I have suddenly lost access to my 2nd monitor and my main monitor will not adjust to the 16 or 32 bit -- It is currently @ 640 by 480 with 4-bit and will not adjust. HELP!! I am currently using my laptop, and have verified that everything is on my server and can access with no problem
  • rolindakay Sep 14, 2010
    I have already disconnected the 2nd Monitor (HP LE1711 LCD Monitor) and uninstalled all drivers -- then reinstalled only my main monitor driver (HP 2465 LCD Monitor) -- Yes Running XP.
    Have been through the display/driver/update thing about 20 times , , , ,
    Also disconnected both monitors and reboot to see if the Plug and play would recognize it. What's strange is the hard boot shows the HP and Windows screen correctly, it is when the Windows login screen comes up that everything is distorted
  • 12,061 Answers
OK, don't worry, here is what to do, start up your PC,and pump the, F & 8 Keys, F8, this will bring up Safe Mode, now choose Standard VGA from the screen OR simply proceed through to Safe Boot, or Safe Mode with networking (Recommended) In any event, the main screen will now only display standard VGA which is 800x600, if still at 640x480, the you simply will have to persevere with that resolution, to do the tasks below, it will be hard but not impossible, remember, TAB, steps it, Enter is Yes, and ESC is No/Cancel. Standard VGA, .this is so almost any monitor will work. What has happened is your driver has faulted, this needs to be reinstalled or replaced.
Now if you can boot up in standard VGA or Safe Mode, then it maybe best to go to your video card manufacturers website and download the latest drivers and install them. Or if you know where the existing files are stored navigate there and run the installer again.
You can do that, or go to Device manager, and find your VGA Card and Click on Update drivers, this then should initiate a search for said drivers, and it should find the correct drivers for your system and install them, you may need to reboot a couple of times to get it OK, now, you may have to enable & set up multiple desktop again too to get the 2nd monitor to work.
Posted on Sep 14, 2010
  • 3,247 Answers
Assuming you are running windows XP, you go to Control panel and select display -- settings -- advanced. Turn the 2nd monitor off so that the main display can return to its regular setting.
It will help if you provide the Monitor make and model for both.
I have 2 monitors my main monitor is blank and I can only see the 2nd monitor. How do I move the main monitor to the 2nd screen?
Right click on desktop and click adjust resolution or something similar, then you'll have the option to activate the other monitor and arrange the desktops in however way you like them
Aug 20, 2014 | Dell Computers & Internet
I CANNOT INSTALL THIS PLOTTER ON MY WINDOWS VISTA ULTIMATE,WHEN I'M TRYING TO INSTALL IT ,IT SAYS" IT CANNOT INSTALL ON THIS TYPE OF WINDOWS"
try it to install on higher version i mean on win 7.or try to check if how many bits is asked there are three bits available i know they are 16,32 and 64 bits
May 18, 2011 | Computers & Internet
Unable to adjust the settings for brightness and contrast .
To adjust the display settings:
1. Press the flywheel control. The main menu appears.
The current display settings appear across the top of the main menu.
2. Rotate the flywheel to highlight an option. The name of the
highlighted option appears in the center of the menu.
3. Press the flywheel control to select the highlighted option, then
rotate the flywheel to adjust it.
Some options can only be enabled or disabled. There are also some
options that contain additional menus.
4. Repeat Steps 2 and 3 until you have made all your changes.
5. Rotate the flywheel control until Exit is highlighted, then press
it to exit the OSD control system.
OSD OPTIONS:
Contrast increases or decreases display image contrast.
Brightness increases or decreases display image brightness.
Horizontal Size increases or decreases the width of the display image.
Horizontal Position moves display image to the left or right side of
the screen.
Vertical Size increases or decreases the height of the display image.
Vertical Position moves display image to the top or bottom of the
screen,
Pincushion curves the sides of the display image inward or outward.
Trapezoid increases or decreases the trapezoid distortion of the
display image.
