Question about Dometic Rooftop RV Air Conditioner
Ac freezes at night - Dometic Rooftop RV Air Conditioner
  • Dometic Master
  • 43,501 Answers
Many air conditioners are not made to run at less then 65 F outdoor air temps. The pressures drop too low and they freeze up...you could try to have someone check and make sure that it is not a bit low on charge... that would make it freeze up sooner...
heatman101
Posted on Sep 14, 2010
AC adaptor for 9NT3A4-500 500gig, lost 1yr, just got AC Adator off Amazon.. when charging, is it ok if its blinking? do u think it can be revived after 1yr+?
Try this. Sometimes it works, sometimes not. Take the laptop battery out and freeze it over night. Let it thaw COMPLETELY (important) before putting it back in and start charging. Usually you can get back 80 % or better on an old battery.
Jan 04, 2017 | Computers & Internet
The coils are freezing overnight
Dirty filter,undercharged, evap. coil plugged.These are some possibilities, also tstat may be set to low adjust to reasonable temp
Apr 01, 2015 | Heating & Cooling
Dometic AC cycles on and off
sounds like you don't have enough of a charge in the system of "free-on". that would make the a/c cycle and cycle to try and keep the pressure up and would also contribute to the lines frosting and freezing
Jul 04, 2012 | Dometic Rooftop RV Air Conditioner
WE ARE CURRENTLY IN NORTHERN TERRITORY VERY HOT AND HUMID. RUNNING AC THRU THE NIGHT IT STOPS BLOWING COLD AIR AND FAN SEEMS TO BE NOISY. HAS IT ICED UP DUE TO THE HUMIDITY. UNIT BEING RUN THRU THE DAY NO...
If your coil is freezing at night, it sounds like your getting cold enough at night to have your saturation temperature drop below the design of what the AC is able to do. If it runs all day without an issue and freezes up at night, you need to add what is called an outdoor fan cycling switch. This will turn the condenser fan off when the saturation temperature drops so it will not freeze your coil at night. You need to have an HVAC technician install this. It is not a DIY projuect since it has adjustments that need to be right. Plus, it it's a heat pump, it needs to drop the switch off in the winter.
Sep 28, 2010 | Heating & Cooling
Ac unit keeps freezing up owner says only at night
A/C's freeze up due to low air flow or low refrigerant charge. Check your air filter and make sure all your registers and vents are open and not blocked. You may need a service tech.
Aug 13, 2009 | American Standard Heating & Cooling
Brand new Dometic rooftop ac,freezes up at night,does fine during day...??
This is common for most air conditioners and is normal due to humidity levels being higher at night causing more condensation build up and then freezing. Solution: Turn down thermostat at night to allow compressor to turn on and off.
Jul 26, 2009 | Heating & Cooling
Weather King 13AJA36A01 AC freezing up at night
check the inside coil is dirtyor may be low on freon
May 14, 2009 | Weather King 12AJA4801AH Air Conditioner
FREEZING :
check your thermostat, could be set to the coldest setting and it is not cutting off.
thermostat could be broken also( stuck close)
the evaporator coil could be clogged with dirt. have it clean.
tnx 4 using fixya,
drcool
Oct 16, 2008 | LG Electronic Window Air Conditioner
Duo therm air conditioner
my duo therm air works beautifuly all day but at night when we go to bed it seams to turn on and shut off rapidly. what could be wrong?
Jul 06, 2008 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
155 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
