is removed you will see several screws on the side of the unit that contain the gears for the brushes. Dirt/dust/hair makes it's way into the gear-case and gums up the works, which seizes the motor.
2. Another possibility is that the electric motor that drives the brushes needs tp be cleaned or replaced. My Roomba had lint/hair caught up in the electric motor...in fact the dirt was separating the brushes from contacting the rotor inside the motor, which means they weren't cunducting electricity. Once I cleaned out the motor itself, the brushed worked right away! There are a couple view holes on the sides of the motor...get a flashlight and look inside...there is probably lots of junk keeping the motor from working properly.
Apr 17, 2014 | iRobot Roomba 530 Robotic Vacuum
Dual control sunbeam electric blanket, one side is blinking 'E' have disconnected it several times, but still nothing. It was wotking fine the night before. The other control is working fine.
An error has occurred in your unit. Near the power or elsewhere find the reset button and press it. If you done it still error is blinking, check if you can the heater and thermostat of the blanket has a problem. Either a short or open circuit occur.
Thanks for asking.
Jun 25, 2011 | Vacuums
The dirt is staying in the hose and not going to the canister.
Can you check for the EXACT model #? The production day span from 2004 to current. It's hard to tell from the stock photo on the upper left side of the screen. M084600
Revision Date: 03/2005
Revision Date: 08/04
Revision Date: 04-06
Revision Date: 04/2005
M084600CAR
M084600DR
M084600HD
=========== You should do these steps outdoor.
Wear protective gloves and mask.
Turn the unit so the brush is facing the celling.
Take a razor blade and clear out any hair trip
It may take up to 5 to 10 minutes to undo the trapped hair and dirt.
***** ID the rotation of the brush by power on the vacuum just for few second. ===
DO NOT rule out a broken drive belt. Damaged /old air filter and belt are very common on the Dirt Devil vac. Style 15 Belt Part Number: 1SN0220001 === Link HERE for the parts order page.
The vacuum inlet (suction) is on the opposite side of the drive belt.
There will be obstruction in the bended tube on the base unit.
Take your time to clean it.
This is a 1/2 to one hour job for DO IT YOURSELF-ER. Please keep me posted on the fix via email.
Jan 27, 2011 | Dirt Devil M084600 Dynamite Bagless...
The one of the controllers for the electric blanket keeps flashing an "e". The other controller is fine. We switched controllers and the same thing happened. We have unplugged the blanket for...
Mack B
Jan 20, 2011 | Vacuums
Our westpoint home electric blanket, model 950, flashes 8 on one unit & can't be turned off. ELECTRIC BLANKET!!
Try pressing the power button and boost button at the same time. Then a C will flash and the setting you had it on before will show up. I think that was caused by pressing the boost button.
Dec 28, 2010 | Vacuums
I received this electric blanket as a gift and it will not heat up on either side. There is no light on the controls when I turn the blanket on. I need my blanket to work - it's like brand new!
Sep 18, 2010 | Sunbeam Vacuums
We have an sunbeam electric blanket model BL 0750 We dont seem to be able to programme it to heat up. Control lights are flashing
Hi. If you have a double or queen size blanket, switch the controls from one side to the other. If the fault follows the control, then the control is faulty. If the fault stays on the same side of the bed, then the blanket may be faulty. Most recent Sunbeam models have 3 years warranty. Once you've checked the controls, if it's under warranty call Sunbeam Customer Service on 1800025059 option 1 to report a warranty issue.
Otherwise: if the control is at fault, a new BL0750 has a recommended retail of $75.20. Get in contact with your local Sunbeam Service Centre via http://www.sunbeam.com.au/Pages/Support/Repairers.aspx
but if all else fails email me as I'm happy to help!
May 25, 2010 | Vacuums
Electrolux Z8240 Cyclonic Bagless Vacuum Cleaner
Be sure to check the hose , wands and power brush for obstructions as well.
If there's a burning hair electrical odor then it might be toast.
i despise bagless vac's as they always wind up being more maintenance and expence then bagged vac's.
Good Luck and let me know what you find out.
Oct 08, 2008 | Vacuums
Vacuums Logo
3,021 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