Degauss removes magnetic discoloration from the display image.
Recall returns most options to the original factory default settings
if the monitor is currently using a preset video mode. (See the “Video
modes” section in this guide for information about the factory preset
modes.)
Advanced Option opens the Advanced Option menu. Color opens the Color
Manager menu.
Language changes the display language for the OSD control system.
User displays information about the monitor’s preset modes.
OSD Manager moves the OSD control window on the screen.
Exit closes OSD control system.
Jun 21, 2010 | Gateway EV 910 19" CRT Monitor
MY MONITOR HAS TURNED PINK
what monitor you have LCD or the picturetube monitor?
If it is a Picturetube monitor, the blue/ yello/ green cathod might have lost.
If they are showing ok then you can adjust your Monitor Data Cable, if needed if may need to replaced. The major probablity here is showing as Data Supply Cable for Monitor needs to be changed, i could help more if i had more details about the problem.
Feb 24, 2010 | Computers & Internet
Compaq mv540 monitor suddenly can't adjust screen features
Please somebody give a solution as same is experienced by me tooo.
Jan 22, 2010 | Compaq MV 540 15" CRT Monitor
I don't know how to increase the volume
OSD Menu Functions
English
All the function settings for the LCD monitor are controlled via the control keys located on
the bottom part of the front panel. To display the OSD main menu, press the “Menu”
keypad button on the control keys2.gif. (Note: The OSD menu display will disappear
automatically after approximately 10 seconds, if no action is taken.)
The LCD2.gif monitor has been adjusted to optimal settings before shipment. Adjustments to
the monitor settings can be made using the OSD menu.
• Press the “Menu” button to display the OSD.
• Press the ▲ or ▼ button to select the function to be adjusted.
• Press the �� button to access the function to be adjusted.
• Press the ▲ or ▼ button to select the sub-function to be adjusted.
• Press the �� or �� buttons to change the current setting of the sub-function.
• To go back to the previous menu, press the button. Changes are saved
automatically.
Source
• To exit the OSD menu press "Menu" again. It automatically will save any changes
that have been made.
If this is helpfull; please indicate so.
JZKlipper/Mike
Nov 11, 2009 | Westinghouse LCM-19v5 Monitor
I don't know how to increase/adjust the volume on my LCM-19v5 computer monitor
OSD Menu Functions
English
keypad button on the control keys. (Note: The OSD menu display will disappear
The LCD monitor has been adjusted to optimal settings before shipment. Adjustments to
automatically.
Source
JZKlipper/Mike
Nov 11, 2009 | Westinghouse Computers & Internet
Hannspree 19" HF199H LCD - Display is LARGE on monitor!
Try Control Panel - Appearance or Display- You can change how your 2nd display looks there.. Sounds like you have it set in Clone mode...(both displays show the same things)...See if you can reset the 2nd display resolution while keeping the laptop in its normal resolution. Not all machines can do this...but most recent ones should be able to.
Mar 27, 2009 | Hannspree 19" Widescreen LCD Flat Panel...
Sudden lost of color gamma - "discoloration"
GO ON LINE AND SEE IF ANYONE ELSE HAS BEEN HAVING THE SAME OR SIMERLY PROBLEMS OR MAYBE A RECALL ON THAT CERTAIN ITEM.
ADDRESS BAR:
BENQ G2110W GAMMA ISSUES,
GAMMA FAILURE,
LOST GAMMA.
ENTER...................... AFTER EACH COMA
ANYTYPE OF PROBLEMS WITH BENQ G2110W
ENTER
GO ON TO ABOUT.COM, ASK.COM, INFO.COM
ROD
Feb 17, 2009 | BenQ G2110W 21" Monitor
Problem with my LG monitor L194WT
You will have to increase the referesh rate first and then go into the game and reset the resolution. The resolution bit is secondary. If increasing the refresh rate works, then you dont have to change the resolution :)
May 27, 2008 | Computers & Internet
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
