Question about Acer Extensa 5420-5687 Notebook
My acer extensa 5420-5687 just shuts down startup repair can not fix it. keep restarting it sometimes it makes it through to my desktop then shuts down, but more time then not it just shuts down before startup repair even starts running
  • 393 Answers
Open the laptop and clean fan and heatsink... thats it
Posted on Sep 14, 2010
Freezing sometime
Check the CPU cooling. Make sure the fan is working and there is no dust in the heatsink
Dec 18, 2013 | Acer Aspire M1641-U1521A PC Desktop
Extensa 5420 Blank at boot
you have a brand new hard drive... probably cable is not fitted properly and the memory contacts needs cleaning. try it... good luck.
May 19, 2012 | Acer Extensa 5420-5687 Notebook
How to recover bios password for acer extensa 4620 ?
If you have forgot BIOS password then you have to reset CMOS jumper setting. Please follow the below steps: Open the Laptop back panel. Locate the CMOS battrey, remove it & then with the help of a screw driver keep on pressing the terminal inside it and turn ON the computer for 10 secs and Turn Off (make sure you keep on pressing the terminal with a screwdriver while turning ON). It will short the BIOS setting. Now, fix the CMOS battrey & restart the computer. This will take care of the issue.
If it is a desktop open the computer and you will be able to see the CMOS battery, please remove it & then with the help of a screw driver keep on pressing the terminal inside it and turn ON the computer for 10 secs and Turn Off (make sure you keep on pressing the terminal with a screwdriver while turning ON). It will short the BIOS setting. Now, fix the CMOS battrey & restart the computer. This will take care of the issue.
Thanks and regards,
Anil.B.R
Oct 24, 2010 | Acer Extensa 4620 Notebook
My Extenza 5420 won't complete updating and start up.
boot from the windows cd. select repair option. it will ask u" which windows u want to repair?". press 1. then in command prompt press the following commands.
c:/> fix MBR
c:/> fix BOOT
ignore the warnings u get in between when u enter the above commands
Sep 09, 2009 | Acer Extensa 5420-5687 Notebook
Acer aspire m5620 freezes, no mouse, monitor shows image but interacion. hard drive activity - none. must hard boot.
Hi..
Restart your PC and keep tapping F8.. choose startup repair and let it diagnose and fix --
Hope this helps !!
Sep 07, 2009 | Computers & Internet
Acer extensa 4420 laptop, not working
when windows starts up it loads my files. but when its loading files. it cant load those files, so its stop working and shut down. if u r not expert. reload yor cop of windows.
Aug 23, 2009 | Dell Inspiron 6000 Notebook
Won't boot up on first try
Whenever you do get it booted into windows, run the command prompt and in there run "chkdsk /f". That will check your disk for errors and repair them. Yours sounds like a boot sector problem, chkdsk should be able to fix that.
Jul 24, 2009 | Acer Extensa 5630-6806 Notebook
ACER NOTEBOOK MODEL 5620 will not boot my applcations
After your system boots, try right-clicking on the task bar and select "Properties" in the dialog box that appears. Click the tab that says "Notification Area" and see if the box "Hide Inactive Icons" is checked. If so, remove the checkmark. You can also leave the check there and select the "Customize" button to mark the ones you want to Hide/Show all the time.
Jun 11, 2009 | Acer Extensa 5420-5687 Notebook
Computer is slow as if it is constintly running a program or something - and - sometimes the screen will go blank as if it shut off, but the power stays on
Many computers have way too many things running in the background. If you see more than three or four little icons down just to the left of the clock, (this area is called the System Tray), some of these programs could be causing your problems.
Use Windows Explorer and navigate to:
C:\Windows\Start Menu\Programs\Startup
Adjust the size of your Windows Explorer so you can see some of your desktop and drag everything in the Startup folder out on the desktop, and then restart your computer. If this minimizes, or eliminates your problem, put each item back in the Startup folder, one-at-a-time, and restart and re-test your computer until you locate the offending program.
If your computer shut off but the power keep on means that your computer is in hibernate mode
To avoid that, do this:
Go to Start >> Control Panel >> Power Options
Unckeck the hibernatge mode at hiberbate tab.
This will fix your problem.
Don't forget to rate my help! :-)
Thank you for using FIXYA!
Pablo
Oct 15, 2008 | Computers & Internet
Acer start up
use your recovery disc that came with your computer to restart windows. or if you have a windows xp program disc this will give the option to do a repair or reload computer with a fresh copy of windows.
Jan 14, 2008 | Acer Extensa 500T Notebook
Acer Extensa 5420-5687 Notebook Logo
592 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
